The selected serial port does not exist
Hi there,
sorry, new to this.
I am running MacOSCatalina 10.15.7 on a MacBook pro.
The Arduino is a clone (which I didn't realise when I bought it!)
When I don't have the Arduino connected (straight to computer) there is no serial port (well, there are some but not an Arduino one). When I connect the Arduino, the power LED comes on, the L LED flashes. And in Tools>Port I get /dev/cu.usbserial-1420
I've tried restarting the computer, resetting the uno and a different USB port.
The verbose error is below. Any help much appreciated.
Arduino: 1.8.15 (Mac OS X), Board: "Arduino Uno"
Sketch uses 932 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-1420 -b115200 -D -Uflash:w:/var/folders/_q/90gd3vnj01x25rmt59jb58dh0000gp/T/arduino_build_920335/LEA4_Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/michaelmoneypenny/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbserial-1420
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/_q/90gd3vnj01x25rmt59jb58dh0000gp/T/arduino_build_920335/LEA4_Blink.ino.hex"
avrdude: writing flash (932 bytes):
Writing | ################################################## | 100% 0.16s
avrdude: 932 bytes of flash written
avrdude: verifying flash memory against /var/folders/_q/90gd3vnj01x25rmt59jb58dh0000gp/T/arduino_build_920335/LEA4_Blink.ino.hex:
avrdude: load data flash data from input file /var/folders/_q/90gd3vnj01x25rmt59jb58dh0000gp/T/arduino_build_920335/LEA4_Blink.ino.hex:
avrdude: input file /var/folders/_q/90gd3vnj01x25rmt59jb58dh0000gp/T/arduino_build_920335/LEA4_Blink.ino.hex contains 932 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.15s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x62 != 0x0c
avrdude: verification error; content mismatch
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
option enabled in File -> Preferences.
Answered my own question.
Needed a new boot loader, so got an original arduino uno. Then followed the steps here:
https://support.arduino.cc/hc/en-us/articles/360012048080-How-to-burn-the-bootloader-between-two-Arduino-UNO
Have to remember to tell the programmer to “Arduino as ISP”. Worked beautifully.
