Hi all,
I have a Waveshare ESP32-S3-Nano and a 1.69" 240x280 TFT IPS Display. When using the <Adafruit_GFX> and <Adafruit_ST7789> libraries, the display works fine, like running the "graphicstest" example. The wiring is as follows:
Disp - ESP32
GND - GND
VDD - 3V3
SCL - D13
SDA - D11
RES - RST
DC - D2
CS - D3
BLK - 3V3
D11, D12 and D13 are the hardware SPI pins according to the manufacturer. In the sketch I defined TFT_CS 3, TFT_RST -1 and TFT_DC 2 according to my wiring. As said, works like a charm.
Now, I'd like to run my display using @bodmer 's TFT_eSPI library. And here after hours of experimenting I still just get a dark display. Wiring is identical to the above. Steps I ve done are as follows:
- Using Ardunio IDE 2.3.2
- Installed TFT_eSPI 2.5.43 via the library manager
- In the file "User_Setup_Select.h":
- commented the default setup (//#include <User_Setup.h>)
- uncommented the to the best of my knowledge matching setup file (#include <User_Setups/Setup203_ST7789.h> // Setup file for ESP32/ESP8266 based ST7789 240X280 1.69inch TFT )
- In the file "Setup203_ST7789.h":
- uncommented "#define TFT_INVERSION_ON" - not that it would be relevant to my problem I assume
- under "Generic ESP32 setup" I uncommented and changed pin assignments as follows:
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCLK 13
#define TFT_CS 3
#define TFT_DC 2
#define TFT_RST -1
What beats me, in the original file it says chip select should not be connected?
//#define TFT_CS -1 // Not connected
Why would that be?
To finish my edits, under the next section "For NodeMCU" there are three uncommented lines for TFT_CS, TFT_DC and TFT_RST which I have commented out in order to avoid conflict with my definitions.
Then trying the example "TFT_eSPI" -> "Generic" -> "Gradient_Fill" I get nothing after upload, just a dark screen. Running the diagnostics "Read_User_Setup" sketch I get:
TFT_eSPI ver = 2.5.43
Processor = ESP32
Frequency = 240MHz
Transactions = Yes
Interface = SPI
Display driver = 9341
Display width = 240
Display height = 320
MOSI = GPIO 11
MISO = GPIO 12
SCK = GPIO 13
TFT_CS = GPIO 3
TFT_DC = GPIO 2
Font GLCD loaded
Font 2 loaded
Font 4 loaded
Font 6 loaded
Font 7 loaded
Font 8 loaded
Smooth font enabled
Display SPI frequency = 40.00
The pins match my setup so it must be reading my edited setup file correctly. But why is the display driver "9341"?
Thinking maybe me hooking up Chip Select in contrary to what was written in the setup file could be an issue: I went back, removed the CS wire phyiscally and in the setup file and moved the display RST wire to pin 3 on the ESP32. User setup readout now gives:
Processor = ESP32
Frequency = 240MHz
Transactions = Yes
Interface = SPI
Display width = 240
MOSI = GPIO 11
MISO = GPIO 12
SCK = GPIO 13
TFT_DC = GPIO 2
TFT_RST = GPIO 3
Font GLCD loaded
Font 2 loaded
Font 4 loaded
Font 6 loaded
Font 7 loaded
Font 8 loaded
Smooth font enabled
Uploading the "Gradient_Fill" sketch still gives a dark display.
There is one additional thing I've noticed, the diagnostic refers to the pins as "GPIO" whereas in the manufacturer pinout diagram I am using the numbers after "D", e.g. I am using 13 in my pin definitions for the SPI CLK, not D13 or even GPIO48. But I couldn't get it to work as well using the GPIO numbers from the manufacturer pinout diagram.
I am lost...
