Timer ISR
I tried to copy and run example of how to use hardware timers to trigger an ISR. I used the more or less identical information from
and
my code is:
int timer = 0;  //volatile?
bool state = 0;
  pinMode(LED_BUILTIN, OUTPUT);
  //cli();//stop interrupts //notwendig?
  TCCR0A = (1 << WGM01); //Set the CTC mode, clear timer on compare,   prescaler config
  OCR0A = 77; //Value for ORC0A for 1ms
  TIMSK0 |= (1 << OCIE0A); //Set the interrupt request
  sei(); //Enable interrupt warum nicht am ende?
  TCCR0B |= (1 << CS02); //Set the prescale 1/1024 clock
  TCCR0B |= (1 << CS00);
  //in this way you can count 1 second because the interrupt request is each 1ms
  if (timer >= 1000) {
    state = !state;
    timer = 0;
  digitalWrite(LED_BUILTIN, state);
ISR(TIMER0_COMPA_vect) {   //This is the interrupt request
  timer++;
My problem is, that my compiler doesn't know these register names, and ISR(). None of the examples uses an include, for them it works right away. What do I have to include to make it work?
A part of the error messages:
Arduino: 1.8.13 (Windows 8.1), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
timer:55:5: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\xxxxxxx\Documents\Arduino\timer\timer.ino: In function 'void setup()':
timer:36:3: error: 'TCCR0A' was not declared in this scope
timer:36:18: error: 'WGM01' was not declared in this scope
timer:37:3: error: 'OCR0A' was not declared in this scope
timer:39:3: error: 'TIMSK0' was not declared in this scope
C:\Users\xxxxxxx\Documents\Arduino\timer\timer.ino: At global scope:
timer:55:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
Clue:
Google "esp8266 timer"
As you yourself wrote recently
Everything is a lot different on the ESP8266 Nodemcu.
TheMemberFormerlyKnownAsAWOL:
Clue:
What do you mean with this clue? This processor doesnt have such timers?
I found the "ticker" also, and it works smoothly so far and it is easy to set up. But I thougt I should get the other way working too.
Thanks for the hint, I will read this:
The processor undoubtedly has timers
But they're not AVR timers.
And I found out my other hardware the Esp32 is different again.
Yep.
If it helps someone, this is an example code for the ESP8266 timer:
    ESP8266 Timer Example
    Hardware: NodeMCU
    Circuits4you.com
    2018
    LED Blinking using Timer
  Höhere Frequenzen als Ticker
  Timer0 von Wifi belegt, Timer1 frei
#include <ESP8266WiFi.h>
void ICACHE_RAM_ATTR onTimerISR() {
  digitalWrite(LED_BUILTIN, !(digitalRead(LED_BUILTIN))); //Toggle LED Pin
 // timer1_write(600000);//12us   //start again if TIM_SINGLE
//                               Setup
  timer1_attachInterrupt(onTimerISR);
  timer1_enable(TIM_DIV256, TIM_EDGE, TIM_LOOP);
  /* Dividers:
    TIM_DIV1 = 0,   //80MHz (80 ticks/us - 104857.588 us max)
    TIM_DIV16 = 1,  //5MHz (5 ticks/us - 1677721.4 us max)
    TIM_DIV256 = 3  //312.5Khz (1 tick = 3.2us - 26843542.4 us max)
    Reloads:
    TIM_SINGLE  0 //on interrupt routine you need to write a new value to start the timer again
    TIM_LOOP  1 //on interrupt the counter will start with the same value again
  timer1_write(31249); //100 ms // for fclk=80MHz  (fclck/prescale*t)-1  Register 32bit?
//                MAIN LOOP
  delay(1000);  //works while delaying
