Thingspeak connection problem program
More details as before. Due to the fact that me myself does not know much about the "engine unreal" I guess I can't help anymore. I guess others will still have questions how your "unreal-engine" is connected with
ThingSpeak
or are you using
TeamSpeak ?
As long as you are in such a hurry that you still do not explain all details you will just slow everything down. Because other users have to ask back again and again to get some more details always still not enough for others to get a
real overview
of what you are doing.
best regards Stefan
Sorry I meant thingspeak , I always get confused with the two names, and ofcourse are totally different things .
As details, what further details ? I am willing to share more but I am not sure what else to write I thought to have explained the idea project I want to do .
put into communication the engine , the thingspeak channel and the nodemcu8266 sensor in a side and the other , so writing data from nodemcu to the channel of thingspeak in field 1 and 2 and send this data to the engine, then have the engine write back on fields 3 and 4 on the thingspeak channel and have the nodemcu read those other two channels to decide wheter to light up or not the two leds .
I managed to get covered the engine part so I need to work out the nodemcu part, the only problem I am having on engine side is that writing on the api in a single field it sets to null all other fields , which is not what I want .
Take a close look at this description:
nodeMCU_Data "A" ===> ThingSpeak-field1
nodeMCU_Data "B" ===> ThingSpeak-field2
nodeMCU_Data "A" ===> engine
nodeMCU_Data "B" ===> engine
engine_Data "C"==>ThingSpeak-field3
engine_Data "D"==>ThingSpeak-field4
nodeMCU===requests-to-ThingSpeak====> "Send-me-Value-of-field3"
ThingSpeak_-field3====>nodeMCU
nodeMCU===requests-to-ThingSpeak====> "Send-me-Value-of-field4"
ThingSpeak_-field4====>nodeMCU
This is a description that is much more precise than your verbal description
And this is the grade of precision that is required as a must to make others really understand what you mean
Now you can add to this description what is happening or in case my description is not correct to correct it.
Ok Thanks I take some time to check .
So according to my idea is Like :
Nodemcu Side :see_no_evil:
nodeMCU_Data "A" =====>ThingSpeak-field1
nodeMCU_Data "B" =====>ThingSpeak-field2
nodeMCU_Data "C" <=====ThingSpeak-field3
nodeMCU_Data "D" <=====ThingSpeak-field4
nodeMCU Set HIGH/LOW Ledblu ( C DATA)
nodeMCU set HIGH/LOW LedRed ( D DATA)
Engine Side
ThingSpeak-field1=====> engine_Data "A"
ThingSpeak-field2=====> engine_Data "B"
Engine Elaborates Data A and B
then sets
Makes sense? :see_no_evil:
Did not make sense?
I am wondering is ok to send both read and write data from and to a nodemcu8266 ? Or is better to limit it to only read or only write?
Experiment with smaller programs and find out. It would seem odd to be restricted to one or the other though.
is there any example to check on having a both read and write program on thingspeak?
Thankyou , I saw this and read but I am meaning reading and writing at the same time on the same device , not just how to read or write that I already done on different devices.
