I'm working on a project to monitor the temperature/humidity using DHT11 sensor.
I need to save the data in a CSV format to file with the timestamp and also display the data on a webpage in LAN.
I'm using Arduino UNO with Ethernet shield W5500 and DS3132 RTC for timestamp.
If I run just the web server section of code, everything OK, the webpage opens up and is property rendered with the data.
#include "DHT.h"
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
#include "RTClib.h"
#define DHTPIN 7
#define DHTTYPE DHT11
RTC_DS3231 rtc;
DHT dht(DHTPIN, DHTTYPE);
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 0, 99);
EthernetServer server(80);
File myFile;
String timeStamp;
Serial.begin (57600);
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
/*Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");*/
dht.begin( );
Ethernet.begin(mac, ip);
server.begin( );
// Write Header Row of CSV
/*myFile = SD.open("test2.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing Header Row of CSV");
myFile.println("time,temperature,humidity");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test2.txt");
// setuop RTC module
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
abort();
if (rtc.lostPower()) {
Serial.println("RTC lost power, let's set the time!");
// When time needs to be set on a new device, or after a power loss, the
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop( )
// === RTC Module Code ===
DateTime now = rtc.now();
// Serial.print(now.year());
// Serial.print('/');
// Serial.print(now.month());
// Serial.print(now.day());
// Serial.print(now.hour());
// Serial.print(':');
// Serial.print(now.minute());
// Serial.print(now.second());
// Serial.println();
// timeStamp = String(now.year()) + "/" + String(now.month()) + "/" + String(now.day()) + " " + String(now.hour()) + ":" + String(now.minute()) + ":" + String(now.second());
// Serial.println(timeStamp);
float h = dht.readHumidity( );
float t = dht.readTemperature( );
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
// myFile = SD.open("test2.txt", FILE_WRITE);
// TODO: fix the web page
if (client)
boolean currentLineIsBlank = true;
while (client.connected ( ) )
if (client.available ( ) )
char character = client.read ( );
Serial.write(character);
if (character == '\n' && currentLineIsBlank)
client.println ("HTTP/1.1 200 OK");
client.println ("Content-Type: text/html");
client.println ("Connection: close");
client.println ("Refresh: 5");
client.println ( );
client.println ("<!DOCTYPE HTML>");
client.println ("<html>");
client.print ("<Title>Arduino Ethernet Webserver </Title>");
client.print ("<h1>Arduino Ethernet Shield Webserver </h1>");
client.print ("<h4>Temperature in C: ");
client.print (t); client.print("C");
client.print ("</h4><h4>Humidity: ");
client.print (h); client.print("%");
client.println ("<br />");
client.println ("</html>");
if ( character == '\n')
else if (character != '\r')
currentLineIsBlank = false;
delay(1);
client.stop();
// if the file opened okay, write to it:
/*delay(5000);
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(" ");
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(':');
myFile.print(now.second(), DEC);
myFile.print(",");
myFile.print(t);
myFile.print(",");
myFile.print(h);
myFile.println("");
// close the file:
myFile.close();
Serial.println("error opening test.txt");
If I disable the webpage and run just the code to save data to file with timestamp, everything is also OK.
#include "DHT.h"
#include <SPI.h>
#include <SD.h>
#include "RTClib.h"
#define DHTPIN 7
RTC_DS3231 rtc;
byte mac[] = {
File myFile;
String timeStamp;
if (!SD.begin(4)) {
while (1);
dht.begin( );
server.begin( );
if (myFile) {
// close the file:
myFile.close();
Serial.flush();
abort();
void loop( )
// if (client)
// boolean currentLineIsBlank = true;
// while (client.connected ( ) )
// if (client.available ( ) )
// char character = client.read ( );
// Serial.write(character);
// if (character == '\n' && currentLineIsBlank)
// client.println ("HTTP/1.1 200 OK");
// client.println ("Content-Type: text/html");
// client.println ("Connection: close");
// client.println ("Refresh: 5");
// client.println ( );
// client.println ("<!DOCTYPE HTML>");
// client.println ("<html>");
// client.print ("<Title>Arduino Ethernet Webserver </Title>");
// client.print ("<h1>Arduino Ethernet Shield Webserver </h1>");
// client.print ("<h4>Temperature in C: ");
// client.print (t); client.print("C");
// client.print ("</h4><h4>Humidity: ");
// client.print (h); client.print("%");
// client.println ("<br />");
// client.println ("</html>");
// break;
// if ( character == '\n')
// currentLineIsBlank = true;
// else if (character != '\r')
// currentLineIsBlank = false;
// delay(1);
// client.stop();
delay(5000);
if (myFile) {
// TODO: check the encoding of timeStamp, file contains some gibberish
// myFile.println(timeStamp + "," + String(t) + "," + String(h));
myFile.print('/');
myFile.print('/');
myFile.print(" ");
myFile.print(':');
myFile.print(':');
myFile.print(",");
myFile.print(t);
myFile.print(",");
myFile.print(h);
myFile.println("");
// close the file:
myFile.close();
The data is saved properly to the file. I've checked the board connnection to LAN, the board responds to ping.
➜ ~ ping 192.168.0.99
PING 192.168.0.99 (192.168.0.99) 56(84) bytes of data.
64 bytes from 192.168.0.99: icmp_seq=1 ttl=128 time=3.49 ms
64 bytes from 192.168.0.99: icmp_seq=2 ttl=128 time=1.08 ms
64 bytes from 192.168.0.99: icmp_seq=3 ttl=128 time=3.29 ms
64 bytes from 192.168.0.99: icmp_seq=4 ttl=128 time=0.872 ms
^C
--- 192.168.0.99 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 0.872/2.183/3.492/1.211 ms
But when I try to run the complete code, with both sections(server, sd card) it tries to run for a few seconds and then just hangs. No errors are displayed and the board responds to a ping indicating an active connection.
[Starting] Opening the serial port - /dev/ttyACM0
[Info] Opened the serial port - /dev/ttyACM0
itializing SD card...initialization done.
Initializing SD card...initialization done.
My code from earlier without RTC, but with server and SD card runs OK.
#include "DHT.h"
#include <SPI.h>
#include <SD.h>
#define DHTPIN 7
byte mac[] = {
File myFile;
Serial.begin (9600);
if (!SD.begin(4)) {
while (1);
dht.begin( );
server.begin( );
void loop( )
myFile = SD.open("test.txt", FILE_WRITE);
if (client)
client.println ( );
client.print (t);client.print("C");
client.print (h);client.print("%");
delay(1);
client.stop();
if (myFile) {
myFile.println("Temperature: " + String(t) + " Humidity: " + String(h));
// close the file:
myFile.close();
The wiring diagrams for RTC module as well as DHT11 are below:
DS3132 RTC
DTH 11
My wiring for DHT11 is slightly different: the green wire in connected to pin 7 and red wire is connected to 3.3V pin.
I've included the photographs of the setup here.
I'm not sure what's causing the code to hang, I appreciate the help.
