I want a function in my arduino code to run for every 6ns of time
The Due has a 84 MHz clock. if my math is correct you get one tick every ~12ns...
also how long would that function run for (including calling time and context switching)?
can you give me a sample example
an example of what?
did you understand the clock issue for your needs?
give an example of arduino code which execute a function for every 6ns of time.
Any example is fine(for arduino due)
Do you understand what this means?
here is my best example:
that will run as fast as possible and yet x won't even be incremented every 6ns
volatile byte x = 0;
void setup() {}
void loop() {while(true) x++;}
If the clock ticks every 12 ns, you cannot do anything in between...
And most functions would take more than one tick.
So: forget about it.
