I am trying to control a Sony VideoCamera through an RC Transmitter.
The Lanc Code I am using is from Michael Koch,
The Code works great, but if I add my pulsein Code for reading PPM/PWM Signal from the Reciever,
button = pulseIn(ppmSwitch, HIGH, 20000);
poti = pulseIn(ppmPoti, HIGH, 20000);
the Zoom & Focus Control is choppy, because of the 20000ms Timing needed for reading the Pwm Signals.
How could I overcome the Problem?
#define cmdPin 7
#define lancPin 11
#define ppmPoti 13
#define ppmSwitch 4
int cmdRepeatCount;
int bitDuration = 104; //Duration of one LANC bit in microseconds.
int button;
int poti;
int recordstate = 0;
//Start-stop video recording
boolean REC[] = {LOW,LOW,LOW,HIGH,HIGH,LOW,LOW,LOW, LOW,LOW,HIGH,HIGH,LOW,LOW,HIGH,HIGH}; //18 33
//Zoom in from slowest to fastest speed
boolean ZOOM_IN_0[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW}; //28 00
boolean ZOOM_IN_1[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,LOW,LOW,HIGH,LOW}; //28 02
boolean ZOOM_IN_2[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,LOW,HIGH,LOW,LOW}; //28 04
boolean ZOOM_IN_3[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,LOW,HIGH,HIGH,LOW}; //28 06
boolean ZOOM_IN_4[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,HIGH,LOW,LOW,LOW}; //28 08
boolean ZOOM_IN_5[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,HIGH,LOW,HIGH,LOW}; //28 0A
boolean ZOOM_IN_6[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,HIGH,HIGH,LOW,LOW}; //28 0C
boolean ZOOM_IN_7[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,LOW,HIGH,HIGH,HIGH,LOW}; //28 0E
//Zoom out from slowest to fastest speed
boolean ZOOM_OUT_0[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,LOW,LOW,LOW,LOW}; //28 10
boolean ZOOM_OUT_1[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,LOW,LOW,HIGH,LOW}; //28 12
boolean ZOOM_OUT_2[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,LOW,HIGH,LOW,LOW}; //28 14
boolean ZOOM_OUT_3[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,LOW,HIGH,HIGH,LOW}; //28 16
boolean ZOOM_OUT_4[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,HIGH,LOW,LOW,LOW}; //28 18
boolean ZOOM_OUT_5[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,HIGH,LOW,HIGH,LOW}; //28 1A
boolean ZOOM_OUT_6[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,HIGH,HIGH,LOW,LOW}; //28 1C
boolean ZOOM_OUT_7[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,LOW,LOW,HIGH,HIGH,HIGH,HIGH,LOW}; //28 1E
Focus Control - not in Use
//Focus control. Camera must be switched to manual focus
boolean FOCUS_NEAR[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,HIGH,LOW,LOW,LOW,HIGH,HIGH,HIGH}; //28 47
boolean FOCUS_FAR[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,HIGH,LOW,LOW,LOW,HIGH,LOW,HIGH}; //28 45
boolean FOCUS_AUTO[] = {LOW,LOW,HIGH,LOW,HIGH,LOW,LOW,LOW, LOW,HIGH,LOW,LOW,LOW,LOW,LOW,HIGH}; //28 41
pinMode(lancPin, INPUT); //listens to the LANC line
pinMode(cmdPin, OUTPUT); //writes to the LANC line
pinMode(ppmSwitch, INPUT); //PPM RX Switch Input
pinMode(ppmPoti, INPUT); //PPM RX Poti Input
digitalWrite(cmdPin, LOW); //set LANC line to +5V
delay(5000); //Wait for camera to power up completly
bitDuration = bitDuration - 8; //Writing to the digital port takes about 8 microseconds so only 96 microseconds are left for each bit
if(button>1500 && recordstate==0)
recordstate = 1;
lancCommand(REC);
if(button<1400 && recordstate==1)
recordstate = 0;
lancCommand(REC);
if (poti>1580 && poti<1630){lancCommand(ZOOM_IN_0);}
if (poti>1630 && poti<1680){lancCommand(ZOOM_IN_1);}
if (poti>1680 && poti<1730){lancCommand(ZOOM_IN_2);}
if (poti>1730 && poti<1780){lancCommand(ZOOM_IN_3);}
if (poti>1780 && poti<1830){lancCommand(ZOOM_IN_4);}
if (poti>1830 && poti<1880){lancCommand(ZOOM_IN_5);}
if (poti>1880 && poti<1930){lancCommand(ZOOM_IN_6);}
if (poti>1930){lancCommand(ZOOM_IN_7);}
if (poti<1420 && poti>1370){lancCommand(ZOOM_OUT_0);}
if (poti<1370 && poti>1320){lancCommand(ZOOM_OUT_1);}
if (poti<1320 && poti>1270){lancCommand(ZOOM_OUT_2);}
if (poti<1270 && poti>1220){lancCommand(ZOOM_OUT_3);}
if (poti<1220 && poti>1170){lancCommand(ZOOM_OUT_4);}
if (poti<1170 && poti>1120){lancCommand(ZOOM_OUT_5);}
if (poti<1120 && poti>1070){lancCommand(ZOOM_OUT_6);}
if (poti<1070){lancCommand(ZOOM_OUT_7);}
void lancCommand(boolean lancBit[]) {
cmdRepeatCount = 0;
while (cmdRepeatCount < 5) { //repeat 5 times to make sure the camera accepts the command
while (pulseIn(lancPin, HIGH) < 5000) {
//"pulseIn, HIGH" catches any 0V TO +5V TRANSITION and waits until the LANC line goes back to 0V
//"pulseIn" also returns the pulse duration so we can check if the previous +5V duration was long enough (>5ms) to be the pause before a new 8 byte data packet
//Loop till pulse duration is >5ms
//LOW after long pause means the START bit of Byte 0 is here
delayMicroseconds(bitDuration); //wait START bit duration
//Write the 8 bits of byte 0
//Note that the command bits have to be put out in reverse order with the least significant, right-most bit (bit 0) first
for (int i=7; i>-1; i--) {
digitalWrite(cmdPin, lancBit[i]); //Write bits.
//Byte 0 is written now put LANC line back to +5V
delayMicroseconds(10); //make sure to be in the stop bit before byte 1
while (digitalRead(lancPin)) {
//Loop as long as the LANC line is +5V during the stop bit
//0V after the previous stop bit means the START bit of Byte 1 is here
//Write the 8 bits of Byte 1
for (int i=15; i>7; i--) {
digitalWrite(cmdPin,lancBit[i]); //Write bits
//Byte 1 is written now put LANC line back to +5V
cmdRepeatCount++; //increase repeat count by 1
/*Control bytes 0 and 1 are written, now don’t care what happens in Bytes 2 to 7
and just wait for the next start bit after a long pause to send the first two command bytes again.*/
}//While cmdRepeatCount < 5
