Time running before on switch
#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(
    0x27, 16, 2);  // double check your LCD address first using: i2C_scanner
int analogOutPin1 = A1;  // finish line beam lane 1 on A1 PIN
int analogOutPin2 = A2;  // finish line beam lane 2 on A2 PIN
const int ledPin1 = 11;  // lane 1 winning LED on D11 PIN
const int ledPin2 = 12;  // Lane 2 winning LED in D12 PIN
int StartSwitch = 2;
int sensorValueFinish1 = 0;
int sensorValueFinish2 = 0;
int StartState = 0;
int sensorThresh = 500;  // Sets the trigger sensing threshold of the IR
                         // receivers. ~1000 = high
unsigned long timeLane1;  // finish line lane 1
unsigned long timeLane2;  // finish line lane 2
float StartTime = 0;
float ET1 = 0;
float ET2 = 0;
  pinMode(StartSwitch, INPUT);
  pinMode(ledPin1, OUTPUT);  // lane 1
  pinMode(ledPin2, OUTPUT);  // lane 2
  digitalWrite(ledPin1, HIGH);
  digitalWrite(ledPin2, HIGH);
  delay(2000);
  digitalWrite(ledPin1, LOW);
  digitalWrite(ledPin2, LOW);
  StartTime = 0;
  lcd.begin(16, 2);
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("MARI BRAMBAK");
  lcd.setCursor(0, 1);
  lcd.print("By: KUHOWC");
  delay(6000);
  lcd.print("Ready to race...");
  StartState = digitalRead(
      StartSwitch);  // Check state of start gate. 0 = closed & 1 = open.
  if (StartState == 0) {
    StartTime = 0;
    ET1 = 0;
    ET2 = 0;
      StartSwitch);  // if start gate is trigger, race started. 1 = open.
  if (StartState == 1 && StartTime == 0) {
    StartTime =
        micros();  // use micro seconds since the races can be that close!
  // read the analog in value of IR's:
  sensorValueFinish1 = analogRead(analogOutPin1);
  sensorValueFinish2 = analogRead(analogOutPin2);
  // remove "//" from below for Debugging and checking actual sensor values.
  // You may have to adjust sensorThresh value for better accuracy.
  // The sensors should read around 900-1000 then go "low" (less than 400) when
  // a car passes through the beam.
  Serial.println(StartTime);
  Serial.println(StartState);
  Serial.print("Sensor Finish1 = ");
  Serial.println(sensorValueFinish1);
  Serial.print("Sensor Finish2 = ");
  Serial.println(sensorValueFinish2);
  delay(50);
  // wait/check for the Finish Line sensors to be triggered
  if (sensorValueFinish1 < sensorThresh && ET1 == 0) {
    timeLane1 = micros();
    ET1 = timeLane1 - StartTime;
    ET1 = ET1 / 1000000;
  if (sensorValueFinish2 < sensorThresh && ET2 == 0) {
    timeLane2 = micros();
    ET2 = timeLane2 - StartTime;
    ET2 = ET2 / 1000000;
  if (ET1 < ET2 && ET1 != 0 &&
      ET2 != 0)  // Set winner Lane 1, turn on winner LED
  if (ET1 > ET2 && ET2 != 0 &&
      ET1 != 0)  // Set winner Lane 2, turn on winner LED
  if (ET1 > 0 && ET2 > 0)  // Race is over, display times for both lanes. //
                           // both cars have to finish to display times.
    lcd.clear();
    lcd.print("L1");
    lcd.setCursor(4, 0);
    lcd.print("ET:");
    lcd.setCursor(6, 0);
    lcd.print(ET1, 4);
    if (digitalRead(ledPin1) == HIGH) {
      lcd.setCursor(12, 0);
      lcd.print("WIN");
    lcd.print("L2");
    lcd.setCursor(4, 1);
    lcd.print("ET:");
    lcd.setCursor(6, 1);
    lcd.print(ET2, 4);
    if (digitalRead(ledPin2) == HIGH) {
      lcd.setCursor(12, 1);
      lcd.print("WIN");
    delay(100);
    digitalWrite(ledPin1, LOW);  // turn off lane winner LED
    digitalWrite(ledPin2, LOW);  // turn off lane winner LED
    timeLane1 = 0;
    timeLane2 = 0;
    StartTime = 0;
    ET1 = 0;
    ET2 = 0;
  }`Preformatted text`
Please always use code tags (this button in the editor window "</>") when posting code.
Your code to start the timer
  StartState = digitalRead(StartSwitch); //if start gate is trigger, race started. 1 = open.
    StartTime = micros(); //use micro seconds since the races can be that close!
... will be true as soon as the program starts. There is nothing to stop the rest of your code running after that.
Rather than looking for a HIGH or LOW value from the start button, you should look for a change from HIGH to LOW, or LOW to HIGH to detect a button press/release.
i make this. copy from youtuber mike freda.
done upload but time running before on the switch.
i hope anyone can solve..
Version 2 Layout.pdf (34.2 KB)
 // Time when start gate is open.
// First car to break IR beam is the lane winner
// Displays Elapsed time and winner on a 16x2 LCD.
// times resets when start gate is closed.
// Calculated time is in microseconds and gets converted to Seconds when
// displayed. Races can be that close. Uses Gikfun 5mm 940nm IR LED's emitters
// and receivers: EK8443
<#include <LiquidCrystal.h>
#include <Wire.h>
int StartState = 0;
float ET1 = 0;
float ET2 = 0;
  delay(2000);
  StartTime = 0;
  lcd.begin(16, 2);
  lcd.backlight();
  delay(6000);
    StartTime = 0;
    ET1 = 0;
    ET2 = 0;
    StartTime =
  //             than 400) when a car passes through the beam.
  delay(50);
    lcd.clear();
    lcd.print("L1");
    lcd.print("ET:");
    lcd.print(ET1, 4);
      lcd.print("*WIN*");
    lcd.print("L2");
    lcd.print("ET:");
    lcd.print(ET2, 4);
      lcd.print("*WIN*");
    delay(100);
    timeLane1 = 0;
    timeLane2 = 0;
    StartTime = 0;
    ET1 = 0;
    ET2 = 0;
type or paste code here
