I am trying to control three linear actuators, each one hooked up to its own IBT-2 motor controller. I am using some test code just to see if they work first and I'm getting unexpected results. When I use the code to extend the linear actuators only the left motor (using pwm pins 9 and 10) works. Then when I retract the actuators, all three are working just fine. I'm brand new to arduino so I don't know what I don't know.
#include <Arduino.h>
#include <PWM.h>
#include <IRremote.hpp>
// Motor Connections (All must use PWM pins)
// ML is Motor Left
#define ML1 9
#define ML2 10
// MR is Motor Right
#define MR1 3
#define MR2 11
// MM is Motor Middle
#define MM1 5
#define MM2 6
#define IR_RECEIVE_PIN A5
//Button layout for IR Remote: Power-1, Plus-14, Minus-20, Up-22, Down-26, Stop-41
// Define a fixed speed - do not exceed 250
int fixedSpeed = 240;
//define the pwm frequency
int pwmFreq = 20000;
// Set motor & enable connections as outputs
pinMode(ML1, OUTPUT);
pinMode(ML2, OUTPUT);
pinMode(MR1, OUTPUT);
pinMode(MR2, OUTPUT);
pinMode(MM1, OUTPUT);
pinMode(MM2, OUTPUT);
pinMode(IR_RECEIVE_PIN, INPUT);
//initialize all timers except for 0, to save time keeping functions
InitTimersSafe();
//sets the frequency for the specified pin
SetPinFrequencySafe(ML1, pwmFreq);
SetPinFrequencySafe(ML2, pwmFreq);
SetPinFrequencySafe(MR1, pwmFreq);
SetPinFrequencySafe(MR2, pwmFreq);
SetPinFrequencySafe(MM1, pwmFreq);
SetPinFrequencySafe(MM2, pwmFreq);
// Stop motors
pwmWrite(ML1, 0);
pwmWrite(ML2, 0);
pwmWrite(MR1, 0);
pwmWrite(MR2, 0);
pwmWrite(MM1, 0);
pwmWrite(MM2, 0);
IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
// initialize IR Receiver
if (IrReceiver.decode()) {
int IRread = IrReceiver.decodedIRData.command;
// read IR Remote button push
switch(IRread) {
case 26: // open button
// extend all motors
pwmWrite(ML2, 0);
pwmWrite(ML1, fixedSpeed);
pwmWrite(MR2, 0);
pwmWrite(MR1, fixedSpeed);
pwmWrite(MM2, 0);
pwmWrite(MM1, fixedSpeed);
case 22: // close button
// retract all motors
pwmWrite(ML1, 0);
pwmWrite(ML2, fixedSpeed);
pwmWrite(MR1, 0);
pwmWrite(MR2, fixedSpeed);
pwmWrite(MM1, 0);
pwmWrite(MM2, fixedSpeed);
case 41: // stop button
// stop all motors
pwmWrite(ML1, 0);
pwmWrite(ML2, 0);
pwmWrite(MR1, 0);
pwmWrite(MR2, 0);
pwmWrite(MM1, 0);
pwmWrite(MM2, 0);
IrReceiver.resume();
