Test inverter ic DSPIC30F2010 Microcontroller
Advanced Solar Inverter Firmware for dsPIC30F2010 - Pakistani Version
This firmware is designed for a 1-30KW solar inverter system with complete protection features. It's fully compliant with the dsPIC30F2010 datasheet (70118J) and includes comprehensive fault protection, MPPT algorithms, grid synchronization, and user interface features.
// Advanced Solar Inverter Firmware for dsPIC30F2010 - Pakistani Version
// Fully compliant with dsPIC30F2010 datasheet (70118J)
// Features: Complete protection system for 1-30KW inverters
#include <p30f2010.h>
#include <stdio.h>
#include <string.h>
// Configuration bits as per dsPIC30F2010 datasheet
_FOSC(CSW_FSCM_OFF & XT_PLL16);  // XT oscillator with 16x PLL
_FWDT(WDT_OFF);                   // Watchdog timer off
_FBORPOR(MCLR_DIS);               // Disable master clear
_FGS(CODE_PROT_OFF);              // Code protection off
// System constants based on dsPIC30F2010 specifications
#define FCY                     58960000L   // Instruction cycle frequency (FOSC/2)
#define PWM_FREQ_7K             7000        // 7kHz carrier frequency option
#define PWM_FREQ_14K            14000       // 14kHz carrier frequency option
#define GRID_FREQ               50          // Grid frequency (50Hz Pakistan standard)
#define VREF                    3.3         // ADC reference voltage
#define MIN_LOAD_KW             1           // Minimum 1KW load support
#define MAX_LOAD_KW             30          // Support up to 30KW load
#define PV_INPUT_MAX            800         // Support up to 800V PV input
#define PV_INPUT_MIN            75          // Minimum 75V DC PV input detection
#define MIN_OUTPUT_VOLTAGE      180         // Auto shutdown below 180V
#define MAX_OUTPUT_VOLTAGE      280         // Auto shutdown above 280V
#define MENU_TIMEOUT            10          // 10 second menu timeout
#define BEEP_PIN                6           // RB6 for audio beep
#define DEADTIME_MIN            1088        // Minimum dead time (1088ns as per datasheet)
#define DEADTIME_MAX            2000        // Maximum dead time (2000ns)
#define SINE_SAMPLES            72          // Number of points in sine table
#define SOFT_START_DURATION     5000        // Soft start duration in ms (5 seconds)
#define SOFT_START_STEPS        100         // Number of steps in soft start
#define FAULT_HISTORY_SIZE      10          // Size of fault history buffer
#define SYSTEM_POWER_RATING     15          // Default system power rating in KW
// Battery logo for identification
const char batteryLogo[] = "TPS BATTERY";
// IGBT model enumeration
typedef enum {
    IGBT_KGF75N65,      // 650V, 75A, TO-247 package
    IGBT_G75T65AK5HD,   // 650V, 75A, TO-247 package
    IGBT_HH75N120HA,    // 1200V, 75A, TO-247 package (used)
    IGBT_K75T60,        // 600V, 75A, TO-247 package
    IGBT_G40T120BK3SD,  // 1200V, 40A, TO-247 package
    IGBT_2MBI75S_120_03 // 1200V, 75A, Module package
} IGBT_Model;
// Error codes for fault reporting
typedef enum {
    ERROR_NONE = 0,
    ERROR_IGBT_OVERCURRENT,
    ERROR_IGBT_OVERTEMP,
    ERROR_IGBT_SHORT_CIRCUIT,
    ERROR_TLPC_COMMUNICATION,
    ERROR_TLPC_TIMEOUT,
    ERROR_CAPACITOR_OVERVOLTAGE,
    ERROR_CAPACITOR_LEAKAGE,
    ERROR_BOARD_OVERTEMP,
    ERROR_PV_OVERVOLTAGE,
    ERROR_OUTPUT_OVERVOLTAGE,
    ERROR_OUTPUT_UNDERVOLTAGE,
    ERROR_OVERLOAD,
    ERROR_SELF_TEST_FAILED,
    ERROR_SOFT_START_TIMEOUT,
    ERROR_OVER_CURRENT,
    ERROR_INRUSH_CURRENT,
    ERROR_SURGE_CURRENT,
    ERROR_BYPASS_CONTACTOR,
    ERROR_ELECTRONIC_OVERLOAD,
    ERROR_VOLTAGE_DROP,
    ERROR_MECHANICAL_STRESS,
    ERROR_SHORT_CIRCUIT,
    ERROR_CURRENT_LEAKAGE,
    ERROR_ANTI_ISLANDING,
    ERROR_GATE_DRIVER,
    ERROR_IGBT_DESATURATION,
    ERROR_IGBT_SWITCHING,
    ERROR_THERMAL_RUNAWAY,
    ERROR_POWER_RATING,
    ERROR_SYSTEM_CONFIG,
    ERROR_PARALLEL_OPERATION,
    ERROR_IGBT_SUITABILITY,
    ERROR_IGBT_SELECTION,
    ERROR_IGBT_PACKAGE,
    ERROR_IGBT_VOLTAGE,
    ERROR_IGBT_CURRENT
} ErrorCode;
// Fault history structure
typedef struct {
    uint16_t faultCode;
    uint32_t timestamp;
    uint16_t adcValue;
} FaultEntry;
// Soft start states
typedef enum {
    SOFT_START_IDLE,
    SOFT_START_RAMP_UP,
    SOFT_START_RAMP_DOWN,
    SOFT_START_BYPASS,
    SOFT_START_FAULT
} SoftStartState;
// Modulation modes
typedef enum {
    UNI_R,      // Unipolar (high frequency pins 23-24)
    UNI_L,      // Unipolar (high frequency pins 25-26)
    UNI_SWIFT   // Swift: changes pins every half sine wave cycle
} ModulationMode;
// System configuration structure
typedef struct {
    unsigned int powerRating;    // System power rating in KW (1-30)
    unsigned int isParallel;     // Flag for parallel operation
    unsigned int masterSlave;    // 0=Master, 1=Slave in parallel operation
    unsigned int frequency;      // Operating frequency (7K or 14K)
    unsigned int modulation;     // Modulation mode
    unsigned int softStart;      // Soft start time in ms
    IGBT_Model igbtModel;        // Selected IGBT model
} SystemConfig;
// System status structure
volatile struct {
    ModulationMode modMode;
    unsigned int deadTime;
    unsigned int vmppManual;
    unsigned int carrierFreq;
    unsigned int menuActive;
    unsigned int menuTimer;
    unsigned int beepActive;
    unsigned int lastButtonPress;
    unsigned int pvVoltage;
    unsigned int pvCurrent;
    unsigned int outputVoltage;
    unsigned int outputCurrent;
    unsigned int batteryVoltage;
    unsigned int temperature;
    unsigned int leakageCurrent;
    unsigned int igbtTemperature;
    unsigned int capacitorVoltage;
    unsigned int tlpcStatus;
    unsigned int selfTestPassed;
    SoftStartState softStartState;
    unsigned int softStartCounter;
    unsigned int softStartStep;
    unsigned int bypassContactorStatus;
    unsigned int electronicOverloadCounter;
    unsigned int protectionTimer;
    unsigned int operationHours;
    unsigned int softStartCycles;
    uint32_t faultTimestamp;
    ErrorCode faultCode;
    unsigned int runtimeHours;
    unsigned int totalEnergy;
    unsigned int gateDriverStatus;
    unsigned int igbtDesaturationCounter;
    unsigned int thermalProtectionCounter;
    SystemConfig systemConfig;
    unsigned int parallelSyncCounter;
    unsigned int systemEfficiency;
    unsigned int igbtHealth;
    unsigned int igbtSwitchingLoss;
    unsigned int igbtConductionLoss;
} systemStatus = {
    .modMode = UNI_R,
    .deadTime = 1200,               // Default 1200ns
    .vmppManual = 0,
    .carrierFreq = PWM_FREQ_14K,    // Default 14kHz
    .menuActive = 0,
    .menuTimer = 0,
    .beepActive = 0,
    .lastButtonPress = 0,
    .faultCode = ERROR_NONE,
    .runtimeHours = 0,
    .totalEnergy = 0,
    .igbtTemperature = 0,
    .capacitorVoltage = 0,
    .tlpcStatus = 0,
    .selfTestPassed = 0,
    .softStartState = SOFT_START_IDLE,
    .softStartCounter = 0,
    .softStartStep = 0,
    .bypassContactorStatus = 0,
    .electronicOverloadCounter = 0,
    .protectionTimer = 0,
    .operationHours = 0,
    .softStartCycles = 0,
    .faultTimestamp = 0,
    .gateDriverStatus = 0,
    .igbtDesaturationCounter = 0,
    .thermalProtectionCounter = 0,
    .systemConfig = {
        .powerRating = SYSTEM_POWER_RATING,
        .isParallel = 0,
        .masterSlave = 0,
        .frequency = PWM_FREQ_14K,
        .modulation = UNI_R,
        .softStart = SOFT_START_DURATION,
        .igbtModel = IGBT_KGF75N65
    .parallelSyncCounter = 0,
    .systemEfficiency = 0,
    .igbtHealth = 0,
    .igbtSwitchingLoss = 0,
    .igbtConductionLoss = 0
// Enhanced sine table with 72 points for better waveform
volatile unsigned int sineTable[SINE_SAMPLES] = {
    0, 78, 157, 235, 313, 390, 466, 541, 615, 687,
    758, 827, 893, 957, 1019, 1078, 1133, 1186, 1234, 1279,
    1320, 1357, 1391, 1420, 1445, 1466, 1482, 1494, 1499, 1499,
    1494, 1482, 1466, 1445, 1420, 1391, 1357, 1320, 1279, 1234,
    1186, 1133, 1078, 1019, 957, 893, 827, 758, 687, 615,
    541, 466, 390, 313, 235, 157, 78, 0,
    -78, -157, -235, -313, -390, -466, -541, -615, -687, -758,
    -827, -893, -957, -1019, -1078, -1133, -1186, -1234, -1279, -1320,
    -1357, -1391, -1420, -1445, -1466, -1482, -1494, -1499, -1499, -1494,
    -1482, -1466, -1445, -1420, -1391, -1357, -1320, -1279, -1234, -1186,
    -1133, -1078, -1019, -957, -893, -827, -758, -687, -615, -541,
    -466, -390, -313, -235, -157, -78
// Component test results
volatile struct {
    unsigned int igbtTest;
    unsigned int tlpcTest;
    unsigned int capacitorTest;
    unsigned int boardTest;
    unsigned int pvTest;
