Hi. On google groups on the subject of "Accelstepper" I found a post by Mike McCauley with the code I wanted to test in my simple project. I am trying to understand the Accelstepper library (I am not a programmer) and use it to move two stepper motors that will be controlled independently with the X, Y joystick - They will guide the trolley on v-slot profiles. For now, I have limited myself to one stepper motor to learn the principle of operation. This code works great for me, but I'd like to add limit buttons to it. I wrote on the google group, but the topic seems to be closed.
I understand that the basis of this program is to keep reading joystick values through the millis () function in a loop. If I add limiting buttons, their value must also be constantly read in the millis () loop so that the cart stops when the limit button is pressed and goes back a few steps in the opposite direction, temporarily deactivating the code responsible for moving the cart with the joystick? So the bounding button loop must take precedence over the X, Y control loop. I wonder where to put the bounding button loop in this code.
Mike's original code looks like this:
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3,
4, 5
#define JOYSTICK_PIN A0
#define MAX_SPEED 100
#define INPUT_READ_INTERVAL 100
unsigned long last_input_time = 0;
// Change these to suit your stepper if you want
stepper.setMaxSpeed(0);
stepper.setAcceleration(10);
// stepper.moveTo(1000000000);
// Every INPUT_READ_INTERVAL milliseconds, read inputs.
// We do this infrequently to prevent interfering
// with the stepper motor high speed stepping
// Get the current joystick position as analog value
unsigned long current_time = millis();
if (current_time - last_input_time > INPUT_READ_INTERVAL)
int joystick_in = analogRead(JOYSTICK_PIN);
// Map the raw analog value to speed range from -MAX_SPEED to MAX_SPEED
int desired_speed = map(joystick_in, 0, 1023, -MAX_SPEED, MAX_SPEED);
// Serial.println(desired_speed);
// Based on the input, set targets and max speed
stepper.setMaxSpeed(abs(desired_speed));
if (desired_speed == 0 && stepper.speed() == 0)
// Prevent running off the end of the position range
stepper.setCurrentPosition(0);
else if (desired_speed < 0)
stepper.moveTo(-1000000000);
else if (desired_speed > 0)
last_input_time = current_time;
stepper.run();
Also, based on the post by the user groundFungus from this Arduino forum, I work this way:
AccelStepper stepper(1, 14, 12);
#define JOYSTICK_PIN 34
#define MAX_SPEED 1000
const byte buttonPin = 27;
bool lastButtonState = HIGH; // button history
bool moveDir = false; // stepper direction flag
long moveSteps = 800; // number of steps to move per button press
pinMode(buttonPin, INPUT_PULLUP);
//pinMode(homebtn, INPUT_PULLUP);
stepper.setAcceleration(1000);
int desired_speed = map(joystick_in, 0, 4095, -MAX_SPEED, MAX_SPEED);
bool buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
stepper.moveTo(-10000);
stepper.moveTo(10000);
else if (buttonState == LOW) {
while (stepper.currentPosition() != 0) // Full speed basck to 0
stepper.setSpeed(0);
stepper.run();
// stepper.runToPosition();
stepper.run(); // must be called very often
// ideally once every loop iteration
How do I approach this. Does the break; command is the right solution?
