The display goes blank after 24 hours
From the sketch below, everything works, even the touch button, just that after 24 hours (almost) from reset the display goes blank.
Can someone, please, help?
```cpp
#include <Wire.h>
#include <Arduino.h>
#include <AudioAnalyzer.h>
#include <Audio.h>
#include <AiEsp32RotaryEncoder.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_GFX.h>
#include <XPT2046_Touchscreen.h>
#include <WiFiManager.h>  // https://github.com/tzapu/WiFiManager
//#include <string.h>
#include <SPI.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeMonoBoldOblique12pt7b.h>
//#include <FreeMonoBoldOblique18pt7b.h>
#include <Fonts/FreeSerifBold18pt7b.h>
#include <ESP32Time.h>
ESP32Time rtc(-180000);
//#include <FreeMono12pt7b.h>
Analyzer OtherAudio = Analyzer(47, 41, 10);  //Strobe pin ->47  RST pin ->41 Analog Pin ->10
int strobe = 47;  // strobe pins on digital 47
int res = 41;     // reset pins on digital 41
int FreqVal[7];   // store band values in these arrays
byte bartop[7];
byte barpeak[7];
int audio_bar_height[7];
int audio_bar_peak[7];
int i = 0;
int band;
int sens;
int test;
int num;
int data1;
int j;
int voll;
int volr;
int barlx = 10;
int barrx = 30;
int barWidth = 10;
int maxTop = 180;
int minTop = 229;
int barBottom = 230;
int currentTop;
int barx;
int basex;
int vol;
int diff;
char temp[50];
char humid[50];
unsigned long previousMillis = 0;
unsigned long interval = 60000UL;
#define I2S_DOUT 2
#define I2S_BCLK 3
#define I2S_LRC 4
//#define VOLUME_PIN 5  //Original sketch was using
#define TFT_CS 1
#define TFT_DC 9
#define TFT_RST 8
//Display LED to 3.3 V
#define TFT_MOSI 11
#define TFT_MISO 13
#define TFT_SCLK 12
// Color constants
#define BACKGROUND_COL ILI9341_WHITE
#define BAR_COL_MAIN ILI9341_GREEN
#define BAR_COL_TOP ILI9341_RED
#define TRIGGER_PIN 14  //Trigger wifi on Demand
#define ROTARY_ENCODER_A_PIN 21
#define ROTARY_ENCODER_B_PIN 20
#define ROTARY_ENCODER_BUTTON_PIN 14
#define ROTARY_ENCODER_STEPS 4
const char *ntpServer = "ca.pool.ntp.org";
const long gmtOffset_sec = -18000;    // Adjust for your timezone
const int daylightOffset_sec = 3600;  // Adjust if DST is active
int timeout = 120;     // seconds to wait for Wifi
char song[128] = "8";  //Test value until the first streaminfo kicks in
AiEsp32RotaryEncoder rotaryEncoder(ROTARY_ENCODER_A_PIN, ROTARY_ENCODER_B_PIN, ROTARY_ENCODER_BUTTON_PIN, -1, ROTARY_ENCODER_STEPS);
Audio audio;
// WiFi credentials
const char *ssid = "YOUR NETWORK";
const char *password = "YOUR PASSWORD";
// Radio stations
const char *stations[] = {
  "https://playerservices.streamtheworld.com/api/livestream-redirect/CJFMFM.mp3",
  "https://playerservices.streamtheworld.com/api/livestream-redirect/CHMPFM.mp3",
  "https://playerservices.streamtheworld.com/api/livestream-redirect/CBMEFM_CBC.mp3",
  "http://www.byte.fm/stream/bytefm.m3u",
  "https://playerservices.streamtheworld.com/api/livestream-redirect/CKOIFM.mp3",
  "https://playerservices.streamtheworld.com/api/livestream-redirect/CKBEFM.mp3",
  "https://stream.rythme971.ca/chlx.mp3",
  "https://best-90s.stream.laut.fm/best-90s",
  "https://stream.zeno.fm/ygg6zypxpg8uv",
  "http://live.radiomixx.ro/"
const char *stationNames[] = {
  "Virgin Radio",
  "TSN 690",
  "CBC Montreal",
  "KEXP",
  "96.9CKOI",
  "The Beat 92.5",
  "Rythme971",
  "Best 90' Radio",
  "City FM Bolivia",
  "Radio MIXX Romania"
const int NUM_STATIONS = sizeof(stations) / sizeof(stations[0]);
