I'm hoping someone can shine some light on this one.
I’m using a Uno with a Waveshere 2.8" TFT shield to use as a alphanumeric keypad to both enter a code to enable access to another loop deeper in the code and then to enter some parameters.
It’s kind of working, the keypad renders quite well, maybe except for the chunky looking numbers but they are perfectly readable, however the key presses are very hit and miss, it often duplicates the previous keypress when I press the next key, so clearly, I’m missing something basic.
I appreciate this is quite a long unwieldly bit of code that is still very much work in progress, but I’ve tried to add some meaningful commenting and got rid of everything else that isn’t needed.
// keypad for entering a 4 digit access code
// using an Arduino Uno and Waveshere 2.8" touch screen
// the entred code is to be compared with a number stored in EEPROM (eventualy) and if matched will enter a different loop
// the keypad will then be used to enter a number for a process that will also be stored in EEPROM
// this code almost works, the rendered image on the scren is fine but keypresses are very hit and miss
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#include <SPI.h> // f.k. for Arduino-1.5.2
#include "Adafruit_GFX.h" // Hardware-specific library
#include <HX8347D_kbv.h> // display hardware library
#include <EEPROM.h> // EEPROM library
HX8347D_kbv tft; // not entirely sure what this is
#include <XPT2046_Touchscreen.h> // touch library
#define XPT_CS 4 // TFT chip sellect
#define XPT_IRQ 255 //use 3 if you fix interrupts in library source code
XPT2046_Touchscreen ts(XPT_CS, XPT_IRQ);
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#ifndef min //no idea what this is
#define min(a, b) (((a) < (b)) ? (a) : (b)) //no idea what this is
#endif //no idea what this is
unsigned long previousMillis = 0; // will store last time loop was updated
const long interval = 1000; // timed code loop interval)
const int ledPin = LED_BUILTIN; // the number of the LED pin
int ledState = LOW; // ledState used to set the LED (for debug only)
int codeTimeout = 0; // this will be a delay to do something if no keys are pressed
int EEPROMdigit0 = 0; // Eprom stored code digit 0
int EEPROMdigit1 = 0; // Eprom stored code digit 1
int EEPROMdigit2 = 0; // Eprom stored code digit 2
int EEPROMdigit3 = 0; // Eprom stored code digit 3
int EEPROMdigit4 = 0; // Eprom stored code digit 4
int EEPROMdigit5 = 0; // Eprom stored code digit 5
pinMode(ledPin, OUTPUT); //for debugging
Serial.begin(9600); //enable serial for debugging
tft.begin(); //Enable display
ts.begin(); //.kbv XPT2046_Touchscreen needs to start
tft.setRotation(2); //set screen to prtrait
//--------------- setup touch field -------------------------
int X_start = 360;
int X_finish = 3840;
int Y_start = 270;
int Y_finish = 3860;
keypad(); //jump straight into keypad loop
void loop() {//main operation loop
//untimed code
// currently empty
unsigned long currentMillis = millis(); //
if (currentMillis - previousMillis >= interval) { // code for non blocking loop
previousMillis = currentMillis; //
//timed code
// currently empty
void keypad() {
tft.fillScreen(BLACK); //clear screen
tft.drawRect(0, 0, 240, 320, WHITE); //outline frame of keypad
tft.drawRect(5, 5, 230, 40, WHITE); //frame for "user code" and display first 4 keys pressed
tft.setTextColor(WHITE); //write "user code" text into box
tft.setCursor(10, 15);
tft.setTextSize(2);
tft.println("User code:");
int codeArray[4] = {0, 0, 0, 0}; // this is where the first 4 key presses will be saved
int keyPosX = 5; //set left hand start point for left column of keys
int keySpaceX = 5; //set horizontal space between keys
int keyPosY = 48; //set the top most start point for the top row of keys