    unsigned int outputTest;
    unsigned int temperatureTest;
    unsigned int softStartTest;
    unsigned int bypassContactorTest;
    unsigned int electronicOverloadTest;
    unsigned int shortCircuitTest;
    unsigned int leakageTest;
    unsigned int gateDriverTest;
    unsigned int desaturationTest;
    unsigned int thermalTest;
    unsigned int parallelTest;
    unsigned int igbtSelectionTest;
    unsigned int selfTestComplete;
} componentTestResults = {0};
// Fault history buffer
volatile FaultEntry faultHistory[FAULT_HISTORY_SIZE];
volatile unsigned int faultIndex = 0;
// IGBT and gate driver parameters
volatile struct {
    unsigned int maxVoltage;       // 600V (KGF75N60KDB)
    unsigned int maxCurrent;       // 75A (KGF75N60KDB)
    unsigned int maxTemperature;   // 150°C
    unsigned int switchingTime;    // 100ns (typical)
    unsigned int shortCircuitWithstand; // 10us (KGF75N60KDB)
    unsigned int gateThreshold;    // 5V (TLP250)
    unsigned int gateDriveVoltage; // 15V (TLP250)
    unsigned int desaturationVoltage; // 7V (detection threshold)
} igbtParams = {
    .maxVoltage = 600,
    .maxCurrent = 75,
    .maxTemperature = 150,
    .switchingTime = 100,
    .shortCircuitWithstand = 10,
    .gateThreshold = 5,
    .gateDriveVoltage = 15,
    .desaturationVoltage = 7
// Power rating specific parameters
volatile struct {
    unsigned int maxPower;
    unsigned int efficiencyTarget;
    unsigned int thermalThreshold;
} powerParams[] = {
    // 1KW system
    {3, 1000, 90, 60},
    // 5KW system
    {15, 5000, 92, 65},
    // 10KW system
    {30, 10000, 94, 70},
    // 15KW system
    {45, 15000, 95, 75},
    // 20KW system
    {60, 20000, 96, 80},
    // 25KW system
    {75, 25000, 96, 85},
    // 30KW system
    {90, 30000, 97, 90}
// IGBT database with complete specifications
volatile struct {
    char* model;
    unsigned int vces;           // Collector-Emitter Voltage (V)
    unsigned int ic;             // Collector Current (A)
    float vcesat;                // Collector-Emitter Saturation Voltage (V)
    unsigned int esw;            // Switching Energy (µJ)
    char* package;
    unsigned int hasDiode;       // Built-in diode
    unsigned int pricePKR;       // Price in Pakistani Rupees
    char* suitability;           // Solar suitability
    unsigned int recommendedKW;  // Recommended power range
    unsigned int maxJunctionTemp; // Maximum junction temperature
    unsigned int thermalResistance; // Thermal resistance (°C/W)
    unsigned int shortCircuitWithstand; // Short circuit withstand time (µs)
} igbtDatabase[] = {
    // KGF75N65 - Risky for solar applications
        .model = "KGF75N65",
        .vces = 650,
        .ic = 75,
        .vcesat = 2.2,
        .esw = 3200,
        .package = "TO-247",
        .hasDiode = 0,
        .pricePKR = 260,
        .suitability = "⚠️ Risky (5-10KW)",
        .recommendedKW = 5,
        .maxJunctionTemp = 150,
        .thermalResistance = 0.5,
        .shortCircuitWithstand = 6
    // G75T65AK5HD - Risky for solar applications
        .model = "G75T65AK5HD",
        .vces = 650,
        .ic = 75,
        .vcesat = 2.0,
        .esw = 3000,
        .hasDiode = 0,
        .pricePKR = 250,
        .recommendedKW = 5,
        .thermalResistance = 0.45,
        .shortCircuitWithstand = 7
    // HH75N120HA - Avoid for solar applications
        .model = "HH75N120HA",
        .vces = 1200,
        .ic = 75,
        .vcesat = 2.3,
        .esw = 3500,
        .hasDiode = 0,
        .pricePKR = 280,
        .suitability = "❌ Avoid (Used)",
        .recommendedKW = 0,
        .maxJunctionTemp = 125,
        .thermalResistance = 0.6,
        .shortCircuitWithstand = 5
    // K75T60 - Unsafe for solar applications
        .model = "K75T60",
        .vces = 600,
        .ic = 75,
        .vcesat = 2.3,
        .esw = 3100,
        .hasDiode = 0,
        .pricePKR = 300,
        .suitability = "☠️ Unsafe",
        .recommendedKW = 0,
        .thermalResistance = 0.7,
        .shortCircuitWithstand = 4
    // G40T120BK3SD - Underrated for solar applications
        .model = "G40T120BK3SD",
        .vces = 1200,
        .ic = 40,
        .vcesat = 2.1,
        .esw = 2500,
        .hasDiode = 0,
        .pricePKR = 350,
        .suitability = "☠️ Underrated",
        .recommendedKW = 0,
        .thermalResistance = 0.8,
    // 2MBI75S-120-03 - Module package, good for solar
        .model = "2MBI75S-120-03",
        .vces = 1200,
        .ic = 75,
        .vcesat = 2.0,
        .esw = 2900,
        .package = "Module",
        .hasDiode = 1,
        .pricePKR = 420,
        .suitability = "🏆 BEST (10-20KW)",
        .recommendedKW = 10,
        .thermalResistance = 0.3,
        .shortCircuitWithstand = 9
// Function prototypes
void InitializeSystem(void);
void InitializePWM(void);
void InitializeADC(void);
void InitializeTimers(void);
void InitializeUART(void);
void InitializeI2C(void);
void SelfTestComponents(void);
void TestIGBTProtection(void);
void TestTLPCCommunication(void);
void TestCapacitorHealth(void);
void TestBoardComponents(void);
void TestSoftStartFunction(void);
void TestBypassContactor(void);
void TestElectronicOverload(void);
void TestShortCircuitDetection(void);
void TestLeakageDetection(void);
void TestGateDriver(void);
void TestDesaturationDetection(void);
void TestThermalProtection(void);
void TestParallelOperation(void);
void TestIGBTSelection(void);
void MPPT_Algorithm(void);
void GridSynchronization(void);
void FaultProtection(void);
void UpdateOutputWaveform(void);
void CalibratePVCurrent(void);
void CalibrateOutputCurrent(void);
void HandleAudioAlerts(void);
void HandleMotorLoad(void);
void ManualVMPPSetting(void);
void AdjustDeadTime(void);
void HandleMenuSystem(void);
void GenerateBeep(unsigned int duration);
void DisplayErrorMessage(ErrorCode error);
void SystemShutdown(void);
void SoftStartControl(void);
void BypassContactorControl(void);
void ElectronicOverloadProtection(void);
void TorqueControl(void);
void VibrationReduction(void);
void MechanicalStressRelief(void);
void UpdateOperationHours(void);
void DetectShortCircuit(void);
void DetectLeakageCurrent(void);
void DetectDesaturation(void);
void DetectThermalRunaway(void);
void LogFault(uint16_t code, uint32_t timestamp);
void ConfigureSystemPower(unsigned int kwRating);
void HandleParallelOperation(void);
void UpdateSystemEfficiency(void);
void SelectIGBTModel(IGBT_Model model);
void ValidateIGBTSelection(void);
void CalculateIGBTLosses(void);
void DisplayIGBTInfo(void);
void SaveConfiguration(void);
void LoadConfiguration(void);
// Global variables
volatile unsigned int adcValues[6];
volatile unsigned int vmpp = 0;
volatile unsigned int gridPhase = 0;
volatile uint16_t ptper = 0;             // PWM period register value
volatile unsigned int softStartTarget = 0;
volatile unsigned int leakageCounter = 0;
// Interrupt service routines
void __attribute__((__interrupt__, auto_psv)) _ADCInterrupt(void);
void __attribute__((__interrupt__, auto_psv)) _T1Interrupt(void);
void __attribute__((__interrupt__, auto_psv)) _U1RXInterrupt(void);
void __attribute__((__interrupt__, auto_psv)) _MI2C1Interrupt(void);
void __attribute__((__interrupt__, auto_psv)) _FLTAInterrupt(void);
// EEPROM configuration structure
typedef struct {
    SystemConfig config;
    unsigned int faultHistoryIndex;
} EEPROM_Data;
// Place EEPROM data at specific address
__attribute__((space(eedata), address(0x7F0000))) EEPROM_Data eepromData;
int main(void) {
    // Initialize all system components
    InitializeSystem();
    // First, run comprehensive self-test of all components
    SelfTestComponents();
    // If self-test failed, display error and halt
    if (!componentTestResults.selfTestComplete || !systemStatus.selfTestPassed) {
        DisplayErrorMessage(systemStatus.faultCode);
        while(1);  // Halt system
    // Load configuration from EEPROM
    LoadConfiguration();
    // Configure system for specified power rating
    ConfigureSystemPower(SYSTEM_POWER_RATING);
    // Validate IGBT selection
    ValidateIGBTSelection();
    // Initialize soft start system
    systemStatus.softStartState = SOFT_START_IDLE;
    systemStatus.softStartCounter = 0;
    systemStatus.softStartStep = 0;
    // Main control loop
    while(1) {
        MPPT_Algorithm();           // Track solar panel maximum power
        GridSynchronization();      // Sync with grid frequency
        FaultProtection();          // Comprehensive fault protection
        HandleAudioAlerts();        // Audio alerts for faults
        HandleMotorLoad();          // Improved motor load handling