int currentStation = 0;
char streamTitle[64] = "";  // Buffer to store the current stream title
// Volume control variables
const int SAMPLES = 5;
int volumeReadings[SAMPLES];
int readIndex = 0;
int total = 0;
int average = 0;
int amp = 0;
unsigned long lastVolumeCheck = 0;
const unsigned long VOLUME_CHECK_INTERVAL = 500;  // Check every 500ms
//Time and date variables
char ttime[128] = "";
char tdate[128] = "";
char tday[128] = "";
// Flags initialization
bool isWiFiConnected = false;
bool isDisplayInitialized = false;
bool isAudioInitialized = false;
void IRAM_ATTR readEncoderISR() {
  rotaryEncoder.readEncoder_ISR();
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
//Screen calibration
#define TOUCH_CS 18
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
XPT2046_Touchscreen touch(TOUCH_CS);
int xMinVal, xMaxVal, yMinVal, yMaxVal;
TS_Point waitForTouch() {
  while (!touch.touched()) {
    delay(200);
  delay(200);
  TS_Point p = touch.getPoint();
  while (touch.touched())
  delay(200);
  return p;
Adafruit_GFX_Button btn;
bool toggleState = false;
  while (!Serial) { delay(10); }  // Wait for Serial to start
  Serial.println(F("ESP32-S3 Internet Radio started..."));
  isDisplayInitialized = true;
  OtherAudio.Init();  // Init audio analyzer module
  pinMode(48, OUTPUT);
  pinMode(46, INPUT);
  pinMode(15, INPUT_PULLUP);
  pinMode(16, INPUT_PULLUP);
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  rotaryEncoder.begin();
  rotaryEncoder.setup(readEncoderISR);
  rotaryEncoder.setBoundaries(0, NUM_STATIONS - 1, true);
  rotaryEncoder.setAcceleration(0);
  SPI.begin(TFT_SCLK, TFT_MISO, TFT_MOSI, TFT_CS);
  //Screen calibrate
  tft.begin();
  touch.begin();
  tft.setRotation(3);
  touch.setRotation(3);
  tft.fillScreen(ILI9341_BLACK);
  tft.setTextSize(2);
  tft.setTextColor(ILI9341_WHITE);
  // Ask user to touch four corners
  tft.setCursor(20, 20);
  tft.fillRoundRect(10, 10, 50, 50, 45, ILI9341_WHITE);
  tft.setCursor(40, 140);
  tft.println("Touch TOP-LEFT");
  TS_Point p1 = waitForTouch();
  xMinVal = p1.x;
  yMinVal = p1.y;
  tft.setCursor(300, 20);
  tft.fillRoundRect(260, 10, 50, 50, 45, ILI9341_WHITE);
  tft.println("Touch TOP-RIGHT");
  //tft.fillRoundRect(180, 200, 50, 50, 45, ILI9341_WHITE);
  //tft.setCursor(20, 140);
  TS_Point p2 = waitForTouch();
  xMaxVal = p2.x;
  tft.setCursor(20, 200);
  tft.fillRoundRect(10, 180, 50, 50, 45, ILI9341_WHITE);
  tft.println("Touch BOTTOM-LEFT");
  TS_Point p3 = waitForTouch();
  yMaxVal = p3.y;
  tft.println("Calibration Done!");
  delay(2000);
  // Print values
  Serial.println("Calibration Values:");
  Serial.print("xMin = ");
  Serial.println(xMinVal);
  Serial.print("xMax = ");
  Serial.println(xMaxVal);
  Serial.print("yMin = ");
  Serial.println(yMinVal);
  Serial.print("yMax = ");
  Serial.println(yMaxVal);
  tft.setCursor(20, 50);
  tft.setTextColor(ILI9341_RED);
  tft.setTextSize(4);
  tft.println(" Web Radio");
  delay(2000);
  tft.setCursor(50, 85);
  tft.setTextSize(3);
  tft.println("  Starting");
  delay(2000);
  tft.setTextSize(2);
  tft.setTextColor(ILI9341_YELLOW);
  tft.setCursor(60, 60);
  tft.setTextSize(4);
  tft.println("Display");
  tft.setCursor(20, 95);
  tft.setTextSize(4);
  tft.setTextColor(ILI9341_BLUE);
  tft.println("Initialized");
  //Start Wifi
  Serial.println(F("Starting WiFi..."));
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
