Hi all!
For an arts project I've been asked to come up with a sensor that detects a hand being held above a column. The installation should then react to the presence of this hand by playing music or changing colour. That's the easy part - the hand detection of course is not.
Range: up to 30-50 cm would be great.
Directional sensitivity is important: it should react ideally only to the hand above the installation, not the person walking by.
Finally: it has to look good, i.e. be pretty much invisible, inside a translucent (milky white) acrylic tube of some 10-20 cm diameter. The tube will be lit from the inside using an LED strip. The antenna may be mounted at the top (it's a bit slanted; it will be capped with another piece of the same acrylic, a 1 mm wire around the inside edge should work.
So ultrasound sensors are out. Traditional capacitive as well - not enough range, just a few cm normally and that by using a complete surface.
Based on that, I'm first of all thinking capacitive sensing - and probably the theremin principle. I've done some reading on the theremin and it seems to tick all the boxes. Those antennas are very sensitive, reportedly up to 80 cm or even a bit more. Basically this makes use of an oscillator, a hand in the magnetic field of the antenna changes the capacitance of it, and that causes a shift in frequency. That shift is small: can be as little as 100 ppm in the far reaches, so needs stable oscillators.
The obvious oscillator, the 555, is no good for this. Definitely not stable enough - 1% according to the data sheet.
A 74HC00 based RC oscillator as suggested here should be an improvement when it comes to stability. Not sure what stability it gets, I haven't found any numbers. I built this oscillator on a breadboard and it oscillates just fine, a nice square wave shows up on the scope. Some tuning of the RC values will easily get the correct frequency.
Then I found another one: an LC based 74HC00 oscillator. Based on what I read elsewhere this should be giving even better stability - but I can't get this to oscillate. I built it on a breadboard; ceramic caps; ferrite core choke; metal film resistors. No luck, just when I touch the resistors I get to see a lot of noise. There's a dedicated thread about that project but it appears to be pretty dead with the OP not a member of this forum any more.
So... what to do? I may assume the circuit of the latter is correct, so it's probably either the breadboard with all its parasitics or the wrong kind of inductor that is stopping it from oscillating. I suppose it's C1 and L1 that are responsible for the frequency, not too sure of the function of C3 and C4. I'd like to have it working on breadboard before soldering it to perfboard in order to get to the correct frequency - the given values should produce about 4.1 MHz...
All suggestions are welcome, thanks in advance!