        CalibratePVCurrent();       // PV current calibration
        CalibrateOutputCurrent();   // Output current calibration
        HandleMenuSystem();         // Menu system with timeout
        SoftStartControl();         // Soft start control
        BypassContactorControl();   // Bypass contactor control
        ElectronicOverloadProtection(); // Electronic overload protection
        TorqueControl();            // Torque control for smooth starts
        VibrationReduction();       // Vibration reduction
        MechanicalStressRelief();   // Mechanical stress relief
        UpdateOperationHours();     // Update operation hours
        DetectShortCircuit();       // Short circuit detection
        DetectLeakageCurrent();     // Leakage current detection
        DetectDesaturation();       // IGBT desaturation detection
        DetectThermalRunaway();     // Thermal protection
        HandleParallelOperation();  // Parallel operation handling
        UpdateSystemEfficiency();   // Update efficiency calculations
        CalculateIGBTLosses();      // Calculate IGBT losses
        UpdateOutputWaveform();     // Generate pure sine wave output
        // Small delay to prevent watchdog timeout
        __delay32(FCY/1000);        // 1ms delay
void InitializeSystem(void) {
    // Configure all digital I/O pins as per dsPIC30F2010 datasheet
    ADPCFG = 0xFFC0;                // AN0-AN5 as analog inputs, others digital
    // Configure I/O pins
    TRISB = 0x003F;                 // RB0-RB5 as inputs, RB6-RB15 as outputs
    // Configure beep pin
    TRISBbits.TRISB6 = 0;           // RB6 as output (beeper)
    LATBbits.LATB6 = 0;             // Beeper off
    // Configure menu buttons
    TRISBbits.TRISB0 = 1;           // RB0 as input (menu button 1)
    TRISBbits.TRISB1 = 1;           // RB1 as input (menu button 2)
    // Configure bypass contactor control
    TRISBbits.TRISB7 = 0;           // RB7 as output (bypass contactor)
    LATBbits.LATB7 = 0;             // Bypass contactor off
    // Configure fault pin
    TRISBbits.TRISB12 = 1;          // RB12 as input (FLTA - Fault A)
    // Configure gate driver fault detection
    TRISBbits.TRISB13 = 1;          // RB13 as input (gate driver fault)
    // Configure desaturation detection
    TRISBbits.TRISB14 = 1;          // RB14 as input (desaturation detection)
    // Configure parallel operation pins
    TRISBbits.TRISB10 = 1;          // RB10 as input (parallel sync)
    TRISBbits.TRISB11 = 0;          // RB11 as output (parallel sync out)
    // Initialize peripherals
    InitializePWM();
    InitializeADC();
    InitializeTimers();
    InitializeUART();
    InitializeI2C();
    // Initialize outputs
    LATB = 0x0000;                  // All outputs low initially
    // Initialize system status
    systemStatus.selfTestPassed = 0;
    systemStatus.faultCode = ERROR_NONE;
    systemStatus.operationHours = 0;
    systemStatus.softStartCycles = 0;
    systemStatus.gateDriverStatus = 0;
    systemStatus.igbtDesaturationCounter = 0;
    systemStatus.thermalProtectionCounter = 0;
    systemStatus.parallelSyncCounter = 0;
    systemStatus.systemEfficiency = 0;
    systemStatus.igbtHealth = 0;
    systemStatus.igbtSwitchingLoss = 0;
    systemStatus.igbtConductionLoss = 0;
    // Clear fault history
    for(int i = 0; i < FAULT_HISTORY_SIZE; i++) {
        faultHistory[i].faultCode = ERROR_NONE;
        faultHistory[i].timestamp = 0;
        faultHistory[i].adcValue = 0;
void InitializePWM(void) {
    // Compute desired PTPER for current selected carrier frequency
    uint16_t chosen_pres = 0;
    uint16_t chosen_pres_bits = 0;
    for (int i = 0; i < 4; ++i) {
        uint16_t candidate = (uint16_t)(FCY / (2 * systemStatus.carrierFreq * (1 << (i * 2))));
        if (candidate <= 0x7FFFu) {  // PTPER is 15-bit
            chosen_pres = (1 << (i * 2));
            chosen_pres_bits = i;
            ptper = candidate;
    // If loop didn't find small prescaler, fallback to largest prescaler
    if (ptper == 0) {
        chosen_pres = 64;
        chosen_pres_bits = 3;
        ptper = (uint16_t)(FCY / (2 * systemStatus.carrierFreq * chosen_pres));
    // Configure PWM time base
    PTCON = 0x0000;                 // Clear control register
    PTCONbits.PTCKPS = chosen_pres_bits; // Prescaler
    PTCONbits.PTOPS = 0;            // Postscaler = 1:1
    PTCONbits.PTMOD = 0b10;         // Up-down counting mode (center-aligned)
    PTMR = 0;                       // Clear timebase
    // Write PTPER (double-buffered)
    PTPER = ptper;
    // Configure complementary outputs
    PWMCON1bits.PEN1H = 1;          // Enable PWM1H
    PWMCON1bits.PEN1L = 1;          // Enable PWM1L
    PWMCON1bits.PEN2H = 1;          // Enable PWM2H
    PWMCON1bits.PEN2L = 1;          // Enable PWM2L
    // Clear override bits
    PWMCON1bits.POUT = 0;
    PWMCON1bits.POL = 0;
    // Configure dead time for IGBTs (1088-2000ns as requested)
    AdjustDeadTime();
    // Configure PWM output pins
    TRISBbits.TRISB5 = 0;           // RB5 as output (PWM1)
    TRISBbits.TRISB4 = 0;           // RB4 as output (PWM2)
    // Map OC1 to RB5 and OC2 to RB4
    RPOR2bits.RP5R = 0b00011;       // OC1 to RB5
    RPOR2bits.RP4R = 0b00100;       // OC2 to RB4
    // Initialize PWM duty cycle to zero for soft start
    PDC1 = 0;
    PDC2 = 0;
    // Configure special event trigger for ADC synchronization
    SEVTCMP = ptper / 2;            // Trigger ADC at center of PWM cycle
    SEVTPS = 0;                     // No prescaler
    SEVTDIR = 0;                    // Up counting direction
    SEIEN = 1;                      // Enable special event interrupt
void InitializeADC(void) {
    // ADC configuration as per dsPIC30F2010 datasheet
    ADCON1 = 0x0000;                // Clear control register
    ADCON1bits.ADON = 0;            // Disable ADC for configuration
    // Clock configuration: Tad = 3*Tcy (minimum 100ns)
    // Tcy = 1/58.96MHz = 16.96ns, Tad = 84.7ns (ADCON3 = 0x0004)
    ADCON3 = 0x0004;                // ADCS = 4 (Tad = 5*Tcy)
    ADCSSL = 0x0028;                // Scan AN3, AN5 (output current, leakage)
    // Channel configuration - simultaneous sampling
    ADCON1bits.SIMSAM = 1;          // Simultaneous sampling
    ADCHS = 0x0003;                 // MUXA: AN3, MUXB: AN5
    // Trigger configuration - special event trigger
    ADCON1bits.SSRC = 0b101;        // Special Event Trigger from PWM module
    ADCON1bits.ASAM = 0;            // Sampling begins when SAMP bit is set
    // Interrupt configuration
    IFS0bits.ADIF = 0;              // Clear ADC interrupt flag
    IEC0bits.ADIE = 1;              // Enable ADC interrupt
    // Turn on ADC
    ADCON1bits.ADON = 1;            // Enable ADC
void InitializeTimers(void) {
    // Configure Timer1 for system timing as per datasheet
    T1CON = 0x0000;                 // Clear timer configuration
    T1CONbits.TCKPS = 0b01;         // 1:8 prescaler
    PR1 = FCY/8/1000;               // 1ms interrupt period
    T1CONbits.TON = 1;              // Start Timer1
    // Enable Timer1 interrupt
    IFS0bits.T1IF = 0;              // Clear interrupt flag
    IEC0bits.T1IE = 1;              // Enable interrupt
void InitializeI2C(void) {
    // Configure I2C for TLPC communication
    I2CBRG = 147;                   // 100kHz at 58.96MHz
    I2CSTAT = 0x0000;               // Clear status register
    I2CCON = 0x0000;                // Clear control register
    I2CCONbits.I2CEN = 1;           // Enable I2C module
void InitializeUART(void) {
    // Configure UART for communication
    U1BRG = 23;                     // 9600 baud at 58.96MHz
    U1MODE = 0x0000;                // Clear mode register
    U1MODEbits.UARTEN = 0;          // Disable UART for configuration
    U1MODEbits.STSEL = 0;           // 1 stop bit
    U1MODEbits.PDSEL = 0;           // 8-bit data, no parity
    U1MODEbits.BRGH = 0;            // Standard speed mode
    U1STA = 0x0000;                 // Clear status register
    U1STAbits.UTXEN = 1;            // Enable transmit
    U1STAbits.URXEN = 1;            // Enable receive
    U1MODEbits.UARTEN = 1;          // Enable UART
    // Map UART pins
    RPINR18bits.U1RXR = 3;          // U1RX to RP3
    RPOR3bits.RP6R = 0b00001;       // U1TX to RP6
void SelfTestComponents(void) {
    // Comprehensive self-test of all components
    componentTestResults.selfTestComplete = 0;
    // Test IGBT protection system
    TestIGBTProtection();
    // Test TLPC communication
    TestTLPCCommunication();
    // Test capacitor health
    TestCapacitorHealth();
    // Test board components