  while (digitalRead(TRIGGER_PIN) == HIGH) {
    tft.fillScreen(ILI9341_WHITE);
    tft.setTextSize(2);
    tft.println("Press Internet button");
    tft.setCursor(40, 50);
    tft.println("Check your phone");
    tft.setCursor(50, 80);
    tft.println("Configure Wifi");
  WiFiManager wm;
  //reset Wifi settings for new Wifi
  wm.resetSettings();
  // set config Web portal timeout
  wm.setConfigPortalTimeout(timeout);
  if (!wm.startConfigPortal("OnDemandAP")) {
    Serial.println("failed to connect and hit timeout");
    ESP.restart();
  int attempts = 0;
  while (WiFi.status() != WL_CONNECTED && attempts < 10) {
    Serial.print(".");
    attempts++;
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println(F("\nWiFi connected"));
    isWiFiConnected = true;
  tft.fillScreen(ILI9341_RED);
  tft.setTextColor(ILI9341_GREEN);
  tft.setTextSize(3);
  tft.println("Wifi connected");
  // Initialize button: (tft, x, y, width, height, outline, fill, textcolor, label, textsize)
  btn.initButton(&tft, 60, 230, 40, 40, ILI9341_WHITE, ILI9341_GREEN, ILI9341_BLACK, "MUTE", 1);
  btn.drawButton();
  initializeAudio();
  //static unsigned long lastInitAttempt = 0;
  //const unsigned long initInterval = 5000;  // 5 between
  // Basic Loop
  audio.loop();
  checkEncoder();
  readfreq();
  unsigned long currentMillis = millis();  // Get current time
  if (currentMillis - previousMillis >= interval) {
    // Save the last time you blinked the LED
    showtime();
  yield();
  //Check MUTE
  if (touch.touched()) {
    // Map raw touch coordinates to screen pixels (values depend on calibration)
    int x = map(p.x, 463, 3685, 0, tft.width());
    int y = map(p.y, 680, 3564, 0, tft.height());
    // Update button "pressed" state
    btn.press(btn.contains(x, y));
    btn.press(false);
  // Check for the moment the button is released to toggle the state
  if (btn.justReleased()) {
    toggleState = !toggleState;
    // Redraw button with new state colors/labels
    if (toggleState) {
      btn.initButton(&tft, 60, 230, 40, 40, ILI9341_WHITE, ILI9341_RED, ILI9341_WHITE, "UNMUTE", 1);
    btn.drawButton();
    // Perform action (e.g., turn on an LED)
    digitalWrite(LED_BUILTIN, toggleState ? HIGH : LOW);
void initializeDisplay() {
  Serial.println(F("InitializingILI9341 Display..."));
  tft.setTextSize(2);
  tft.setCursor(20, 40);
  tft.println(F("Initializing..."));
  Serial.println(F("Display initialized"));
void initializeAudio() {
  audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
  audio.setVolume(10);
  connectToStation(currentStation);
  isAudioInitialized = true;
  Serial.println(F("Audio initialized"));
void checkEncoder() {
  if (rotaryEncoder.encoderChanged()) {
    //Serial.println("Changing..");
    currentStation = rotaryEncoder.readEncoder();
  if (rotaryEncoder.isEncoderButtonClicked()) {
    Serial.println(F("Encoder-SW check"));
    // Here other funtion using the SW, it is used to trigger Wifi setup, OnDemand
void connectToStation(int stationIndex) {
  audio.stopSong();
  audio.connecttohost(stations[stationIndex]);
  updateDisplay();
void updateDisplay() {
  if (!isDisplayInitialized) return;
  //if (isDisplayInitialized && isWiFiConnected && isAudioInitialized) {
  //showtime();
  tft.setTextColor(ILI9341_BLACK);
  tft.setCursor(5, 10);
  tft.setTextSize(1);
  tft.setFont(&FreeSans9pt7b);
  tft.println("Station...       ");