int keySpaceY = -5; //set vertical space between keys (currently not working prpperly for some reason)
int keyWidth = 73; //set width of keys
int keyHieght = 63; //set hight of keys
int colum1 = keyPosX; //human readable left start point for left column of keys
int colum2 = keyPosX + keySpaceX + keyWidth; //human readable left start point for second column of keys
int colum3 = keyPosX + (keySpaceX * 2) + (keyWidth * 2);//human readable left start point for third column of keys
int row1 = keyPosY; //human readable top start point for top row of keys
int row2 = keyPosY + keySpaceY + keyWidth; //human readable top start point for second row of keys
int row3 = keyPosY + (keySpaceY * 2) + (keyWidth * 2); //human readable top start point for third row of keys
int row4 = keyPosY + (keySpaceY * 3) + (keyWidth * 3); //human readable top start point for fourth row of keys
//================================== draw keys =========================================
//-----------------------------------key 1 -----------------------------------------
tft.drawRect(colum1, keyPosY, keyWidth, keyHieght, GREEN); //key 1 draw key
tft.setTextColor(GREEN);
tft.setCursor(keyPosX + 25, keyPosY + 15);
tft.setTextSize(5);
tft.println("1");
//-----------------------------------key 2 ----------------------------------------
tft.drawRect(colum2, keyPosY, keyWidth, keyHieght, GREEN); //key 2
tft.setCursor(colum2 + 25, keyPosY + 15);
tft.setTextSize(5);
tft.println("2");
//-----------------------------------key 3 -----------------------------------------
tft.drawRect(colum3, keyPosY, keyWidth, keyHieght, GREEN); //key 3
tft.setCursor(colum3 + 25, keyPosY + 15);
tft.setTextSize(5);
tft.println("3");
//-----------------------------------key 4 --------------------------------------
tft.drawRect(colum1, row2, keyWidth, keyHieght, GREEN); //key 4
tft.setCursor(colum1 + 25, row2 + 15);
tft.setTextSize(5);
tft.println("4");
//-----------------------------------key 5 ------------------------------------
tft.drawRect(colum2, row2, keyWidth, keyHieght, GREEN); //key 5
tft.setCursor(colum2 + 25, row2 + 15);
tft.setTextSize(5);
tft.println("5");
//-----------------------------------key 6 -----------------------------------
tft.drawRect(colum3, row2, keyWidth, keyHieght, GREEN); //key 6
tft.setCursor(colum3 + 25, row2 + 15);
tft.setTextSize(5);
tft.println("6");
//-----------------------------------key 7 ------------------------------------
tft.drawRect(colum1, row3, keyWidth, keyHieght, GREEN); //key 7
tft.setCursor(colum1 + 25, row3 + 15);
tft.setTextSize(5);
tft.println("7");
//-----------------------------------key 8 ----------------------------------
tft.drawRect(colum2, row3, keyWidth, keyHieght, GREEN); //key 8
tft.setCursor(colum2 + 25, row3 + 15);
tft.setTextSize(5);
tft.println("8");
//-----------------------------------key 9 --------------------------------
tft.drawRect(colum3, row3, keyWidth, keyHieght, GREEN); //key 9
tft.setCursor(colum3 + 25, row3 + 15);
tft.setTextSize(5);
tft.println("9");
//-----------------------------------key C -------------------------------
tft.drawRect(colum1, row4, keyWidth, keyHieght, GREEN); //key C
tft.setCursor(colum1 + 25, row4 + 15);
tft.setTextSize(5);
tft.println("C");
//-----------------------------------key 0 -------------------------------
tft.drawRect(colum2, row4, keyWidth, keyHieght, GREEN); //key 0
tft.setCursor(colum2 + 25, row4 + 15);
tft.setTextSize(5);
tft.println("0");
//-----------------------------------key E -------------------------------
tft.drawRect(colum3, row4, keyWidth, keyHieght, GREEN); //key E
tft.setCursor(colum3 + 25, row4 + 15);
tft.setTextSize(5);
tft.println("E");
//========================= key press ================================