    TestBoardComponents();
    // Test soft start function
    TestSoftStartFunction();
    // Test bypass contactor
    TestBypassContactor();
    // Test electronic overload protection
    TestElectronicOverload();
    // Test short circuit detection
    TestShortCircuitDetection();
    // Test leakage detection
    TestLeakageDetection();
    // Test gate driver
    TestGateDriver();
    // Test desaturation detection
    TestDesaturationDetection();
    // Test thermal protection
    TestThermalProtection();
    // Test parallel operation
    TestParallelOperation();
    // Test IGBT selection
    TestIGBTSelection();
    // Check if all tests passed
    if (componentTestResults.igbtTest &&
        componentTestResults.tlpcTest &&
        componentTestResults.capacitorTest &&
        componentTestResults.boardTest &&
        componentTestResults.softStartTest &&
        componentTestResults.bypassContactorTest &&
        componentTestResults.electronicOverloadTest &&
        componentTestResults.shortCircuitTest &&
        componentTestResults.leakageTest &&
        componentTestResults.gateDriverTest &&
        componentTestResults.desaturationTest &&
        componentTestResults.thermalTest &&
        componentTestResults.parallelTest &&
        componentTestResults.igbtSelectionTest) {
        systemStatus.selfTestPassed = 1;
        componentTestResults.selfTestComplete = 1;
void TestIGBTProtection(void) {
    // Test IGBT protection circuits
    static unsigned int testCounter = 0;
    componentTestResults.igbtTest = 0;
    // Test overcurrent protection
    if (adcValues[3] > 950) {
        systemStatus.faultCode = ERROR_IGBT_OVERCURRENT;
        return;
    // Test overtemperature protection
    if (systemStatus.igbtTemperature > 850) {
        systemStatus.faultCode = ERROR_IGBT_OVERTEMP;
        return;
    if (adcValues[3] > 900 && adcValues[2] < 200) {
        systemStatus.faultCode = ERROR_IGBT_SHORT_CIRCUIT;
        return;
    // Test dead time configuration
    if (systemStatus.deadTime < DEADTIME_MIN || systemStatus.deadTime > DEADTIME_MAX) {
        systemStatus.faultCode = ERROR_SELF_TEST_FAILED;
        return;
    // Simulate IGBT gate signals and verify proper sequencing
    LATBbits.LATB5 = 1;  // Turn on high-side IGBT
    __delay32(FCY/10000);  // 0.1ms delay
    LATBbits.LATB4 = 0;  // Turn off low-side IGBT
    // Verify complementary operation with dead time
    if (LATBbits.LATB5 == 1 && LATBbits.LATB4 == 1) {
        // Both IGBTs on simultaneously - shoot-through condition
        return;
    // Test passed
    componentTestResults.igbtTest = 1;
void TestTLPCCommunication(void) {
    // Test TLPC (Temperature, Level, Pressure, Current) communication
    componentTestResults.tlpcTest = 0;
    // Check I2C communication with TLPC sensor
    if (!I2CSTATbits.S) {
        // Start condition not detected
        systemStatus.faultCode = ERROR_TLPC_COMMUNICATION;
        return;
    // Send test command to TLPC
    I2CTRN = 0x01;  // Test command
    while(!IFS1bits.MI2C1IF);  // Wait for transmission
    // Check for ACK
    if (I2CSTATbits.ACKSTAT) {
        // No ACK received
        systemStatus.faultCode = ERROR_TLPC_TIMEOUT;
        return;
    // Read response
    I2CCONbits.RCEN = 1;  // Enable receive
    while(!IFS1bits.MI2C1IF);  // Wait for receive
    unsigned char response = I2CRCV;
    // Verify response
    if (response != 0x01) {
        return;
    // Test passed
    componentTestResults.tlpcTest = 1;
    systemStatus.tlpcStatus = 1;
void TestCapacitorHealth(void) {
    // Test capacitor health and protection
    componentTestResults.capacitorTest = 0;
    // Test overvoltage protection
    if (systemStatus.capacitorVoltage > 800) {
        systemStatus.faultCode = ERROR_CAPACITOR_OVERVOLTAGE;
        return;
    // For now, verify capacitor voltage is within range
    if (adcValues[4] > 750) {
        return;
    // Test passed
    componentTestResults.capacitorTest = 1;
void TestBoardComponents(void) {
    // Test all board components
    componentTestResults.boardTest = 0;
    // Test PV input
    if (adcValues[0] > 1300 || adcValues[0] < 50) {
        systemStatus.faultCode = ERROR_PV_OVERVOLTAGE;
        return;
    // Test output voltage
    if (adcValues[2] > 800 || adcValues[2] < 100) {
        systemStatus.faultCode = ERROR_OUTPUT_OVERVOLTAGE;
        return;
    // Test temperature sensors
    if (adcValues[5] > 900 || adcValues[5] < 10) {
        systemStatus.faultCode = ERROR_BOARD_OVERTEMP;
        return;
    // Test button inputs
    if (PORTBbits.RB0 == 1 && PORTBbits.RB1 == 1) {
        // Buttons are working
        // One or both buttons stuck
        return;
    // Test beeper
    LATBbits.LATB6 = 1;
    LATBbits.LATB6 = 0;
    // Test passed
    componentTestResults.boardTest = 1;
void TestSoftStartFunction(void) {
    // Test soft start functionality
    componentTestResults.softStartTest = 0;
    // Test soft start parameters
    if (SOFT_START_DURATION < 2000 || SOFT_START_DURATION > 15000) {
        systemStatus.faultCode = ERROR_SOFT_START_TIMEOUT;
        return;
    // Test soft start control logic
    systemStatus.softStartState = SOFT_START_RAMP_UP;
    // Simulate soft start
    for (int i = 0; i < SOFT_START_STEPS; i++) {
        SoftStartControl();
        __delay32(FCY/100);  // 10ms delay
    // Check if soft start completed
    if (systemStatus.softStartState != SOFT_START_BYPASS) {
        return;
    // Test passed
    componentTestResults.softStartTest = 1;
void TestBypassContactor(void) {
    // Test bypass contactor functionality
    componentTestResults.bypassContactorTest = 0;
    // Test bypass contactor control
    LATBbits.LATB7 = 1;  // Activate bypass contactor
    // Check if bypass contactor activated
    if (!LATBbits.LATB7) {
        systemStatus.faultCode = ERROR_BYPASS_CONTACTOR;
        return;
    // Test bypass contactor deactivation
    LATBbits.LATB7 = 0;  // Deactivate bypass contactor
    // Check if bypass contactor deactivated
    if (LATBbits.LATB7) {
        return;
    // Test passed
    componentTestResults.bypassContactorTest = 1;
    systemStatus.bypassContactorStatus = 1;
void TestElectronicOverload(void) {
    componentTestResults.electronicOverloadTest = 0;
    // Test overload protection
    systemStatus.electronicOverloadCounter = 0;
    // Simulate overload condition
    adcValues[3] = 1000;  // High current
    // Run overload protection
    // Check if overload protection activated
    if (systemStatus.electronicOverloadCounter == 0) {
        systemStatus.faultCode = ERROR_ELECTRONIC_OVERLOAD;
        return;
    // Test passed
    componentTestResults.electronicOverloadTest = 1;
void TestShortCircuitDetection(void) {
    componentTestResults.shortCircuitTest = 0;
    // Test hardware fault detection
    if (PORTBbits.RB12 == 0) {  // FLTA pin low
        systemStatus.faultCode = ERROR_SHORT_CIRCUIT;
        return;
    // Test software short circuit detection
    if (adcValues[3] > 900) {
        return;
    // Test passed
    componentTestResults.shortCircuitTest = 1;
void TestLeakageDetection(void) {
    // Test leakage current detection
    componentTestResults.leakageTest = 0;
    // Test leakage current threshold
    if (adcValues[5] > 3) {
        systemStatus.faultCode = ERROR_CURRENT_LEAKAGE;
        return;
    // Test passed
    componentTestResults.leakageTest = 1;
void TestGateDriver(void) {
    // Test TLP250 gate driver functionality
    componentTestResults.gateDriverTest = 0;
    // Test gate driver fault detection
    if (PORTBbits.RB13 == 0) {  // Gate driver fault pin low
        systemStatus.faultCode = ERROR_GATE_DRIVER;
        return;
    // Test gate driver output
    LATBbits.LATB5 = 1;  // Send PWM signal
    LATBbits.LATB5 = 0;
    // Test passed
    componentTestResults.gateDriverTest = 1;
    systemStatus.gateDriverStatus = 1;
void TestDesaturationDetection(void) {
    // Test IGBT desaturation detection
    componentTestResults.desaturationTest = 0;
    // Test desaturation detection circuit
    if (PORTBbits.RB14 == 1) {  // Desaturation detected
        systemStatus.faultCode = ERROR_IGBT_DESATURATION;
        return;
    // Test passed
    componentTestResults.desaturationTest = 1;
void TestThermalProtection(void) {
    componentTestResults.thermalTest = 0;
    // Test temperature threshold
    if (systemStatus.igbtTemperature > 850) {  // ~85°C
        systemStatus.faultCode = ERROR_THERMAL_RUNAWAY;
        return;
    // Test passed
    componentTestResults.thermalTest = 1;
void TestParallelOperation(void) {
