TFT problem value flickering
Hi All!
Just started with the arduino :slight_smile:
Having some major problems with the variables->flickering.
Arduino UNO
MAX6675 Thermocouple
1.8 SPI TFT
In the proces of building a cargauge with:
EGT,AFR and boost read out.
This is my code so far based on the basic example:
"THE" question haw can i remove the flickering in the variables?
  Arduino TFT text example
  This example demonstrates how to draw text on the
  TFT with an Arduino. The Arduino reads the value
  of an analog sensor attached to pin A0, and writes
  the value to the LCD screen, updating every
  quarter second.
  This example code is in the public domain
  Created 15 April 2013 by Scott Fitzgerald
  http://arduino.cc/en/Tutorial/TFTDisplayText
#include <TFT.h>  // Arduino LCD library
#include <SPI.h>
#include "max6675.h"
// pin definition for the max6675
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
int vccPin = 3;
int gndPin = 2;
// pin definition for the Uno
#define cs   10
#define dc   9
#define rst  8
// pin definition for the Leonardo
// #define cs   7
// #define dc   0
// #define rst  1
// create an instance of the library
TFT TFTscreen = TFT(cs, dc, rst);
// char array to print to the screen
char sensorPrintout[4];
  // Put this line at the beginning of every sketch that uses the GLCD:
  TFTscreen.begin();
  // clear the screen with a black background
  TFTscreen.background(0, 0, 0);
  // write the static text to the screen
  // set the font color to white
  TFTscreen.stroke(255, 255, 255);
  // set the font size
  TFTscreen.setTextSize(2);
  // write the text to the top left corner of the screen
  TFTscreen.text("EGT :\n ", 0, 0);
  // ste the font size very large for the loop
  TFTscreen.setTextSize(3);
  TFTscreen.text("AFR :\n ", 0, 50);
  TFTscreen.text("Boost :\n ", 0, 100);
  //activate MAX7735
  Serial.begin(19200);
  // use Arduino pins
  pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
  pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
  Serial.println("MAX6675 test");
  // wait for MAX chip to stabilize
  Serial.print("C = ");
  Serial.println(thermocouple.readCelsius());
  delay(10);
  // Read the value of the sensor EGT
  String sensorVal = String(thermocouple.readCelsius());
  // convert the reading to a char array
  sensorVal.toCharArray(sensorPrintout, 4);
   // print the sensor value
  TFTscreen.text(sensorPrintout, 80, 0);
  // wait for a moment
  delay(100);
  // erase the text you just wrote
    TFTscreen.stroke(0, 0, 0);
  // Read the value of the sensor on AFR
  String sensorVal2 = String(analogRead(A0));
  sensorVal2.toCharArray(sensorPrintout, 4);
  TFTscreen.text(sensorPrintout, 80, 50);
  delay(100);
Gee, showing numbers for 1/10th of a second before clearing the screen and putting up the next.....
how could human eyes fail to follow that?
Why do you keep setting color the same? Isn't once enough?
thx for the reply.
However if I only set the font color once, the variable wont show...
THe variables never show up simultanious on the display its always just one:
Its a bit like on off;off on etc
You write one, wait 1/10th of a second, you clear the screen and write the next the next, repeat.
Try writing spaces over just the spots you want to write one number to then write the number instead of wiping everything out before you write any number.
