// Adafruit Motor shield library
// copyright Adafruit Industries LLC, 2009
// this code is public domain, enjoy!
#include <AFMotor.h>
// Connect a stepper motor with 48 steps per revolution (7.5 degree)
// to motor port #2 (M3 and M4)
AF_Stepper motor(48, 2);
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Stepper test!");
motor.setSpeed(10); // 10 rpm
Serial.println("Single coil steps");
motor.step(500, FORWARD, SINGLE);
Is there anyone knows why my stepper just turn back and forth? what is wrong with the code?
Stepper motors need the 4 phases energized in the correct order, and with 4 wires there are 3 fundamental ways to
hook it up (ignoring cyclic rotations of the phases or reversing the motor), 2 of which don't work, 1 of which does...
If the phases are marked A+, A-, B+, B- then its easy, just ensure you alternate from A to B:
A+/B+/A-/B- or A-/B+/A+/B- will work for instance. However anything thats AABB or ABBA or BAAB etc won't work.
However sometimes phases are unmarked or marked "1,2,3,4" which frankly could mean anything - trial and error are
then needed (or using a multimeter to identify A winding from B winding).
