#include <DHT.h>
#define DHTPIN A0
#define MOTORPIN 9
#define MIN_TEMP 20
#define MAX_TEMP 30
#define MIN_SPEED 0
#define MAX_SPEED 255
DHT dht(DHTPIN, DHT11);
pinMode(MOTORPIN, OUTPUT);
dht.begin();
float temperature = dht.readTemperature();
int temp = map(temperature, 0, 1023, 0, 255);
if (temp >= MIN_TEMP && temp <= MAX_TEMP) {
int speed = map(temp, MIN_TEMP, MAX_TEMP, MIN_SPEED, MAX_SPEED);
analogWrite(MOTORPIN, speed);
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.print("C, Motor Speed: ");
Serial.println(speed);
analogWrite(MOTORPIN, 0);
Serial.println("C, Motor Speed: OFF");
When you see this, copy the code and paste it int a .txt file then save.
Open this text file, copy the code agin and paste it into a new .ino file.
Copy it back out, paste it over your existing sketch and compile.
That worked! Thanks very much. Can you tell me why the monitor would be reporting the temp and fan speed incorrectly, as such:
'18:13:50.253 -> Temperature: nanC, Motor Speed: -23592
18:13:51.271 -> Temperature: nanC, Motor Speed: -23592
18:13:52.320 -> Temperature: nanC, Motor Speed: -23592'
I did a schematic in TinkerCAD that looks like this, and have it wired exactly the same on a breadboard:
The fan spins at the same rate continuously, at present.
- Print the value of temp
Serial.println(temp);
What do you get ?
What is the range of temperature.
temperature is ’type’ float
Never power motors from your Arduino !
Use an external power supply.
Your sketch uses a DHT11, but your wiring diagram appears to show a TMP36 or something similar.
I'm always so reassured when the diagram shows one thing and the sketch shows another... I get that warm fuzzy feeling sinking sensation in my stomach.
I do hope you didn't take that hookup diagram as gospel. Blowing the dust off a DHT11 module I have here, Gnd and Vcc are reversed to that diagram.
Hooked up as I showed it, the DHT11 will short out because the diagram is wrong?
On the one I looked at here, Vcc and Gnd were reversed from that diagram. Perhaps yours isn't. Perhaps it is. If I were you, I'd check it.
Topic moved !! Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
Thanks for using code tags in your first post ![]()
Just make triple sure. Recently some largish amount of time was wasted and it turned out the inquirer was using a transistor instead of a DS18b20.
I don't know why they call a single component in a TO-92 package a module. And that one part can't be doing temperature and humidity.
a7
