Tempetare range
Hello there,
I'm a beginner at Arduino and ı wanna do a project about temperature sensors. What do I need to do to run it in a certain temperature range?
For example, operating the heater in the range of 22-26 degrees.
sinirdeger1= 22
sinirdeger2= 26
if (temp<=sinirdeger1 || temp<=sinirdeger2)
digitalWrite(role1,HIGH);
digitalWrite(role1,LOW);
Do you want the heater to turn on if the temperature is below 22 and off it above 26 ?
sinirdeger1= 22
sinirdeger2= 26
if temp is less than 22 it is bound to be less than 26. Check the logic of your test
Yes, exactly.
Then you need to program
if temperature < 22
  turn on heater
else if temperature greater than 26
  turn off the heater
Is that what your code does ?
All I need is it.
Then try to write it for yourself
Well would that be degrees F or C? What sensor are you using to get temperature?
Simple On/Off is what I am seeing but how well it works will depend on how well the heaters are controlled because depending on your application turning a heater Off at 26 degrees C or F the temp is likely to creep above that set point after the heating source (element) is turned off. Anyway you may have some considerations to make. :slight_smile:
Ron