  //tft.print(String(stationNames[currentStation]) );
  tft.setCursor(80, 10);
  tft.print((String(stationNames[currentStation])));
  //tft.println();
  tft.setCursor(5, 30);
  tft.setTextSize(1);
  tft.println("Playing  ");
  tft.setCursor(80, 30);
  tft.print((String(streamTitle)));
  /*  tft.setFont(&FreeMonoBoldOblique12pt7b);
  tft.setCursor(100, 75);
  tft.setTextSize(1);
  tft.println(tday);
  tft.setCursor(65, 92);
  tft.setTextSize(1);
  tft.println(tdate);
  tft.setCursor(110, 120);
  tft.setTextSize(1);
  tft.setFont(&FreeSerifBold18pt7b);
  tft.println(ttime);
  tft.setCursor(5, 90);
  tft.setFont();
  tft.println("VOLUME");
  tft.setCursor(10, 95);
  tft.println("L");
  tft.setCursor(30, 95);
  tft.println("R");
  tft.setTextSize(1);
  //tft.setFont(FreeMono12pt7b.h);
  tft.setFont();
  tft.setCursor(80, 230);
  tft.println("64");
  tft.setCursor(100, 230);
  tft.println("160");
  tft.setCursor(125, 230);
  tft.println("400");
  tft.setCursor(150, 230);
  tft.println("1K ");
  tft.setCursor(170, 230);
  tft.println("2.5K");
  tft.setCursor(200, 230);
  tft.println("6.3K");
  tft.setCursor(230, 230);
  tft.println("16K");
  tft.setCursor(250, 140);
  tft.setTextSize(1);
  tft.setTextColor(ILI9341_BLACK, ILI9341_WHITE);
  sprintf(temp, "Temp %d C", 45);
  tft.println(temp);
  tft.setCursor(250, 180);
  tft.setTextSize(1);
  sprintf(humid, "Humid %d%%", 80);
  tft.println(humid);
  showtime();
  volume(voll, volr);
  basex = 10;
  vol = voll;
  drawBar(basex, vol);
  delay(50);
  basex = 30;
  vol = volr;
  btn.drawButton();
  /*tft.fillRect(volbarlx, volbasey-maxheight,10, maxheight-voll-40,ILI9341_WHITE);
    tft.fillRect(volbarlx, volbasey-voll, 10, voll, ILI9341_GREEN);
    Serial.println(voll);
    delay(3000);
    tft.fillRect(volbarrx, volbasey-maxheight,10, maxheight-volr-40,ILI9341_WHITE);
    tft.fillRect(volbarrx, volbasey-volr, 10, volr, ILI9341_GREEN);
    delay(50);*/
// Audio callback functions
void audio_info(const char *info) {
  Serial.print("info        ");
  Serial.println(info);
void audio_id3data(const char *info) {
  Serial.print("id3data     ");
void audio_eof_mp3(const char *info) {
  Serial.print("eof_mp3     ");
void audio_showstation(const char *info) {
  Serial.print("station     ");
void audio_showstreaminfo(const char *info) {
  Serial.print("streaminfo  ");
void audio_showstreamtitle(const char *info) {
  Serial.print("streamtitle: ");
  streamTitle[sizeof(streamTitle) - 1] = '\0';  // Ensure null-termination
  strncpy(streamTitle, info, sizeof(streamTitle) - 1);
  updateDisplay();
void audio_bitrate(const char *info) {
  Serial.print("bitrate     ");
void audio_commercial(const char *info) {
  Serial.print("commercial  ");
void audio_icyurl(const char *info) {
  Serial.print("icyurl      ");
void audio_lasthost(const char *info) {
  Serial.print("lasthost    ");
void audio_eof_speech(const char *info) {
  Serial.print("eof_speech  ");
void showtime() {
  struct tm timeinfo = rtc.getTimeStruct();
  if (!getLocalTime(&timeinfo)) {
    Serial.println("Failed to obtain time");
    return;
  Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
  //delay(1000);
  strftime(tdate, 128, "%B %d %Y", &timeinfo);
  strftime(ttime, 128, "%H:%M", &timeinfo);
  strftime(tday, 128, "%A", &timeinfo);
  //Display time & date
  //tft.setFont(&FreeMonoBoldOblique12pt7b);
  tft.setFont();
  tft.setCursor(82, 50);
  tft.setTextSize(3);
