timer based PWM for port expander
Hello,
I am working on trying to make three 7-segment displays dim according to input from a potentiometer. I am using the MCP23017 port expander attached to an UNO board to control each section of the displays. I am not having any problem with the code that makes the displays run, just with my minimal code to try to get my software timer PWM to work the way I want it to. So the goal of the code I've attached below is to dim the onboard LED attached to pin13 to dim according to the input from the pot. I'm using an interrupt on overflow on Timer2 to control the period and an interrupt on compare on Timer0(CTC mode) to control the pulse width. The problem that I am having is that I cannot figure out why the Timer0 interrupt is not firing? From what I understand from the datasheet, the CTC mode will start the ISR when the TCNT0 register hits the same value as the OCR0A register.
So now that I think I've described my problem clearly, I have two questions:
  1. Is there a better way to control dimming on the port expander (I'm using I2C to talk to it)?
  2. Why is the Timer0 interrupt not working (The ISR increments a counter every time it fires but the counter value is never changing, which says to me that the ISR is never firing)?
const int ledPin =  13;
int ledState = LOW;
long previousMillis = 0;
long interval = 1000;
volatile int overflowCount = 0;
int lastCount = 0;
volatile int count2 = 0;
int lastCount2 = 0;
unsigned int tcnt2 = 0;
unsigned int tcnt0 = 0;
int toggle = 0;
int POT = A1;
volatile int potVal = 50;
int lastPot = 0;
ISR(TIMER2_OVF_vect) // interrupt service routine that executes when Timer2
                     //overflows
  TCNT2 = tcnt2;
  TCNT0 = tcnt0;
//  digitalWrite(ledPin, toggle == 0 ? HIGH : LOW);
//  toggle = ~toggle;
  ++overflowCount;
  digitalWrite(ledPin, HIGH);
ISR(TIMER0_COMPA_vect)  //interrupt service routine that executes when Timer0
                        //matches OCR0A (potVal)
  ++count2;
  digitalWrite(ledPin, LOW);
  pinMode(ledPin, OUTPUT);
//Timer2 for LED turn on
  TIMSK2 &= ~(1<<TOIE2);  //dissable interrupt while configuring
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));  // configure timer2 in normal mode
                                         //counting up with no PWM
  TCCR2B &= ~(1<<WGM22);
  ASSR   &= ~(1<<AS2);  //select internal clock source
  TIMSK2 &= ~(1<<OCIE2A);  //disable Compare Match A interrupt enable
  TCCR2B |= /*(1<<CS20) |*/ (1<<CS21) | (1<<CS22);  //set bits
  TCCR2B &= ~((1<<CS20) /*| (1<<CS21) | (1<<CS22)*/);  //clear bits
  TCNT2   = tcnt2;
  TIMSK2 |= (1<<TOIE2);  //interrupt on Timer2 overflow
//Timer0 for LED turn off
  TCCR0A |= (1<<WGM01);  //CTC mode
  OCR0A   = potVal;
  TIMSK0 |= (1<<OCIE0A);  //interrupt on Compare A match enable
  TCNT0   = tcnt0;
  TCCR0B |= /*(1<<CS00) |*/ (1<<CS21) | (1<<CS22);  //set bits
  TCCR0B &= ~((1<<CS00) /*| (1<<CS21) | (1<<CS22)*/);  //clear bits
  potVal = analogRead(POT);
  if ((potVal > (lastPot+25)) | (potVal < (lastPot-25)))
    potVal = potVal/4;
    OCR0A = potVal;
  if (overflowCount > lastCount)
      lastCount = overflowCount;
//      Serial.print("overflow = ");
//      Serial.println(overflowCount);
      Serial.print("POT = ");
      Serial.println(potVal);
    if (count2 > lastCount2)
      Serial.print("count = ");
      lastCount2 = count2;
      Serial.println(count2);
So I managed to fix part of my problem, I got the Timer0 CTC mode to work. However, it lead to a new question, for some reason it only worked with a prescale of 64 or less, it wouldn't work with 128 or 1024. Does anyone have an idea of why that would be?
here is the fixed code (my problem was that I was trying to use the CS bits for timer2 instead of timer0 to set the prescale, very silly typo :disappointed_relieved: )
int ledState = LOW;
volatile int count = 0;
int lastCount = 0;
int lastCount2 = 0;
int toggle = 0;
int POT = A1;
int lastPot = 0;
//overflows (happens at just under 61 Hz)
  TCNT2 = tcnt2;
  TCNT0 = tcnt0;
  ++count;
  ++count2;
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));  // Timer2 normal mode couting up, no PWM
  TCCR2B |= (1<<CS21) | (1<<CS20);  //set bits 64 prescale
  TCNT2   = tcnt2;
  TCCR0A &= ~((1<<COM0A1) | (1<<COM0A0));
  interrupts();
  OCR0A   = 128;
  TCCR0B |= ((1<<CS01) | (1<<CS00));  //set bits 64 prescale
    potVal = potVal/4;
    OCR0A = potVal;
  if (count > lastCount)
    lastCount = count;
    Serial.println(count);
    Serial.print("count2 = ");
