Using a simple equation, a conversion to lux can be obtained. However, the measurement is limited to a maximum of 1000 lux. Is there a way to get more than 1000 lux?
float lux = analogRead(TEMT6000_PIN) * 0.9765625; // 1000 / 1024 = 0.9765625
cevepe:
Can you give a source for that ?
cevepe:
Read the datasheet of the sensor for the maximum amount of light it can measure.
Then check the datasheet for an application to measure a large range.
Bad luck: The maximum amount of light it can measure is not in the datasheet.
The tutorial of Sparkfun does not tell it either: TEMT6000 Ambient Light Sensor Hookup Guide - SparkFun Learn.
The graph in the datasheet is for a range of 10 to 1000 lux. That same graph is in the Sparkfun tutorial.
Solution: Buy an other sensor.
You can not measure sunlight with a sensor, for sunlight you need a dark filter.
When you want to measure lux, buy a sensor with a digital interface that tells the lux.