  tft.setTextColor(ILI9341_BLUE, ILI9341_WHITE);
  tft.print(" ");
  tft.print(tday);
  tft.print(" ");
  tft.setCursor(65, 77);
  tft.setTextSize(3);
  tft.println(tdate);
  tft.setCursor(110, 105);
  tft.setTextSize(3);
  tft.setTextColor(ILI9341_WHITE, ILI9341_WHITE);
  //tft.setFont(&FreeSerifBold18pt7b);
  tft.println(ttime);
  tft.setCursor(115, 105);
  tft.println(ttime);
void volume(int &voll, int &volr) {
  voll = analogRead(15);
  volr = analogRead(16);
  voll = 640;
  volr = 640;
  voll = map(voll, 10, 1023, 20, 512);
  volr = map(volr, 10, 1023, 20, 512);
void readfreq() {
  OtherAudio.ReadFreq(FreqVal);  //Return 7 values of 7 bands pass filter
                                 //Frequency(Hz):63  160  400  1K  2.5K  6.25K  16K
                                 //FreqVal[]:      0    1    2    3    4    5    6
  for (int i = 0; i < 7; i++) {  // loop for every frequency (63Hz, 160Hz, 400Hz, 1kHz, 2.5kHz, 6.25kHz and 16kHz)
    test = FreqVal[i] - 100;
    //Serial.printf("FreqVal %d : %d\n",i,FreqVal[i]); //view each frequency level
    audio_bar_height[i] = map(max(test, 0), 0, 4095, 0, 64);  // set the bar value based on the measurement from the audio analyzer sensor
    // calculate the peak position
    if (audio_bar_peak[i] < audio_bar_height[i]) {         // if the peak is below the current bar size
      audio_bar_peak[i] = audio_bar_height[i];             // move peak to the new max. position (i.e. size of the bar)
    } else if (audio_bar_peak[i] > audio_bar_height[i]) {  // if the bar is lower than the peak
      audio_bar_peak[i]--;                                 // slowly move the peak down, one pixel every frame
    tft.fillRect(80 + i * 25, 140, 5, 63, ILI9341_RED);
    tft.fillRect(80 + i * 25, 220 - audio_bar_height[i], 5, audio_bar_height[i], ILI9341_BLACK);  //draw bar
    tft.fillRect(80 + i * 25, 220 - audio_bar_peak[i], 5, 1, ILI9341_BLACK);  // draw peak
    /*volume (voll, volr);
    tft.fillRect(volbarlx, volbasey-maxheight,10, voll,ILI9341_WHITE);
    tft.fillRect(volbarrx, volbasey-maxheight,10, volr,ILI9341_WHITE);
    tft.fillRect(volbarlx, 200-voll, 10, voll, ILI9341_GREEN);
    tft.fillRect(volbarrx, 200-volr, 10, volr, ILI9341_GREEN);
    delay(50);
void drawBar(int &basex, int &vol) {
  // Variables
  int sensorValue = vol;
  int barWidth = 8;
  int maxBarHeight = 110;
  int yBase = 230;  // The screen Y-coordinate for the bottom of the bar
  int triggerValue = 90;
  uint16_t barColor;
  // 1. Map your sensor value to a pixel height
  int currentHeight = map(sensorValue, 0, 384, 0, maxBarHeight);
  // 2. Select color based on trigger value
  //uint16_t barColor = (currentHeight > triggerValue) ? ILI9341_RED : ILI9341_GREEN;
  // 3. Clear previous bar (optional but recommended to prevent ghosting)
  tft.fillRect(basex, yBase - maxBarHeight, barWidth, maxBarHeight, ILI9341_WHITE);
  if (currentHeight > triggerValue) {
    diff = currentHeight - triggerValue;
    barColor = ILI9341_RED;
    tft.fillRect(basex, yBase - maxBarHeight - diff, barWidth, maxBarHeight, ILI9341_RED);
  tft.fillRect(basex, yBase - currentHeight, barWidth, currentHeight, ILI9341_GREEN);
  // 4. Draw the bar from bottom up
  // Formula: tft.fillRect(x, yBase - currentHeight, width, currentHeight, color)
  //tft.fillRect(basex, yBase - currentHeight, barWidth, currentHeight, barColor);
So, what part of the code is still running?