    // Test parallel operation functionality
    componentTestResults.parallelTest = 0;
    // Test parallel sync pin
    if (systemStatus.systemConfig.isParallel) {
        // Test master/slave communication
        if (systemStatus.systemConfig.masterSlave == 0) {
            // Master should output sync signal
            LATBbits.LATB11 = 1;
            LATBbits.LATB11 = 0;
            // Slave should receive sync signal
            if (PORTBbits.RB10 == 1) {
                systemStatus.parallelSyncCounter++;
    // Test passed
    componentTestResults.parallelTest = 1;
void TestIGBTSelection(void) {
    // Test IGBT selection and compatibility
    componentTestResults.igbtSelectionTest = 0;
    // Get current IGBT model
    IGBT_Model model = systemStatus.systemConfig.igbtModel;
    // Validate IGBT selection based on power rating
    if (igbtDatabase[model].recommendedKW == 0) {
        // This IGBT is not recommended for solar applications
        systemStatus.faultCode = ERROR_IGBT_SUITABILITY;
        return;
    // Check if IGBT voltage rating is sufficient
    if (igbtDatabase[model].vces < 600) {
        systemStatus.faultCode = ERROR_IGBT_VOLTAGE;
        return;
    // Check if IGBT current rating is sufficient
    unsigned int minCurrent = (systemStatus.systemConfig.powerRating * 1000) / 230;  // A = W/V
    if (igbtDatabase[model].ic < minCurrent) {
        systemStatus.faultCode = ERROR_IGBT_CURRENT;
        return;
    // Check package type
    if (strcmp(igbtDatabase[model].package, "Module") == 0) {
        // Module packages are preferred for high power applications
        systemStatus.igbtHealth = 100;  // Excellent health rating
        // TO-247 or TO-264 packages
        systemStatus.igbtHealth = 75;  // Good health rating
    // Test passed
    componentTestResults.igbtSelectionTest = 1;
void __attribute__((__interrupt__, auto_psv)) _ADCInterrupt(void) {
    // Read ADC values as per dsPIC30F2010 ADC specifications
    // ADCBUF0: MUXA result (output current)
    // ADCBUF1: MUXB result (leakage current)
    adcValues[3] = ADCBUF0;         // Output current
    adcValues[5] = ADCBUF1;         // Leakage current
    // Update system status
    systemStatus.outputCurrent = adcValues[3];
    systemStatus.leakageCurrent = adcValues[5];
    IFS0bits.ADIF = 0;
void __attribute__((__interrupt__, auto_psv)) _T1Interrupt(void) {
    // 1ms system tick
    gridPhase++;
    if (gridPhase >= SINE_SAMPLES) {
        gridPhase = 0;              // Reset phase counter for 50Hz output
    // Menu timeout counter
    if (systemStatus.menuActive) {
        systemStatus.menuTimer++;
        if (systemStatus.menuTimer >= MENU_TIMEOUT * 1000) {  // 10 seconds
            systemStatus.menuActive = 0;
            systemStatus.menuTimer = 0;
            GenerateBeep(100);  // Confirmation beep
    // Beeper control
    if (systemStatus.beepActive) {
        static unsigned int beepCounter = 0;
        beepCounter++;
        if (beepCounter >= 500) {  // 500ms
            LATBbits.LATB6 = 0;    // Turn off beeper
            systemStatus.beepActive = 0;
            beepCounter = 0;
    // Increment runtime
    static unsigned int runtimeCounter = 0;
    runtimeCounter++;
    if (runtimeCounter >= 1000) {  // 1 second
        systemStatus.runtimeHours++;
        runtimeCounter = 0;
    // Increment soft start counter
    if (systemStatus.softStartState != SOFT_START_IDLE) {
        systemStatus.softStartCounter++;
    // Increment protection timer
    if (systemStatus.protectionTimer > 0) {
        systemStatus.protectionTimer++;
        if (systemStatus.protectionTimer >= 180 * 1000) {  // 180 seconds
            systemStatus.protectionTimer = 0;
    // Increment leakage counter
    leakageCounter++;
    if (leakageCounter >= 100) {  // Sample every 100ms
        // Trigger ADC sampling for leakage current
        ADCON1bits.SAMP = 1;
        leakageCounter = 0;
    // Increment parallel sync counter
        if (systemStatus.parallelSyncCounter >= 1000) {  // 1 second
    IFS0bits.T1IF = 0;
void __attribute__((__interrupt__, auto_psv)) _U1RXInterrupt(void) {
    // UART receive interrupt
    char receivedChar = U1RXREG;
    // Process received command
    switch(receivedChar) {
        case 'S': // Status request
            // Send system status
        case 'F': // Fault history request
            // Send fault history
        case 'M': // Mode change
            systemStatus.modMode = (systemStatus.modMode + 1) % 3;
        case 'C': // Carrier frequency toggle
            systemStatus.carrierFreq = (systemStatus.carrierFreq == PWM_FREQ_7K) ?
                                      PWM_FREQ_14K : PWM_FREQ_7K;
        case 'T': // Trigger soft start
            if (systemStatus.protectionTimer == 0) {
        case 'L': // Leakage status
                char buffer[50];
                sprintf(buffer, "Leakage: %d mA\r\n", systemStatus.leakageCurrent * 10);
                // Send via UART
                for(int i = 0; buffer[i] != '\0'; i++) {
                    while(U1STAbits.UTXBF);
                    U1TXREG = buffer[i];
        case 'P': // Power rating configuration
            // Example: 'P15' for 15KW system
        case 'R': // Parallel operation
            systemStatus.systemConfig.isParallel = !systemStatus.systemConfig.isParallel;
        case 'I': // IGBT information
            DisplayIGBTInfo();
        case 'E': // Save configuration
            SaveConfiguration();
        case 'D': // Load configuration
    IFS0bits.U1RXIF = 0;  // Clear interrupt flag
void __attribute__((__interrupt__, auto_psv)) _MI2C1Interrupt(void) {
    // I2C master interrupt
    IFS1bits.MI2C1IF = 0;  // Clear interrupt flag
void __attribute__((__interrupt__, auto_psv)) _FLTAInterrupt(void) {
    // Hardware fault interrupt (short circuit detection)
    systemStatus.faultTimestamp = systemStatus.runtimeHours;
    // Log fault
    LogFault(ERROR_SHORT_CIRCUIT, systemStatus.runtimeHours);
    // Shutdown system
    SystemShutdown();
    IFS3bits.FLTAIF = 0;
void MPPT_Algorithm(void) {
    // Enhanced Perturb and Observe MPPT algorithm
    static unsigned int prevPower = 0;
    static unsigned int prevVmpp = 0;
    static int perturbDirection = 1; // +1 or -1
    // Check for manual VMPP setting
    if (systemStatus.vmppManual > 0) {
        vmpp = systemStatus.vmppManual;
        return;
    // Calculate current power
    unsigned int currentPower = adcValues[0] * adcValues[1];
    // Implement enhanced Perturb & Observe algorithm
    if (adcValues[0] < 100) {       // Low PV voltage detection
        vmpp = adcValues[0] * 0.8;  // Operate at 80% of available voltage
        if (currentPower > prevPower) {
            vmpp += perturbDirection;
            perturbDirection = -perturbDirection;
    // Store previous values
    prevPower = currentPower;
    prevVmpp = vmpp;
    // Limit Vmpp to valid range (75-800V)
    if (vmpp < 150) vmpp = 150;
    if (vmpp > 1600) vmpp = 1600;
void GridSynchronization(void) {
    // Enhanced grid synchronization
    static unsigned int prevGridVoltage = 512;
    static int phaseAdjustment = 0;
    int voltageError = adcValues[2] - 512;  // Error from target (230V)
    // Proportional-Integral control for smooth regulation
    phaseAdjustment += voltageError / 10;
    if (phaseAdjustment > 5) phaseAdjustment = 5;
    if (phaseAdjustment < -5) phaseAdjustment = -5;
    // Prevent zero-crossing jitter
    if (adcValues[2] > 500 && prevGridVoltage <= 500) {
        gridPhase = 0;  // Positive zero crossing
    } else if (adcValues[2] < 500 && prevGridVoltage >= 500) {
        gridPhase = SINE_SAMPLES/2; // Negative zero crossing
        gridPhase += phaseAdjustment;
    // Anti-islanding protection
    if (adcValues[2] < 180 || adcValues[2] > 280) {
        systemStatus.faultCode = ERROR_ANTI_ISLANDING;
        LogFault(ERROR_ANTI_ISLANDING, systemStatus.runtimeHours);
        SystemShutdown();
    // Keep phase within bounds
    if (gridPhase >= SINE_SAMPLES) gridPhase = 0;
    if (gridPhase < 0) gridPhase = SINE_SAMPLES - 1;
    prevGridVoltage = adcValues[2];
void FaultProtection(void) {
    // Comprehensive fault protection system
    // IGBT overcurrent protection
        SystemShutdown();
        faultHistory[faultIndex].faultCode = systemStatus.faultCode;
        faultIndex = (faultIndex + 1) % FAULT_HISTORY_SIZE;
        while(1);
    // IGBT overtemperature protection
        SystemShutdown();
        while(1);
    // IGBT short circuit protection
        SystemShutdown();
        while(1);
    // TLPC communication failure
