I would need a timer that when you start it with push button it turns led from state one to another and starts 7 sec timer when 7 sec is gone it turns led back to original state and starts 3 sec timer.
This 7 sec - 3 sec should be repeated 5 times. Then from pushing the button sequence should start again.
push button green led turns to red 7 sec delay led turns green 3 sec delay led turns red 7 sec delay led turns green 3 sec delay led turns red 7 sec delay led turns green 3 sec delay led turns red 7 sec delay led turns green 3 sec delay led turns red 7 sec delay led turns green 3 sec delay led turns red 15 sec delay led turns green. You can start sequence again by push button.
You can do something along the lines of press the button and enter a while loop. Inside you have a simple variable that increments by 1 all the way to 5 every ten seconds. (I chose to start at 5 and decrement instead)
Now out of those ten seconds, you have an IF statement looking at the seconds increase. First you turn on the red LED and once the seconds is greater than 7, you turn off the red LED and turn on the green LED.
Something like this, (this was not tested). Make sure your button is wired to be brought to ground when pressed
#define RED_ON do{digitalWrite(redLED, HIGH);digitalWrite(greenLED, LOW);}while(0)
#define GRN_ON do{digitalWrite(redLED, LOW);digitalWrite(greenLED, HIGH);}while(0)
#define BothOff do{digitalWrite(redLED, LOW);digitalWrite(greenLED, LOW);}while(0)
const byte buttonPin = 2;
const byte redLED = 3;
const byte greenLED =4;
unsigned long prevTime = 0;
byte seconds = 0;
byte cycle = 5;
pinMode(buttonPin, INPUT_PULLUP);
pinMode(redLED, OUTPUT);
pinMode(greenLED, OUTPUT);
if (digitalRead(buttonPin) == LOW) // if the button was pressed ie brought to GND, go in
prevTime = micros(); // get the current time in microseconds
cycle = 5; // reset cycle to 5
while (cycle != 0) // keep checking until cycle == 0
if (micros() - prevTime >= 1000000UL) // 1 second timer
seconds++; // increment the variable "seconds" by 1
if (seconds > 10) // if seconds is greater than 10, reset it back to 0 and decrement cycle by 1
seconds = 0;
cycle--;
prevTime += 1000000UL; // increment prevTime by the interval of 1 second (1000000 microseconds)
if (seconds < 7) // if seconds is less than 7, turn on red LED
RED_ON;
else // otherwise turn on green LED
GRN_ON;
BothOff;
*You might need to play with the cycle and seconds numbers. I think they may be 1 too many.
Here is code using the State Machine concept.
You will have to add some code to finish your sequence.
//State Machine example
//LarryD
unsigned long TaskWait;
unsigned long currentmillis;
const byte redLED = 2;
const byte greenLED = 3;
const byte startSwitch = 4;
//define the available machine states that we can have for this sketch
//add more states as needed
enum States{
stateZERO, stateONE, stateTWO, stateTHREE, stateFOUR, stateFIVE, stateSIX, stateSEVEN, stateEIGHT, stateTEN};
//mState = machine State
States mState = stateZERO; //we start out in this machine state
//start with the green LED on
digitalWrite(greenLED,HIGH); //anode to the pin, cathode to 220 ohm resistor, other end of 220 to GND
pinMode(startSwitch, INPUT_PULLUP); //one side of my switch is connected to GND, the other to the pin
TaskWait = millis(); //initialize the next wait time
} // >>>>>>>>>>>>>> E N D O F s e t u p ( ) <<<<<<<<<<<<<<<<<
//leave this line of code at the top
currentmillis = millis();
//Put your non-blocking regular stuff here
//Check machine state and do things that must be done accordingly
switch (mState)
case stateZERO:
//let us see if the switch is pushed
if(!digitalRead(startSwitch))
digitalWrite(greenLED,LOW); //this LED OFF