All code it running, no errors, nothing on Serial monitor, just the display goes blank, meaning white display
IT worked before for a few weeks, no changes.
What display?
Worked while not being touched and one day it stopped, or you turn it on and off and move it?
Probably data/command wires between the display and ESP32 are not making connection.
Without touching anything wire wise, a simple reset and all is back until almost 24 hours, it happens during the night when I cannot see it.
At what time? How many hours after "simple reset." Does your power go off at night? Do you have cats?
Post a picture of your wiring.
Every call to tft.fillScreen(ILI9341_WHITE); is followed by writing text to the screen in another color... that is why I suspect wiring or power.
I do not have cats, like now all working, 16;37, at night I go to bed around midnight, all working, next morning, except white screen all working, I can change stations, I can use the touch button, still no display.
When you go to bed, reset the system and see if the screen is white in the morning.
Your morning is after 24 hours at midnight ?
Try to debug the issue logically. It could be hardware issue, memory fragmentation or time-related.
When I hear that a problem happens at a certain time, I start thinking of counters overflowing, or something is writing to memory where it should not be.
That means look at every variable that is smaller than a long for overflow (can happen in combination with another) and all loop indexes or any array indexing especially with time values.
Not solving the problem because you don't seem to call the below function but the comment // Ensure null-termination is not quite correct.
From https://linux.die.net/man/3/strncpy (note the warning)
So if the info variable is longer than n bytes you will end up with a non-terminated string in the streamTitle variable.
You should do the termination after the strncpy.
Yes, the screen is white in the morning, still playing music.
That should show "duration of use" is not an issue, and "time of day" seems to be the issue.
I have no clue what this (above) does, but it is RTC related... so I suspect it, I do not know how.
Inside showtime(), this line (below) sets WHITE text on WHITE background... not easy to read... and may appear as a white screen.
Change one or both color parameters to contrasting colors.
This line [quote="xfpd, post:14, topic:1448942"] tft.setTextColor(ILI9341_WHITE, ILI9341_WHITE);`
[/quote]
The line [quote="mikemarcu, post:1, topic:1448942"]
[/quote]
actually comes from Freenove ESP32-S3 on board RTC recommendations.
Can actually be removed, a few line lower the screen is defined again.
I see white-on-white as a symptom of a "white" screen with radio working.
I would start by putting an I/O pin toggle in the update display function. When it stops displaying, check that I/O pin to see if the update display function is still being called.
I have to investigate, even the sound is gone now.
If possible, go back to something as basic as just the screen and the controller board.
Don't disturb the wiring apart from careful disconnects.
The equivalent of Hello World.
I slowly rebuilt the sketch, step by step, until full sketch is again up and running.
The problem with grey screen comes back once in a while, more than 24 hours, and not being able to mention after how long after a full reset, now here are more than 48 hours and no problem.
