Hey guys,
i have 2 Arduinos Mega (1 for the TFT touch screen and the second for Sensors).
The Code is too long thats why i used points.
without the funktion Werte() the TFT worked well.
The funktion Werte() worked also good but when i use it i couldnt use the touch again i mean the touch function doesnt work when i put Werte() funktion.
do you have any solutions guys?
thjis is the Code :
#include <UTFT.h>
#include <UTouch.h>
//==== Creating Objects
UTFT myGLCD(EHOUSE70,38,39,40,41);
UTouch myTouch( 6, 5, 4, 3, 2);
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
float sensor1 = 0;
char inChar;
int bg[] = {
0, 0, 255};
#define Relai 8
int fg[] = {
255, 255, 255};
int button1on = 0;
char currentPage, selectedUnit;
int waterhour = 16;//
int waterminute0 = 0;
int waterminute1 = 30;//
int waterminute2 = 46;
int watersecond = 0;
int waterONminute = 1;
// Initial setup
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
drawHomeScreen(); // Draws the Home Screen
currentPage = '0'; // Indicates that we are at Home Screen
selectedUnit = '0'; // Indicates the selected unit for the first example, cms or inches
pinMode(Relai, OUTPUT);
Serial1.begin(9600);
digitalWrite(Relai, HIGH);
// Home Screen
if (currentPage == '0') {
Werte();
if (myTouch.dataAvailable()) {
myTouch.read();
x=myTouch.getX();
y=myTouch.getY();
if ((x>=110) && (x<=410) && (y>=350) && (y<=450)) {
drawFrame(110, 350,410, 450);
currentPage = '1';
myGLCD.clrScr();
Systemeinstellung();
if (currentPage == '1') {
myTouch.read();
x=myTouch.getX();
y=myTouch.getY();//
if ((x>=10) && (x<=60) &&(y>=10) && (y<=36)) {
drawFrame(10, 10, 60, 36);
currentPage = '0'; // Indicates we are at home screen
myGLCD.clrScr();
drawHomeScreen(); // Draws the home screen
if ((x>=200) && (x<=600) &&(y>=130) && (y<=180)) {
drawFrame(200, 130,600, 180);
currentPage = '3';
myGLCD.clrScr();
drawWasserpumpe();}
void drawHomeScreen()
// Title
myGLCD.setBackColor(0,0,0); // Sets the background color of the area where the text will be printed to black
myGLCD.setColor(255, 255, 255); // Sets color to white
myGLCD.setFont(BigFont); // Sets font to big
myGLCD.print("Willkomen ", CENTER, 10); // Prints the string on the screen
myGLCD.setFont(SmallFont); // Sets the font to small
myGLCD.setColor(255, 0, 0); // Sets color to red
myGLCD.drawLine(0,32,319,32); // Draws the red line
myGLCD.print("Der Multifilter ist ", LEFT, 64);
myGLCD.print("Temperatur ", CENTER, 90);
myGLCD.print("TEMP1(TANK) TEMP2(REAKTOR1) TEMP3(DRAUSSEN) Temp4(MULTIFILTER) TEMP5(REAKTOR2)", 10, 120);
myGLCD.printNumI(x4,540, 150);
myGLCD.printNumI(x5,720, 150);
myGLCD.print("FEINSTAUB ", CENTER, 190);
myGLCD.print("PM1.0 ", 25, 220);
myGLCD.print("PM2.5 ", 360, 220);
myGLCD.print("PM10 ", 695, 220);
myGLCD.printNumI(x1,35, 240);
myGLCD.printNumI(x2,370, 240);
myGLCD.printNumI(x3,705, 240);
myGLCD.print("NOX ", 350, 270);
myGLCD.print("Konzentration0 ", 150, 290);
myGLCD.print("Konzentration1 ", 500, 290);
myGLCD.printNumI(x1,200, 310);
myGLCD.printNumI(x2,550, 310);
// Button - System einstellen
myGLCD.setColor(16, 167, 103); // Sets green color
myGLCD.fillRoundRect (110, 350,410, 450); // Draws filled rounded rectangle
myGLCD.drawRoundRect (110, 350,410, 450); //
myGLCD.setFont(BigFont); // Sets the font to big