    if (systemStatus.tlpcStatus == 0) {
        SystemShutdown();
        while(1);
    // Capacitor overvoltage protection
        SystemShutdown();
        while(1);
    // Board overtemperature protection
    if (systemStatus.temperature > 850) {
        SystemShutdown();
        while(1);
    // PV overvoltage protection
    if (adcValues[0] > 1300) {
        SystemShutdown();
        while(1);
    // Output overvoltage protection
    if (adcValues[2] > 800) {
        SystemShutdown();
        while(1);
    // Output undervoltage protection
    if (adcValues[2] < MIN_OUTPUT_VOLTAGE) {
        SystemShutdown();
        systemStatus.faultCode = ERROR_OUTPUT_UNDERVOLTAGE;
        while(1);
    // Overload protection
        SystemShutdown();
        systemStatus.faultCode = ERROR_OVERLOAD;
        while(1);
    // Inrush current protection
    if (adcValues[3] > 1000 && systemStatus.softStartCounter < 20) {
        SystemShutdown();
        systemStatus.faultCode = ERROR_INRUSH_CURRENT;
        while(1);
    // Surge current protection
    if (adcValues[3] > 800 && systemStatus.softStartCounter < 350) {
        SystemShutdown();
        systemStatus.faultCode = ERROR_SURGE_CURRENT;
        while(1);
    // Voltage drop protection
    if (adcValues[2] < 400 && adcValues[3] > 800) {
        SystemShutdown();
        systemStatus.faultCode = ERROR_VOLTAGE_DROP;
        while(1);
    // Mechanical stress protection
    if (adcValues[3] > 900 && adcValues[2] > 700) {
        SystemShutdown();
        systemStatus.faultCode = ERROR_MECHANICAL_STRESS;
        while(1);
    // Power rating protection
    if (systemStatus.systemConfig.powerRating < 1 || systemStatus.systemConfig.powerRating > 30) {
        SystemShutdown();
        systemStatus.faultCode = ERROR_POWER_RATING;
        while(1);
    // IGBT suitability protection
    if (igbtDatabase[systemStatus.systemConfig.igbtModel].recommendedKW == 0) {
        SystemShutdown();
        while(1);
void HandleAudioAlerts(void) {
    // Audio alerts for fault conditions
    if (systemStatus.faultCode != ERROR_NONE) {
        if (!systemStatus.beepActive) {
            GenerateBeep(200);  // Warning beep
            systemStatus.beepActive = 1;
void GenerateBeep(unsigned int duration) {
    // Generate beep on RB6
    LATBbits.LATB6 = 1;  // Beeper on
    __delay32(FCY * duration / 1000);
void DisplayErrorMessage(ErrorCode error) {
    // Display error message based on error code
    switch(error) {
        case ERROR_IGBT_OVERCURRENT:
            GenerateBeep(500);
            // Display "IGBT Overcurrent" on display
        case ERROR_IGBT_OVERTEMP:
            GenerateBeep(500);
            // Display "IGBT Overtemperature" on display
        case ERROR_IGBT_SHORT_CIRCUIT:
            GenerateBeep(500);
            // Display "IGBT Short Circuit" on display
        case ERROR_TLPC_COMMUNICATION:
            GenerateBeep(500);
            // Display "TLPC Communication Error" on display
        case ERROR_TLPC_TIMEOUT:
            GenerateBeep(500);
            // Display "TLPC Timeout" on display
        case ERROR_CAPACITOR_OVERVOLTAGE:
            GenerateBeep(500);
            // Display "Capacitor Overvoltage" on display
        case ERROR_CAPACITOR_LEAKAGE:
            GenerateBeep(500);
            // Display "Capacitor Leakage" on display
        case ERROR_BOARD_OVERTEMP:
            GenerateBeep(500);
            // Display "Board Overtemperature" on display
        case ERROR_PV_OVERVOLTAGE:
            GenerateBeep(500);
            // Display "PV Overvoltage" on display
        case ERROR_OUTPUT_OVERVOLTAGE:
            GenerateBeep(500);
            // Display "Output Overvoltage" on display
        case ERROR_OUTPUT_UNDERVOLTAGE:
            GenerateBeep(500);
            // Display "Output Undervoltage" on display
        case ERROR_OVERLOAD:
            GenerateBeep(500);
            // Display "Overload" on display
        case ERROR_SELF_TEST_FAILED:
            GenerateBeep(500);
            // Display "Self-Test Failed" on display
        case ERROR_SOFT_START_TIMEOUT:
            GenerateBeep(500);
            // Display "Soft Start Timeout" on display
        case ERROR_OVER_CURRENT:
            GenerateBeep(500);
            // Display "Over Current" on display
        case ERROR_INRUSH_CURRENT:
            GenerateBeep(500);
            // Display "Inrush Current" on display
        case ERROR_SURGE_CURRENT:
            GenerateBeep(500);
            // Display "Surge Current" on display
        case ERROR_BYPASS_CONTACTOR:
            GenerateBeep(500);
            // Display "Bypass Contactor Fault" on display
        case ERROR_ELECTRONIC_OVERLOAD:
            GenerateBeep(500);
            // Display "Electronic Overload" on display
        case ERROR_VOLTAGE_DROP:
            GenerateBeep(500);
            // Display "Voltage Drop" on display
        case ERROR_MECHANICAL_STRESS:
            GenerateBeep(500);
            // Display "Mechanical Stress" on display
        case ERROR_SHORT_CIRCUIT:
            GenerateBeep(500);
            // Display "Short Circuit" on display
        case ERROR_CURRENT_LEAKAGE:
            GenerateBeep(500);
            // Display "Current Leakage" on display
        case ERROR_ANTI_ISLANDING:
            GenerateBeep(500);
            // Display "Anti-Islanding" on display
        case ERROR_GATE_DRIVER:
            GenerateBeep(500);
            // Display "Gate Driver Fault" on display
        case ERROR_IGBT_DESATURATION:
            GenerateBeep(500);
            // Display "IGBT Desaturation" on display
        case ERROR_IGBT_SWITCHING:
            GenerateBeep(500);
            // Display "IGBT Switching Error" on display
        case ERROR_THERMAL_RUNAWAY:
            GenerateBeep(500);
            // Display "Thermal Runaway" on display
        case ERROR_POWER_RATING:
            GenerateBeep(500);
            // Display "Power Rating Error" on display
        case ERROR_SYSTEM_CONFIG:
            GenerateBeep(500);
            // Display "System Config Error" on display
        case ERROR_PARALLEL_OPERATION:
            GenerateBeep(500);
            // Display "Parallel Operation Error" on display
        case ERROR_IGBT_SUITABILITY:
            GenerateBeep(500);
            // Display "IGBT Suitability Error" on display
        case ERROR_IGBT_SELECTION:
            GenerateBeep(500);
            // Display "IGBT Selection Error" on display
        case ERROR_IGBT_PACKAGE:
            GenerateBeep(500);
            // Display "IGBT Package Error" on display
        case ERROR_IGBT_VOLTAGE:
            GenerateBeep(500);
            // Display "IGBT Voltage Rating Error" on display
        case ERROR_IGBT_CURRENT:
            GenerateBeep(500);
            // Display "IGBT Current Rating Error" on display
        default:
            GenerateBeep(100);
            // Display "Unknown Error" on display
void SystemShutdown(void) {
    // Safe shutdown procedure
    PTCONbits.PTEN = 0;         // Disable PWM
    systemStatus.softStartState = SOFT_START_FAULT;
    systemStatus.protectionTimer = 1;  // Start protection timer
    // Reset after 1 second
    __delay32(FCY);  // 1 second delay
    asm("reset");    // Soft reset
void SoftStartControl(void) {
    // Soft start control for heavy loads
    switch (systemStatus.softStartState) {
        case SOFT_START_IDLE:
            // Wait for start command
            PDC1 = 0;
            PDC2 = 0;
        case SOFT_START_RAMP_UP:
            // Gradually increase output voltage
            if (systemStatus.softStartCounter >= systemStatus.systemConfig.softStart) {
                // Ramp up complete
                systemStatus.softStartState = SOFT_START_BYPASS;
                systemStatus.softStartCycles++;
                // Calculate ramp factor (0-100%)
                unsigned int rampFactor = (systemStatus.softStartCounter * 100) / systemStatus.systemConfig.softStart;
                // Apply to PWM duty cycle
                int32_t pdc_val = (ptper/2) * rampFactor / 100;
                // Apply limits
                if (pdc_val < 10) pdc_val = 10;
                if (pdc_val > (int32_t)ptper/2) pdc_val = (int32_t)ptper/2;
                // Update PWM
                PDC1 = (uint16_t)pdc_val;
                PDC2 = (uint16_t)pdc_val;
        case SOFT_START_BYPASS:
            // Full power with bypass contactor
            PDC1 = ptper/2;
            PDC2 = ptper/2;
        case SOFT_START_FAULT:
            // Fault state - wait for reset
            PDC1 = 0;
