Hello all,
I am looking to add a Time readout that counts up for the duration the output is active, when the output the timer would drop to nil.
My problem is most likely not knowing the right search terms.
Project is fairly simple. Hardware is:
Arduino Uno
BME280
20x4 LCD
LED's
buttons
Output to a solid state relay. This is what i want to know how long its been on.
I read the temp and report it to the LCD
I read the millis and report it to the LCD
I switch the relay output between the 2 temps i have set
2 temps are variable with the buttons.
My code:
#include "cactus_io_BME280_I2C.h"
BME280_I2C bme(0x76); //BM280 address
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 20 chars 4 line display
const int r1_pin = 10; //Solid State Relay 1
const int led1 = 13; //Red Led used to indicate relay on (Heat on)
const int led2 = 12; //Yellow Led used to indicate standby, relay off (Heat Off)
const int led3 = 11; //Green Led used to indicate program is running through its loop
int r1state = LOW; // SSR state setting
const int B1pin = 2; //Button for templow incriment +
const int B2pin = 3; //Button for templow incriment -
const int B3pin = 4; //Button for temphigh incriment +
const int B4pin = 5; //Button for temphigh incriment -
int B1State; // the current reading from the input pin
int B2State; // the current reading from the input pin
int B3State; // the current reading from the input pin
int B4State; // the current reading from the input pin
int lastB1State = LOW; // the previous reading from the input pin
int lastB2State = LOW; // the previous reading from the input pin
int lastB3State = LOW; // the previous reading from the input pin
int lastB4State = LOW; // the previous reading from the input pin
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
float templow = 19; // Temperature realy will switch on
float temphigh = 20;// Temperature relay will switch off
unsigned long previousMillis = 0UL; //timing setup
unsigned long interval = 100UL; //timing delay setting
void setup(){
pinMode(r1_pin, OUTPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(B1pin, INPUT_PULLUP);
pinMode(B2pin, INPUT_PULLUP);
pinMode(B3pin, INPUT_PULLUP);
pinMode(B4pin, INPUT_PULLUP);
lcd.init(); // initialize the lcd
lcd.backlight(); // initialize the backlight for lcd
Serial.begin(115200) ;
if (!bme.begin()) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);}
bme.setTempCal(-1); // Temp calibration setting in Cecius
lcd.setCursor(0,0); lcd.print("Temp ");
lcd.setCursor(11,0); lcd.print("Heat");
lcd.setCursor(0,1); lcd.print("Low ");
lcd.setCursor(0,2); lcd.print("High");
bme.readSensor();
//======================== BUTTON INPUT SECTION ==================
int reading = digitalRead(B1pin);// read the state of the switch into a local variable:
//check to see if you just pressed the button (i.e. the input went from LOW to HIGH), and you've waited long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastB1State) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != B1State) {
B1State = reading;
// only toggle the LED if the new button state is HIGH
if (B1State == HIGH) {
templow = templow+0.1;
lastB1State = reading;
int reading = digitalRead(B2pin);// read the state of the switch into a local variable:
if (reading != lastB2State) {
if (reading != B2State) {
B2State = reading;
if (B2State == HIGH) {
templow = templow-0.1;
lastB2State = reading;
int reading = digitalRead(B3pin);// read the state of the switch into a local variable:
if (reading != lastB3State) {
if (reading != B3State) {
B3State = reading;
if (B3State == HIGH) {
temphigh = temphigh+0.1;
lastB3State = reading;
int reading = digitalRead(B4pin);// read the state of the switch into a local variable:
if (reading != lastB4State) {
if (reading != B4State) {
B4State = reading;
if (B4State == HIGH) {
temphigh = temphigh-0.1;
lastB4State = reading;
//======================== HEAT CONTROL SECTION ==================
if(currentMillis - previousMillis > interval)
if (bme.getTemperature_C() < (templow)) {digitalWrite(r1_pin, LOW); digitalWrite(led1, HIGH); digitalWrite(led2, LOW); lcd.setCursor(16,0); lcd.print("ON.");}
else if (bme.getTemperature_C() >= (temphigh)){digitalWrite(r1_pin, HIGH); digitalWrite(led1, LOW); digitalWrite(led2, HIGH); lcd.setCursor(16,0); lcd.print("OFF");
//======================== LCD OUTPUT SECTION ====================
lcd.setCursor(5,0); lcd.print(bme.getTemperature_C());
lcd.setCursor(0,3); lcd.print(millis() / 1000);
lcd.setCursor(5,1); lcd.print(templow);
lcd.setCursor(5,2); lcd.print(temphigh); }
My code is not the best i imagine, its not my strong suit. I did notate most of it when i was doing debugging due to a LCD freezing issue, i changed all the hardware and the issue persisted. tried different library's and it persisted. Then i seen mention of EMF causing issues and i started looking at me relay setup. i was running a relay board to switch a 24VAC contactor, as soon as i swapped the contactor to a SSR it solved the issue.
Anyways hoping someone has a better search term i can use that will find something beyond "Blink Without Delay"
Cheers