myGLCD.setBackColor(16, 167, 103); //
myGLCD.print("System einstellen", 130, 390); // Prints the string
// Button - Sensoren Messwerte
myGLCD.fillRoundRect (430, 350, 730, 450);
myGLCD.drawRoundRect (430, 350, 730, 450);
myGLCD.print("Sensoren Werte", 460, 390);
drawButtons();
void drawFrame(int x1, int y1, int x2, int y2) {
myGLCD.drawRoundRect (x1, y1, x2, y2);
while (myTouch.dataAvailable())
myTouch.read();
void Systemeinstellung() {
myGLCD.setColor(100, 155, 203);
myGLCD.fillRoundRect (10, 10, 60, 36);
myGLCD.drawRoundRect (10, 10, 60, 36);
myGLCD.setBackColor(100, 155, 203);
myGLCD.print("<-", 18, 15);
myGLCD.setBackColor(0, 0, 0);
myGLCD.print("zurueck", 70, 18);
myGLCD.print("Einstellung", CENTER, 50);
// Button - Wasserpumpe
myGLCD.fillRoundRect (200, 130,600, 180); // Draws filled rounded rectangle
myGLCD.drawRoundRect (200, 130,600, 180); // Draws rounded rectangle without a fill, so the overall appearance of the button looks like it has a frame
myGLCD.setBackColor(16, 167, 103); // Sets the background color of the area where the text will be printed to green, same as the button
myGLCD.print("Wasserpumpe", CENTER, 150); // Prints the string
// Button - Luftpumpe
myGLCD.fillRoundRect (200, 200,600, 250); // Draws filled rounded rectangle
myGLCD.drawRoundRect (200, 200,600, 250); // Draws rounded rectangle without a fill, so the overall appearance of the button looks like it has a frame
myGLCD.print("Luftpumpe", CENTER, 220); // Prints the string
// Button - Licht
myGLCD.fillRoundRect (200, 270,600, 320); // Draws filled rounded rectangle
myGLCD.drawRoundRect (200, 270,600, 320); // Draws rounded rectangle without a fill, so the overall appearance of the button looks like it has a frame
myGLCD.print("Licht", CENTER, 290); // Prints the string
// Button - Durchlauferhitzer
myGLCD.fillRoundRect (200, 340,600, 390); // Draws filled rounded rectangle
myGLCD.drawRoundRect (200, 340,600, 390); // Draws rounded rectangle without a fill, so the overall appearance of the button looks like it has a frame
myGLCD.print("Durchlauferhitzer", CENTER, 360); // Prints the string
// Button - Kühlgeräte
myGLCD.fillRoundRect (200, 410,600, 460); // Draws filled rounded rectangle
myGLCD.drawRoundRect (200, 410,600, 460); // Draws rounded rectangle without a fill, so the overall appearance of the button looks like it has a frame
myGLCD.print("Kuehlgeraet", CENTER, 430); // Prints the string
void Werte(){
if (Serial1.available()){
// wait until the serial reading encounters character 'a'
// this marks the beginning of data
inChar = Serial1.read();
while (inChar != 'a')
// when character 'a' is encountered, read the floating data till the next character
sensor1 = Serial1.parseFloat();
// run if the next character is 'b' (it will always be 'b', unless someone messes with the sender code)
if (inChar == 'b')
// read floating value till next character
sensor2 = Serial1.parseFloat();
// break out of the loop once character 'c' is encountered
if (inChar == 'c')
return;
// for more sensor values, add more IF cases and keep the 'break' in the last one
// number them alphabetically for simplicity
Serial.println(sensor1);
Serial.println(sensor2);
myGLCD.printNumF(sensor1,2,190, 150);
myGLCD.printNumF(sensor2,2,360, 150);