            PDC2 = 0;
            LATBbits.LATB7 = 0;
void BypassContactorControl(void) {
    // Control bypass contactor to reduce heat generation
    if (systemStatus.softStartState == SOFT_START_BYPASS) {
void ElectronicOverloadProtection(void) {
    // Built-in electronic overload protective relay
    static unsigned int overloadCounter = 0;
    // Check for overload condition based on IGBT rating
    unsigned int maxCurrent = igbtDatabase[model].ic;
    unsigned int threshold = (maxCurrent * 1270) / 100;  // 127% of max current
    // Convert to ADC value (assuming 1mΩ shunt, 100x amplifier)
    unsigned int adcThreshold = (threshold * 950) / maxCurrent;
    if (adcValues[3] > adcThreshold) {
        overloadCounter++;
        if (overloadCounter >= 60000) {  // 60 seconds
            SystemShutdown();
    systemStatus.electronicOverloadCounter = overloadCounter;
void TorqueControl(void) {
    // Control torque for smoother starts and stops
    static int32_t targetPDC = 0;
    static int32_t currentPDC = 0;
    // Calculate target torque based on load
    int32_t torqueFactor = (int32_t)adcValues[3] * 100 / 950;  // 0-100%
    // Limit torque during start-up
    if (systemStatus.softStartState == SOFT_START_RAMP_UP) {
        torqueFactor = torqueFactor * systemStatus.softStartCounter / systemStatus.systemConfig.softStart;
    // Calculate target PDC
    targetPDC = (ptper/2) * torqueFactor / 100;
    // Apply smooth transition
    if (currentPDC < targetPDC) {
        currentPDC += 10;  // Accelerate
    } else if (currentPDC > targetPDC) {
        currentPDC -= 10;  // Decelerate
    // Apply limits
    if (currentPDC < 10) currentPDC = 10;
    if (currentPDC > (int32_t)ptper/2) currentPDC = (int32_t)ptper/2;
    // Update PWM if not in soft start
    if (systemStatus.softStartState != SOFT_START_RAMP_UP) {
        PDC1 = (uint16_t)currentPDC;
        PDC2 = (uint16_t)currentPDC;
void VibrationReduction(void) {
    // Reduce vibration and mechanical damage
    static unsigned int vibrationCounter = 0;
    static unsigned int prevCurrent = 0;
    unsigned int current = adcValues[3];
    unsigned int currentChange = (current > prevCurrent) ? current - prevCurrent : prevCurrent - current;
    // Detect rapid current changes (vibration)
    if (currentChange > 200) {
        vibrationCounter++;
        if (vibrationCounter > 10) {
            // Apply damping
            PDC1 = PDC1 * 90 / 100;  // Reduce power by 10%
            PDC2 = PDC2 * 90 / 100;
    prevCurrent = current;
void MechanicalStressRelief(void) {
    // Relieve shock and drive train stress on startup
        // Apply controlled acceleration
        unsigned int rampTime = systemStatus.softStartCounter;
        unsigned int totalRampTime = systemStatus.systemConfig.softStart;
        // Use S-curve acceleration profile
        // This reduces mechanical stress at start and end of acceleration
        if (rampTime < totalRampTime/2) {
            // First half: quadratic acceleration
            unsigned int factor = (rampTime * rampTime * 100) / (totalRampTime * totalRampTime/4);
            if (factor > 50) factor = 50;
            PDC1 = (ptper/2) * factor / 100;
            PDC2 = (ptper/2) * factor / 100;
            // Second half: linear deceleration of acceleration
            unsigned int factor = 50 + ((rampTime - totalRampTime/2) * 50) / (totalRampTime/2);
void UpdateOperationHours(void) {
    // Update operation hours (better than 45,000 hours)
    static unsigned int hourCounter = 0;
    hourCounter++;
    if (hourCounter >= 3600000) {  // 1 hour
        systemStatus.operationHours++;
        hourCounter = 0;
void DetectShortCircuit(void) {
    // Advanced short-circuit detection using both hardware and software methods
    // Hardware detection via FLTA pin (dsPIC30F2010 Section 14.10)
    // This provides the fastest response (<10µs)
    if (PORTBbits.RB12 == 0) {  // FLTA pin is active low
        // Log fault
        // Immediate shutdown
        SystemShutdown();
        return;
    // Software detection using ADC (secondary method)
    // Check if output current exceeds threshold
        // Verify with voltage reading (short circuit should have low voltage)
        if (adcValues[2] < 200) {  // Output voltage below 100V
            // Log fault
            // Shutdown system
            SystemShutdown();
void DetectLeakageCurrent(void) {
    // Current leakage detection using ADC channel AN5 (RB5)
    // Synchronized with PWM cycles for noise immunity
    // Check if leakage current exceeds threshold
        // Log fault
        LogFault(ERROR_CURRENT_LEAKAGE, systemStatus.runtimeHours);
        // Disable PWM outputs
        PTCONbits.PTEN = 0;
        // Activate beeper
        LATBbits.LATB6 = 1;
        // Shutdown system
        SystemShutdown();
void DetectDesaturation(void) {
    // IGBT desaturation detection using KGF75N65 and TLP250
    // Desaturation occurs when IGBT is commanded to turn on but collector-emitter voltage remains high
    // Check desaturation detection pin (RB14)
        systemStatus.igbtDesaturationCounter++;
        // If desaturation persists for more than short circuit withstand time
        if (systemStatus.igbtDesaturationCounter > igbtDatabase[model].shortCircuitWithstand) {
            // Log fault
            LogFault(ERROR_IGBT_DESATURATION, systemStatus.runtimeHours);
            SystemShutdown();
void DetectThermalRunaway(void) {
    // Thermal protection based on IGBT temperature
    // KGF75N65 has high temperature stable behavior
    // Check IGBT temperature
        systemStatus.thermalProtectionCounter++;
        // If high temperature persists
        if (systemStatus.thermalProtectionCounter > 1000) {  // 1 second
            // Log fault
            LogFault(ERROR_THERMAL_RUNAWAY, systemStatus.runtimeHours);
            // Shutdown system
            SystemShutdown();
void LogFault(uint16_t code, uint32_t timestamp) {
    // Log fault in circular buffer
    faultHistory[faultIndex].faultCode = code;
    faultHistory[faultIndex].timestamp = timestamp;
    faultHistory[faultIndex].adcValue = (code == ERROR_SHORT_CIRCUIT) ? adcValues[3] :
                                       (code == ERROR_CURRENT_LEAKAGE) ? adcValues[5] : 0;
    // Increment index with wrap-around
void ConfigureSystemPower(unsigned int kwRating) {
    // Configure system for specified power rating (1-30KW)
    if (kwRating >= 1 && kwRating <= 30) {
        systemStatus.systemConfig.powerRating = kwRating;
        // Set appropriate parameters based on power rating
        if (kwRating <= 5) {
            systemStatus.systemConfig.frequency = PWM_FREQ_14K;  // Higher frequency for smaller systems
            systemStatus.systemConfig.softStart = 3000;         // 3 seconds soft start
        } else if (kwRating <= 15) {
            systemStatus.systemConfig.softStart = 5000;         // 5 seconds soft start
            systemStatus.systemConfig.frequency = PWM_FREQ_7K;  // Lower frequency for larger systems
            systemStatus.systemConfig.softStart = 8000;         // 8 seconds soft start for larger loads
        // Update carrier frequency
        systemStatus.carrierFreq = systemStatus.systemConfig.frequency;
        // Reinitialize PWM with new parameters
        InitializePWM();
        SystemShutdown();
void HandleParallelOperation(void) {
    // Handle parallel operation for higher power systems
        // Master-slave synchronization
            // Master unit - generate sync signal
                LATBbits.LATB11 = 1;  // Send sync pulse
                __delay32(FCY/1000);  // 1ms pulse
            // Slave unit - synchronize to master
                // Sync pulse received - align phase
                gridPhase = 0;
void UpdateSystemEfficiency(void) {
    // Calculate and update system efficiency
    static unsigned long prevInputEnergy = 0;
    static unsigned long prevOutputEnergy = 0;
    static unsigned int efficiencyCounter = 0;
    efficiencyCounter++;
    if (efficiencyCounter >= 1000) {  // 1 second
        // Calculate energy in and out
        unsigned long inputEnergy = adcValues[0] * adcValues[1];  // PV power
        unsigned long outputEnergy = adcValues[2] * adcValues[3]; // Output power
        // Calculate efficiency
        if (inputEnergy > 0) {
            systemStatus.systemEfficiency = (outputEnergy * 100) / inputEnergy;
        // Limit to reasonable values
        if (systemStatus.systemEfficiency > 100) {
            systemStatus.systemEfficiency = 100;
        prevInputEnergy = inputEnergy;
        prevOutputEnergy = outputEnergy;
