Testing if the detail-formatting still works
a longer time ago I used this html-detail-thing for folding longer parts of postings
[details = detail title]
but it seems no longer to work
[/details]
There should be just the tittle and a triangle.
If you cklick on the triangle the detail-section becomes unfolded
it does not work:
is this some kind of option in my browser I can change or did the
Arduino-forum-maintenance disable it?
Or
am I doing something wrong in trying to use it?
title
ah I got it!
no space between the word detail and the equal-sign
Or you could use the "Hide Details" option available from the "gearwheel" icon when editing a message
Summary
This text will be hidden
The button gives you something to edit
[details="Summary"]
[/details]
But if you want, you can just enter the HTML:
I typed this…
… entire thing by hand just now.
IDK why it don't work for you.
[details = "detail title"]
[/details]
Works if you remove the spaces before and after the '=', go figure.
a7
Because I know @StefanL38 likes screenshots, and in case it will be of use to other users who aren't familiar with the post composer interface, I'll provide illustrated instructions:
  1. Click the :gear: icon on the post composer toolbar:
  2. A menu will open:
  3. Select "▸ Hide Details" from the menu:
The skeleton markup will be added to your post at the cursor location:
You can then change the title text and contents as needed.
I personally prefer this approach because, although it is available here on Arduino Forum, BBCode markup is not supported on other platforms (e.g., GitHub, Stack Exchange). I like to have a single standard approach to writing that I can use on any platform that supports Markdown.
I use this template:
<details>
  <summary><b><!-- TODO: title here --></b></summary>
  <p>
<!-- TODO: content here -->
  </p>
</details>
testing the template
lot's of text nothing shown after clicking the triangle ?
I guess this means more html-knowledge must be applied to make it work
self-explaining html-code
<details><summary>
<b> <type in titel here:> the letters that will be shown as title </b></summary>
<p>
<type in detail-content here> start of details that are shown / hidden when clicking on the triangle
  </p>
</details>
It is only a template. You must fill your content into the template.
I added HTML comment tags to document where you must fill in the content.