int keypress = 55; //declare integer to store key pressed set at 55 so will only read if a valid number
// set human readable touch point limits for key detection
int pressCol1 = 336; // start of column 1
int presscol2 = 1420; //end of column 1 start of column 2
int presscol3 = 2660; //end of column 2 start of column 3
int presscol4 = 3740; //right most edge of column 3 keys
int pressrow1 = 950; // top start point of row 1
int pressrow2 = 1730; //bottom of row 1 top of row 2
int pressrow3 = 2440; //bottom of row 2 top of row 3
int pressrow4 = 3190; //bottom of row 3 start of row 4
int keypressIndex = 0; //array index number
tft.fillRect(130, 10, 75, 30, BLACK); // clear keypress displayed
//keypad key read loop
while (1) {
TS_Point p = ts.getPoint();
if (ts.touched()) {
//store pressed key number in 'keypress'
if (p.x > pressrow1 && p.x < pressrow2 && p.y < presscol2) keypress = 1;
if (p.x > pressrow1 && p.x < pressrow2 && p.y > presscol2 && p.y < presscol3) keypress = 2;
if (p.x > pressrow1 && p.x < pressrow2 && p.y > presscol3 && p.y < presscol4) keypress = 3;
if (p.x > pressrow2 && p.x < pressrow3 && p.y < presscol2) keypress = 4;
if (p.x > pressrow2 && p.x < pressrow3 && p.y > presscol2 && p.y < presscol3) keypress = 5;
if (p.x > pressrow2 && p.x < pressrow3 && p.y > presscol3 && p.y < presscol4) keypress = 6;
if (p.x > pressrow3 && p.x < pressrow4 && p.y < presscol2) keypress = 7;
if (p.x > pressrow3 && p.x < pressrow4 && p.y > presscol2 && p.y < presscol3) keypress = 8;
if (p.x > pressrow3 && p.x < pressrow4 && p.y > presscol3 && p.y < presscol4) keypress = 9;
if (p.x > pressrow4 && p.y > presscol2 && p.y < presscol3) keypress = 0;
// if (p.x > pressrow4 && p.y > presscol3 && p.y < presscol4) screenBuild(); //cancel key will return
// to main running loop
delay (100); //delay for stability, might not be required
//Serial.println(keypress); //serial print keypress for debugging
if (keypress != 55) codeArray[keypressIndex] = keypress;
//codeArray[keypressIndex] = keypress; //store keypress in array
//------------------------- clear code -----------------------------------------------
if (p.x > pressrow4 && p.y < presscol2) {// clear key
tft.fillRect(130, 10, 100, 30, BLACK); // clear keypress displayed;
keypressIndex = 0;
keypress = 55;
codeArray[0] = 0;
codeArray[1] = 0;
codeArray[2] = 0;
codeArray[3] = 0;
//----------------------------- display keypress ----------------------------------------------
//dipslays the 4 digit code on the screen
if (keypressIndex == 0) { //display first digit
tft.setCursor(130, 10);
tft.setTextSize(4);
tft.println(codeArray[0]);
if (keypressIndex == 1) { //display second digit
tft.setCursor(155, 10);
tft.setTextSize(4);
tft.println(codeArray[1]);
if (keypressIndex == 2) { // display third digit
tft.setCursor(180, 10);
tft.setTextSize(4);
tft.println(codeArray[2]);
if (keypressIndex == 3) { //display forth digit
tft.setCursor(205, 10);
tft.setTextSize(4);
tft.println(codeArray[3]);
keypressIndex++; //increment keypress index to store next key
if (codeArray[0] == 1 && codeArray[1] == 9 && codeArray[2] == 8 && codeArray[3] == 0) loop(); //temporary set code
//------------- the below serial printed for debugging purposes --------------------------------
// Serial.print("x= "); | serial print touch co-ordinates to set up key touch areas
// Serial.print(p.x); |
// Serial.print(" y="); |
// Serial.print(p.y); |
Serial.print(" codeArray "); // serial print first 4 numbers pressed
Serial.print(codeArray[0]); //
Serial.print(codeArray[1]); //
Serial.print(codeArray[2]); //
Serial.print(codeArray[3]); //
Serial.print(" keypress "); // serial print key pressed
Serial.print(keypress);
Serial.print(" keypressIndex "); // serial print index number
Serial.println(keypressIndex);
delay(300); // to prevent multiple presses