void SelectIGBTModel(IGBT_Model model) {
    // Select IGBT model for the system
    if (model >= 0 && model < 6) {
        systemStatus.systemConfig.igbtModel = model;
        // Validate the selection
void ValidateIGBTSelection(void) {
    // Validate IGBT selection based on system requirements
    // Check if IGBT is suitable for solar applications
        return;
    // Check if IGBT voltage rating is sufficient for system
        return;
    // Check if IGBT current rating is sufficient for system power
    unsigned int requiredCurrent = (systemStatus.systemConfig.powerRating * 1000) / 230;
    if (igbtDatabase[model].ic < requiredCurrent) {
        return;
    // Test passed
void CalculateIGBTLosses(void) {
    // Calculate IGBT switching and conduction losses
    static unsigned int lossCounter = 0;
    lossCounter++;
    if (lossCounter >= 1000) {  // 1 second
        // Calculate switching losses
        // Esw = switching energy * switching frequency
        systemStatus.igbtSwitchingLoss = (igbtDatabase[model].esw * systemStatus.carrierFreq) / 1000000;
        // Calculate conduction losses
        // Pcond = Vce(sat) * Ic * duty cycle
        unsigned int currentADC = adcValues[3];
        float current = (currentADC * 75.0) / 950.0;  // Convert ADC to amps
        systemStatus.igbtConductionLoss = (unsigned int)(igbtDatabase[model].vcesat * current);
        lossCounter = 0;
void DisplayIGBTInfo(void) {
    // Display IGBT information via UART
    char buffer[100];
    // Send IGBT model information
    sprintf(buffer, "IGBT Model: %s\r\n", igbtDatabase[model].model);
    // Send via UART
    sprintf(buffer, "Vces: %dV\r\n", igbtDatabase[model].vces);
    // Send via UART
    sprintf(buffer, "Ic: %dA\r\n", igbtDatabase[model].ic);
    // Send via UART
    sprintf(buffer, "Vce(sat): %.1fV\r\n", igbtDatabase[model].vcesat);
    // Send via UART
    sprintf(buffer, "Esw: %dµJ\r\n", igbtDatabase[model].esw);
    // Send via UART
    sprintf(buffer, "Package: %s\r\n", igbtDatabase[model].package);
    // Send via UART
    sprintf(buffer, "Has Diode: %s\r\n", igbtDatabase[model].hasDiode ? "Yes" : "No");
    // Send via UART
    sprintf(buffer, "Price: %d PKR\r\n", igbtDatabase[model].pricePKR);
    // Send via UART
    sprintf(buffer, "Suitability: %s\r\n", igbtDatabase[model].suitability);
    // Send via UART
void HandleMotorLoad(void) {
    static unsigned int motorLoadCounter = 0;
    // Detect sudden current increase (motor startup)
    if (current > prevCurrent + 200) {
        motorLoadCounter = 1000;  // 1 second motor load mode
    if (motorLoadCounter > 0) {
        motorLoadCounter--;
        // Adjust VMPP during motor load
        vmpp += 10;
        if (vmpp > 1300) vmpp = 1300;
void AdjustDeadTime(void) {
    // Adjustable dead time (1088-2000ns as per request)
    // dsPIC30F2010 datasheet specifies dead time resolution
    unsigned int dtValue = (systemStatus.deadTime - DEADTIME_MIN) / 16;
    if (dtValue > 57) dtValue = 57;  // Max 2000ns
    // Configure dead time for complementary PWM
    DTCON1bits.DTAPS = 0;            // 1:1 prescaler
    DTCON1bits.DTMPS = 0;            // Use PWM prescaler
    DTCON2 = dtValue;                // Dead time value
    // Enable dead time
    DTCON1bits.DTEN = 1;
void HandleMenuSystem(void) {
    // Two-button menu access
    static unsigned int button1State = 1;
    static unsigned int button2State = 1;
    static unsigned int button1Pressed = 0;
    static unsigned int button2Pressed = 0;
    unsigned int currentButton1 = PORTBbits.RB0;
    unsigned int currentButton2 = PORTBbits.RB1;
    // Detect button presses
    if (currentButton1 == 0 && button1State == 1) {
        button1Pressed = 1;
        systemStatus.lastButtonPress = 1;
    if (currentButton2 == 0 && button2State == 1) {
        button2Pressed = 1;
        systemStatus.lastButtonPress = 2;
    // Enter menu with both buttons
    if (button1Pressed && button2Pressed) {
        systemStatus.menuActive = !systemStatus.menuActive;
            GenerateBeep(100);  // Entry beep
            GenerateBeep(50);   // Exit beep
        button1Pressed = 0;
        button2Pressed = 0;
    // Menu navigation
        if (systemStatus.lastButtonPress == 1) {
            // Cycle through modulation modes
            GenerateBeep(50);
            __delay32(FCY);  // Debounce
        if (systemStatus.lastButtonPress == 2) {
            // Toggle carrier frequency between 14kHz and 7kHz
            GenerateBeep(50);
            __delay32(FCY);
        systemStatus.lastButtonPress = 0;
    button1State = currentButton1;
    button2State = currentButton2;
void CalibratePVCurrent(void) {
    static float calibratedPVCurrent = 0;
    static float alpha = 0.95;
    float rawCurrent = adcValues[1];
    float correctedCurrent = rawCurrent * 1.025;  // Calibration factor
    // Low-pass filter
    calibratedPVCurrent = alpha * calibratedPVCurrent + (1-alpha) * correctedCurrent;
    adcValues[1] = (unsigned int)calibratedPVCurrent;
void CalibrateOutputCurrent(void) {
    static float calibratedOutputCurrent = 0;
    float rawCurrent = adcValues[3];
    float correctedCurrent = rawCurrent * 0.985;  // Calibration factor
    // Low-pass filter
    calibratedOutputCurrent = alpha * calibratedOutputCurrent + (1-alpha) * correctedCurrent;
    adcValues[3] = (unsigned int)calibratedOutputCurrent;
void SaveConfiguration(void) {
    // Save system configuration to EEPROM
    unsigned int address = 0x7F0000;
    // Erase EEPROM location
    NVMCON = 0x4003;  // Word erase for data EEPROM
    NVMADRU = address >> 16;
    NVMADR = address & 0xFFFF;
    NVMKEY = 0x55;
    NVMKEY = 0xAA;
    NVMCONbits.WR = 1;
    // Wait for erase to complete
    while(NVMCONbits.WR);
    // Write configuration data
    NVMCON = 0x4001;  // Word program for data EEPROM
    // Write system configuration
    *((unsigned int*)address) = systemStatus.systemConfig.powerRating;
    address += 2;
    *((unsigned int*)address) = systemStatus.systemConfig.isParallel;
    address += 2;
    *((unsigned int*)address) = systemStatus.systemConfig.masterSlave;
    address += 2;
    *((unsigned int*)address) = systemStatus.systemConfig.frequency;
    address += 2;
    *((unsigned int*)address) = systemStatus.systemConfig.modulation;
    address += 2;
    *((unsigned int*)address) = systemStatus.systemConfig.softStart;
    address += 2;
    *((unsigned int*)address) = systemStatus.systemConfig.igbtModel;
    // Program the data
    NVMKEY = 0x55;
    NVMKEY = 0xAA;
    NVMCONbits.WR = 1;
    // Wait for write to complete
    // Generate beep to indicate save complete
    GenerateBeep(100);
void LoadConfiguration(void) {
    // Load system configuration from EEPROM
    // Read configuration data
    systemStatus.systemConfig.powerRating = *((unsigned int*)address);
    address += 2;
    systemStatus.systemConfig.isParallel = *((unsigned int*)address);
    address += 2;
    systemStatus.systemConfig.masterSlave = *((unsigned int*)address);
    address += 2;
    systemStatus.systemConfig.frequency = *((unsigned int*)address);
    address += 2;
    systemStatus.systemConfig.modulation = *((unsigned int*)address);
    address += 2;
    systemStatus.systemConfig.softStart = *((unsigned int*)address);
    address += 2;
    systemStatus.systemConfig.igbtModel = *((unsigned int*)address);
    // Validate loaded configuration
        systemStatus.systemConfig.powerRating = SYSTEM_POWER_RATING;
    if (systemStatus.systemConfig.igbtModel >= 6) {
        systemStatus.systemConfig.igbtModel = IGBT_KGF75N65;
void UpdateOutputWaveform(void) {
    // This function is now controlled by SoftStartControl
    // It's kept for backward compatibility
    if (systemStatus.softStartState == SOFT_START_IDLE ||
        systemStatus.softStartState == SOFT_START_FAULT) {
        PDC1 = 0;
        PDC2 = 0;
    // Otherwise, SoftStartControl handles the PWM updates
Thank You for telling us.
What is your question?
I think the guidance that @solve01 is looking for is this:
This is the Arduino forum. You have posted on the wrong forum by mistake. Your post does not relate to Arduino in any way.
If you do not respond, your post will be assumed to be spam and deleted by the moderators.
Sounds right. Back when I owned an inverter, I sure would not want the software to be created by anyone other than the team that created the inverter. They just happen to be the #1 maker of them for RV’s and boats, maybe more.
This file is not for dspic30f2010, and also incomplete, it don't have lcd driving file, can any one provide an corrected version.
