Hello World,
I am trying to take thermocouple reading after every 1-second interval. I have tried two approaches, one with delay() & the other with millis() function. The latter is not updating the temperature value. Code, wiring example & results are attached. Thanks for your time & concern, any help shall be appreciated.
Thanks,
with delay() function
#include <max6675.h>
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 6;
int sl = 0;
float sum = 0;
float avg = 0;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
analogReference(INTERNAL1V1);
delay(200);
Serial.println("Data logging started...");
delay(200);
sl = sl + 1;
sum = 0;
Serial.print("time (s)");
Serial.print(" \t");
Serial.print(sl);
Serial.print("Temperature = ");
for (int i = 0; i < 20; i++) {
sum = sum + thermocouple.readCelsius();
delay(39);
avg = sum / 20;
Serial.print(avg);
Serial.println("*C");
Results: working
time (s) 1 Temperature = 69.25 *C
time (s) 2 Temperature = 70.00 *C
time (s) 3 Temperature = 69.75 *C
time (s) 4 Temperature = 70.25 *C
time (s) 5 Temperature = 70.00 *C
time (s) 6 Temperature = 71.00 *C
time (s) 7 Temperature = 71.25 *C
time (s) 8 Temperature = 71.25 *C
time (s) 9 Temperature = 72.00 *C
time (s) 10 Temperature = 71.00 *C
time (s) 11 Temperature = 72.25 *C
time (s) 12 Temperature = 72.50 *C
time (s) 13 Temperature = 72.00 *C
time (s) 14 Temperature = 73.25 *C
time (s) 15 Temperature = 72.50 *C
time (s) 16 Temperature = 73.25 *C
time (s) 17 Temperature = 73.25 *C
time (s) 18 Temperature = 73.25 *C
time (s) 19 Temperature = 73.50 *C
time (s) 20 Temperature = 73.50 *C
time (s) 21 Temperature = 74.00 *C
time (s) 22 Temperature = 73.50 *C
time (s) 23 Temperature = 74.25 *C
time (s) 24 Temperature = 74.75 *C
time (s) 25 Temperature = 74.50 *C
time (s) 26 Temperature = 75.25 *C
time (s) 27 Temperature = 75.00 *C
time (s) 28 Temperature = 75.25 *C
time (s) 29 Temperature = 75.75 *C
time (s) 30 Temperature = 75.00 *C
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 6;
int sl = 0;
float sum = 0;
float avg = 0;
unsigned long previousMillis = 0;
const long interval = 1000;
delay(200);
sum = 0;
avg = sum / 20;
if (currentMillis - previousMillis >= interval) {
sl = sl + 1;
Serial.print(sl);
Serial.print(avg);
Results: Not working (temp. value static)
time (s) 1 Temperature = 84.75 *C
time (s) 2 Temperature = 84.75 *C
time (s) 3 Temperature = 84.75 *C
time (s) 4 Temperature = 84.75 *C
time (s) 5 Temperature = 84.75 *C
time (s) 6 Temperature = 84.75 *C
time (s) 7 Temperature = 84.75 *C
time (s) 8 Temperature = 84.75 *C
time (s) 9 Temperature = 84.75 *C
time (s) 10 Temperature = 84.75 *C
time (s) 11 Temperature = 84.75 *C
time (s) 12 Temperature = 84.75 *C
time (s) 13 Temperature = 84.75 *C
time (s) 14 Temperature = 84.75 *C
time (s) 15 Temperature = 84.75 *C
time (s) 16 Temperature = 84.75 *C
time (s) 17 Temperature = 84.75 *C
time (s) 18 Temperature = 84.75 *C
time (s) 19 Temperature = 84.75 *C
time (s) 20 Temperature = 84.75 *C
time (s) 21 Temperature = 84.75 *C
time (s) 22 Temperature = 84.75 *C
time (s) 23 Temperature = 84.75 *C
time (s) 24 Temperature = 84.75 *C
time (s) 25 Temperature = 84.75 *C
time (s) 26 Temperature = 84.75 *C
time (s) 27 Temperature = 84.75 *C
time (s) 28 Temperature = 84.75 *C
time (s) 29 Temperature = 84.75 *C
time (s) 30 Temperature = 84.75 *C
