timing question - turn off relay
I have a simple alarm.
uses motion sensors. the output 12VDC when in normal, and then open the circuit (0VDC) when in alarm.
I have a latching relay. one pulse to set the relay into alarm.
a second pulse to take it out of alarm
for testing, I was looking to just have the second pulse wait about 5 seconds after the sensors go high.
it seems I am continuously pulsing the relay
int led = 13;
const int buttonPin = 2;
int buttonState = 0;
int lastButtonState = LOW;
int ledState = HIGH;
int interval = 5000;
unsigned long then = 0;
int lastState = HIGH;
int relay1 = 8;
int relay2 = 9;
  pinMode(led, OUTPUT);
  pinMode(buttonPin, INPUT);
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    digitalWrite(led, HIGH);
  else {
    digitalWrite(led, LOW);
  if (buttonState == LOW){ // natural state is high for normal - low is alarm
    if (lastState == HIGH){
      digitalWrite (relay1,HIGH);
      delay (200);        // this is to pulse the relay coil one half second.
      digitalWrite (relay1,  LOW);
  if (buttonState == HIGH){
    if (lastState == LOW){
      then = millis();   //stores the time for the interval
  if (millis()-then > interval ){  // I think this is where I am going wrong
    digitalWrite (relay2, HIGH);
    delay(200);  // this is to pulse the relay coil one half second.
    digitalWrite (relay2,LOW);
  lastState=buttonState;
} // end of loop
I thought that once the sensor value goes high, and it was lastly LOW
that I would set 'then'
so, the timer would start at the time the sensor changed state from low to high.
then the timer would count for 5 seconds and then execute the pulse.
I need to put the
' if millis()-then....'
inside of
if (buttonState == HIGH);
part of my problem, exactly as you found, was that even on the first section, 'then' never re-set to 0 and was always high.,
your idea of adding
'activeAlarm = false;'
will allow me to pulse it one time and then not pulse it again until after it goes changes.
thanks.
still a glitch
I added
 then = millis();
to keep 'then' = mills() unless it was out of alarm
