TFTM101-1 10 inch Display RA8876, problem with Mega 2560
Hello All,
I have recently purchased a 10.1 inch TFT display from:
This display is advertised as being compatible with the Mega 2560. I have downloaded the library and example files from this web site and have been experiencing problems just trying to compile the code. I have not yet powered up the display nor the shield. The SPI.h is referenced often.
Note: The display was designed for the Due but also advertised as being Mega 2560 compatible.
The first error stands out:
error: no matching function for call to 'SPIClass::begin(int&)'
The following is a complete dump of the compiler report. Thanks.
Complete Error Report After Compiling:
Arduino: 1.8.13 (Linux), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560) /home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp: In member function 'boolean Ra8876_Lite::begin()':
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:27:19: error: no matching function for call to 'SPIClass::begin(int&)'
SPI.begin(_xnscs);
In file included from /home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:11:0:
/home/pi/Downloads/arduino-1.8.13/hardware/arduino/avr/libraries/SPI/src/SPI.h:159:15: note: candidate: static void SPIClass::begin()
static void begin();
/home/pi/Downloads/arduino-1.8.13/hardware/arduino/avr/libraries/SPI/src/SPI.h:159:15: note: candidate expects 0 arguments, 1 provided
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:30:32: error: no matching function for call to 'SPIClass::setClockDivider(int&, int)'
SPI.setClockDivider(_xnscs,21);
/home/pi/Downloads/arduino-1.8.13/hardware/arduino/avr/libraries/SPI/src/SPI.h:302:22: note: candidate: static void SPIClass::setClockDivider(uint8_t)
inline static void setClockDivider(uint8_t clockDiv) {
/home/pi/Downloads/arduino-1.8.13/hardware/arduino/avr/libraries/SPI/src/SPI.h:302:22: note: candidate expects 1 argument, 2 provided
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:31:35: error: no matching function for call to 'SPIClass::setDataMode(int&, int)'
SPI.setDataMode(_xnscs,SPI_MODE0);
/home/pi/Downloads/arduino-1.8.13/hardware/arduino/avr/libraries/SPI/src/SPI.h:297:22: note: candidate: static void SPIClass::setDataMode(uint8_t)
inline static void setDataMode(uint8_t dataMode) {
/home/pi/Downloads/arduino-1.8.13/hardware/arduino/avr/libraries/SPI/src/SPI.h:297:22: note: candidate expects 1 argument, 2 provided
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:66:31: error: no matching function for call to 'SPIClass::setClockDivider(int&, int)'
SPI.setClockDivider(_xnscs,2);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp: In member function 'void Ra8876_Lite::lcdRegWrite(ru8)':
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:133:43: error: 'SPI_CONTINUE' was not declared in this scope
SPI.transfer(_xnscs,RA8876_SPI_CMDWRITE,SPI_CONTINUE);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp: In member function 'void Ra8876_Lite::lcdDataWrite(ru8)':
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:140:44: error: 'SPI_CONTINUE' was not declared in this scope
SPI.transfer(_xnscs,RA8876_SPI_DATAWRITE,SPI_CONTINUE);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp: In member function 'ru8 Ra8876_Lite::lcdDataRead()':
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:147:43: error: 'SPI_CONTINUE' was not declared in this scope
SPI.transfer(_xnscs,RA8876_SPI_DATAREAD,SPI_CONTINUE);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:148:38: error: void value not ignored as it ought to be
ru8 data = SPI.transfer(_xnscs,0xff);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp: In member function 'ru8 Ra8876_Lite::lcdStatusRead()':
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:155:45: error: 'SPI_CONTINUE' was not declared in this scope
SPI.transfer(_xnscs,RA8876_SPI_STATUSREAD,SPI_CONTINUE);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:156:37: error: void value not ignored as it ought to be
ru8 data= SPI.transfer(_xnscs,0xff);
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp: In member function 'void Ra8876_Lite::lcdDataWrite16bbp(ru16)':
/home/pi/Arduino/libraries/Ra8876_Lite/Ra8876_Lite.cpp:179:44: error: 'SPI_CONTINUE' was not declared in this scope
Multiple libraries were found for "Ra8876_Lite.h"
Used: /home/pi/Arduino/libraries/Ra8876_Lite
Not used: /home/pi/Arduino/libraries/olfRa8876_Lite
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
Any help would be appreciated.
Regards,
Brian