digitalWrite(redLED,HIGH); //this LED ON
mState = stateONE; //advance to the next state
beak; //end case stateZERO:
case stateONE:
if (CheckTime(TaskWait, 7000UL))
digitalWrite(greenLED,HIGH); //this LED ON
digitalWrite(redLED,LOW); //this LED OFF
mState = stateTWO; //advance to the next state
break; //end case stateONE:
case stateTWO:
if (CheckTime(TaskWait, 3000UL))
mState = stateTHREE; //advance to the next state
break; //end of stateTWO
case stateTHREE:
mState = stateFOUR; //advance to the next state
break; //end of stateTHREE
case stateFOUR:
mState = stateFIVE; //advance to the next state
break; //end of stateFOUR
case stateFIVE:
mState = stateZERO; //advance to the next state <------<<<< Change to stateSIX
break; //end of stateFIVE
//Y O U R T U R N T O A D D S O M E S T A T E S
} // end of switch(mState)
} // >>>>>>>>>>>>>> E N D O F l o o p ( ) <<<<<<<<<<<<<<<<<
// F U N C T I O N S
//Delay time expired function
boolean CheckTime(unsigned long &lastMillis, unsigned long wait)
//is the time up for this task?
if (currentmillis - lastMillis >= wait)
lastMillis += wait; //get ready for the next iteration
return true;
return false;
} //END of CheckTime()
// E N D O F C O D E
I really like newbies. And they need simple answers.
So my code is just doing what you are looking for without any state-of-the art code.
Read my comments in the code and you will understand how it works.
If you need LED timing AND other code execution look for things like "blink without delay".
I think my code will just do what you asked for.
I just set up the hardware and tested the code - so this does work - according to German style
arduinoaleman - June 2015
// simple code by arduinoaleman
// codestructure is optimized for understanding by newbies and nor for efficiency
// HARDWARE SETUP:
// connect your LEDS to your output pins using 220 ohms resistors
// connect your switch to your INPUT pin and ground
// also connect a 10 kilo ohms resistor from your INPUT pin to +5 Volts
const int LED_green = 8; // use your own pin numbers here
const int LED_red = 9;
const int inputswitch = 3;
pinMode (LED_green, OUTPUT);
pinMode (LED_red, OUTPUT);
pinMode (inputswitch, INPUT); // this line is not required - just tells you it is INPUT (default setting)
digitalWrite (LED_red,LOW);
digitalWrite (LED_green,LOW);
while (digitalRead(inputswitch)==HIGH); // wait until switch is pressed
for (int number=1; number <=5; number=number+1) { // this loop will execute the following code 5 times
digitalWrite (LED_red,HIGH); // switch ON red LED
delay (7000); // wait 7000 milliseconds = 7 seconds
digitalWrite (LED_red,LOW); // switch OFF red LED
digitalWrite (LED_green,HIGH); // switch ON green LED
delay (3000); // wait 3000 milliseconds = 3 seconds
digitalWrite (LED_green,LOW); // switch OFF green LED
} // end of loop ("number" is how often you want to reapeat the loop
Timo
What happens if you push the button during the sequence? Do you want the sequence to continue normally? Or do you want it to start over from the beginning? Or what?
I'm using Arduino Nano and for some reason it burns red and green led at the same time, but not green at all on it own state?!
Any ideas or suggestions?
D4 switch, switch between gnd and D4, also Vin+ thru 10Kohm resistor to D4
D3 green led, thru resistor to gnd
D2 red led, thru resistor to gnd
Vin +
Gnd -
Timo
There is an internal pull-up resistor on D4 already so you don't need the 10K (wont hurt though).
LED Anode to the pin, cathode to 220 ohm resistor, other end of 220 to GND
const byte greenLED = 4;
byte seconds = 0;
byte cycle = 5;
if (cycle != 0) // keep checking until cycle == 0
seconds = 0;
cycle--;
RED_ON;
GRN_ON;
BothOff;
