How can you calculate the level of stress (tension ratio formula) in the blood or what is the relationship?
in Programming
in Programming
What's the regular formula?
In programming, we don't have regular "equations". We have "expressions" or "functions" that return a value. The result of an expression is on the left and it's often called an "lvalue". A formula needs to be converted to the form of an expression or algorithm.
A couple of simple example expressions:
X = 2+2;
X = A + B; //A & B are known and defined and X is the result.
I am currently looking for the normal formula to convert it into a program, but I need someone who knows medicine for you to give us the formula for tension in the blood
I think there is a direct relationship between oxidation rate and heart rate
I'll bet that Google will find plenty of literature describing the formula and how to apply it.
