Timer Interrupt using ISR
My interrupt code will not compile without errors:
  Interrupt Test Program
    - 2/24/2025
  Author: Terry Benson
// Arduino NANO 33 IoT board selected
#include "SAMDTimerInterrupt.h" // This has no affect on the errors
bool ledOn = false;
const unsigned long TIME_TICKS = 7500; // for 10 ms interrupts at 48 MHz
const bool PRESCALER = B00000011; // Prescaler of 64
const bool ENABLE_ISR = B00000010; // Enable the ISR to generate an interrupt
// ISR for the switch debounce functions using timer 1
ISR (TIMER1_COMPA_vect)
    ledOn = !ledOn;   // toggle led
    if (ledOn) {
      digitalWrite(LED_BUILTIN, HIGH);
      digitalWrite(LED_BUILTIN, LOW);
} // End of ISR
//  flash the LED at the interrupt rate
  pinMode(LED_BUILTIN, OUTPUT);
  ledOn = false;
// Set up timer for 10 ms interrupts
  TCCR1A = 0;           // Init Timer1A
  TCCR1B = 0;           // Init Timer1B
  TCCR1B |= PRESCALER;  // Set Prescaler
  OCR1A = TIME_TICKS;   // Timer Compare1A Register
  TIMSK1 |= ENABLE_ISR; // Enable Timer COMPA Interrupt
  // set up main function here
I get these errors among others (with or without the Included library):
TimerISR_Test\TimerISR_Test.ino:16:5: error: expected constructor, destructor, or type conversion before '(' token
TimerISR_Test\TimerISR_Test.ino:34:3: error: 'TCCR1A' was not declared in this scope
Do I need to use different names for the Timer Registers?
That code will work only on the Arduino Uno R3 or related AVR processors.
Yes, and the interrupts have more than likely different names.
Topic moved to the dedicated Nano33 IoT section of the forum. Do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
Thanks for the response. I'll change to the NANO board.
