Hello, I have a very basic understanding of electronics in general. I purchased an EE-SX4070 photomicrosensor. I have tried my best to follow the circuit set up in the datasheet for this sensor. So far I have had no luck. The sensor will heat up mostly and doesn't give any helpful input (random numbers). I would appreciate a picture of what the circuit should look like on a breadboard, and what types of input I should be getting if the sensor was connected to an analog pin on an arduino.
Thank You
A very brief search using simple terms and a well-known search engine (rhymes with "oogle") found this
This is what I am going off of. The forum post in the link above was helpful but I am still confused and looking for a picture of a circuit not just a schematic.
@Mobius1, what made you think that your question has anything to do with the Website and Forum section which is clearly stated to be for "Improvements for the web system, applications to moderator, spam, etc."? I have suggested to the Moderator to move it to the Project Guidance section.
This sort of carelessness makes unnecessary work for the Moderators.
Please read How to get the best out of the Forum
...R
Assuming you are connecting the sensor to a microcontroller board:
If Arduino, which one? If not, then which one? What is the Vcc voltage, 5 or 3.3 volts or?
I apologize, I have an Arduino UNO. The sensor is connected to 5v and in all cases( both emitter and receiver). I am confused with the part of the schematic where the signal line and power line are connected through what I assume is a resistor (zig zag line).
I appreciate the help!
Its a pullup resistor that holds the input pin HIGH until the phototransistor pulls it low, but the Arduino has builtin pullups that you can enable. So, connect K to GND, A to a 5.6 or 6.8K resistor then other end of resistor to +5V. Connect V to +5V, G to GND and O to your input pin (4 for test). In setup, set the input pin to INPUT_PULLUP.
byte inPin = 4;
pinMode(inPin, INPUT_PULLUP);
pinMode(LED_BUILTIN,OUTPUT);
digitalWrite(LED_BUILTIN, digitalRead(inPin));
The LED should go ON / OFF when you block the sensor.
