I am having a similar problem. Everything seems to be working properly and even getting the values I intend in the Serial Monitor. But when it comes to viewing these values in the dashboard, I am getting values of "0"
Sketch generated by the Arduino IoT Cloud Thing "Untitled 2"
https://create.arduino.cc/cloud/things/4fbdca4b-9386-4744-94cc-5da4fac5209f
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float temp_Sensor;
int pH_Sensor;
int tDS_Sensor;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Arduino.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is connected to the Arduino digital pin
#define ONE_WIRE_BUS 17 // change this to your sensor's pin if it's not 17
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
const int pHSensorPin = 36;
const int tdSensorPin = 34;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
pinMode(pHSensorPin, INPUT);
pinMode(tdSensorPin, INPUT);
sensors.begin();
sensors.setResolution(12);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
int pHValue = readPHValue();
float temperature = readTemperature();
int tdValue = readTDValue();
Serial.print("pH Value: ");
Serial.println(pHValue);
Serial.print("Temperature: ");
Serial.println(temperature);
Serial.print("TDS Value: ");
Serial.println(tdValue);
delay(1000); // Wait for 1 second before reading again
int readPHValue() {
int sensorValue = analogRead(pHSensorPin);
// Convert the sensor value to pH value using your calibration formula or library
// Replace the code below with your actual conversion logic
int pH = sensorValue * 0.004;
return pH;
float readTemperature() {
sensors.requestTemperatures();
float temperature = sensors.getTempCByIndex(0);
return temperature;
int readTDValue() {
int tdValue = analogRead(tdSensorPin);
// Convert the sensor value to TDS value using your calibration formula or library
// int tds = ... ;
return tdValue;
Here is the thingProperties.h code
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char DEVICE_LOGIN_NAME[] = "0aa3fa2c-1501-4bcc-b07b-b5d84ecbd613";
const char SSID[] = SECRET_SSID; // Network SSID (name)
const char PASS[] = SECRET_OPTIONAL_PASS; // Network password (use for WPA, or use as key for WEP)
const char DEVICE_KEY[] = SECRET_DEVICE_KEY; // Secret device password
float temp_Sensor;
int pH_Sensor;
int tDS_Sensor;
void initProperties(){
ArduinoCloud.setBoardId(DEVICE_LOGIN_NAME);
ArduinoCloud.setSecretDeviceKey(DEVICE_KEY);
ArduinoCloud.addProperty(temp_Sensor, READ, ON_CHANGE, NULL);
ArduinoCloud.addProperty(pH_Sensor, READ, ON_CHANGE, NULL);
ArduinoCloud.addProperty(tDS_Sensor, READ, ON_CHANGE, NULL);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
int ANALOG_PIN = A1;//2
int RELAY_PIN = 2;//13
#define RANGE 5000 // Depth measuring range 5000mm (for water)
#define VREF 5000 // ADC's reference voltage on your Arduino,typical value:5000mV
#define CURRENT_INIT 4.00 // Current @ 0mm (uint: mA)
#define DENSITY_WATER 1 // Pure water density normalized to 1
#define DENSITY_GASOLINE 0.74 // Gasoline density
#define PRINT_INTERVAL 2000 // changed from 1000 642023
int16_t dataVoltage;
float dataCurrent, depth; //unit:mA
// paste end
#define TEMP_UPPER_THRESHOLD 40 // upper temperature threshold
#define TEMP_LOWER_THRESHOLD 34 // lower temperature threshold
#define SENSOR_PIN A2 // 23 ESP32 pin connected to DS18B20 sensor's DQ pin
#define RELAY_TEMP_PIN 1 // 27 ESP32 pin connected to relay
OneWire oneWire(SENSOR_PIN);
DallasTemperature DS18B20(&oneWire);
LiquidCrystal_I2C lcd(0x3F, 16, 2); // I2C address 0x27, 16 column and 2 rows
float tempC; // temperature in Celsius
float tempF; // temperature in Fahrenheit
delay(1500);
initProperties();
Maximum is 4
DS18B20.begin(); // initialize the DS18B20 sensor
pinMode(RELAY_TEMP_PIN, OUTPUT);
lcd.init(); // initialize the lcd
lcd.backlight(); // open the backlight
// paste begin
pinMode(ANALOG_PIN, INPUT);
pinMode(RELAY_PIN, OUTPUT);//paste end
delay(2000);// added to see if this would update Remote APP
// Your code here
DS18B20.requestTemperatures(); // send the command to get temperatures
float temperature = DS18B20.getTempFByIndex(0); // read temperature in Fahrenheit
tempC = DS18B20.getTempCByIndex(0); // read temperature in Celsius
tempF = tempC * 9 / 5 + 32; // convert Celsius to Fahrenheit
//paste begin
dataVoltage = analogRead(ANALOG_PIN) / 1024.0 * VREF;
dataCurrent = dataVoltage / 120.0; //Sense Resistor:120ohm
depth = ((dataCurrent - CURRENT_INIT) * (RANGE / DENSITY_WATER / 16.0) * .0114); //Calculate depth from current readings and convert to inches
if (depth < 0)
depth = 0.0;
//Serial print results
Serial.print("depth:");
Serial.print(depth);
Serial.println("inches");
// Check if depth is low, and turn on the relay if it is
if (depth < 15.5) {
Serial.println("Relay 2 closed");// turn pump on
digitalWrite(RELAY_PIN, HIGH);
} else if (depth >= 16.6) {
Serial.println("Relay 2 open");// turn pump off
digitalWrite(RELAY_PIN, LOW);
} //paste end
lcd.clear();
lcd.setCursor(0, 0); // display position
lcd.print(depth); // display the depth reading from sensor
lcd.print(" Inches");
lcd.setCursor(0, 1); // display position
lcd.print(tempF); // display the temperature in Fahrenheit
lcd.print((char)223); // display ° character
lcd.print("F");
if (temperature > TEMP_UPPER_THRESHOLD) {
Serial.println(DS18B20.getTempFByIndex(0));
Serial.println("Relay 1 open");// relay 1 controls temperature by starting pump
digitalWrite(RELAY_TEMP_PIN, LOW); // turn off
} else if (temperature < TEMP_LOWER_THRESHOLD) {
Serial.println("Relay 1 closed");
digitalWrite(RELAY_TEMP_PIN, HIGH); // turn on
delay(1500);
Here is the code I'm using however it won't display values in IOT Remote dashboard
