Timing utility: an alternative to delay()
A small timing utility: can be a non blocking replacement for delay(). The need: execute a function on a timed basis, without blocking the processor with delay(). Independant of the time taken by other running processes. Example of use: flash a led at 3 hertz rate while flashing a second led at 11 hertz, a third at 0,75 Hz, etc. The two main functions: startTimer() and checkTimer.
Have fun!
int tickPeriod = 100; //Défines the duration of one tick in milliSeconds. All timers are incremented at this tick rate.
// Also defines timers resolution. The tickPeriod should be longer than the void-loop duration.
unsigned long int tickCounter = 0; //counts millis divided by tickPeriod.
unsigned int mainTimer = 0; //mainTimer increases every tickPeriod. All declared timers rely on mainTimer to maesure time.
unsigned int timer1[4] = {0, 0, 0, 0 }; //declare 2 timers
unsigned int timer2[4] = {0, 0, 0, 0 };
//EXAMPLE OF USE:
tickTimers(); //Increase all declared timers by one at each tickPeriod milliSeconds.
flashLed1(5); //flash LED 1, period of 1 sec.
flashLed2(7); //flash LED 2, period of 1.4 sec.
// Note: only for demonstration purpose: flashLed could be more efficient...
void flashLed1(int period) {
static unsigned int timer1[4] = {0, 0, 0, 0 };
static byte toggle = 0;
startTimer(timer1, period);
if (checkTimer(timer1)) {
if (toggle == 0) {
Serial.println(" LED 1 is ON");
toggle = 1;
else {
Serial.println(" LED 1 is OFF");
toggle = 0;
void flashLed2(int period) {
startTimer(timer2, period);
if (toggle == 0) {
Serial.println(" LED 2 is ON");
toggle = 1;
else {
Serial.println(" LED 2 is OFF");
toggle = 0;
//------------------------------------- TIMERS UTILITY -------------------------------------
void tickTimers() { //Must be called at least once in a void ... loop
//Increments tickCounter up to tickPeriod, and then increments mainTimer.
if ((unsigned long)(millis() - tickCounter) >= tickPeriod) {
tickCounter += tickPeriod;
Serial.print("time = "); Serial.println(mainTimer); mainTimer ++;
//A timer is an array of 4 unsigned integers.
// array[0] is the timerPeriod: the timer increments up to this Period before checkTimer returns true.
// A null (0) timerPeriod is iterpreted as an infinite Period: the timer is counting but will never end.
// array[1] is the StartedTime: a copy of mainTimer taken when the timer was initially started with startTimer.
// array[2]is the time when timer was paused: a copy of mainTimer when pauseTimer was called.Used to resumeTimer.
// array[3] is the timer status: 0: the timer is running, !=0: the timer is paused.
// PRINCIPLE: To measure time, one takes note of mainTimer when startTimer is called.
// Elapsed time = actual (running) mainTimer minus the originally noted mainCounter.
const byte timerPeriod = 0;
const byte startedTime = 1;
const byte pausedTime = 2;
const byte timerStatus = 3;
const byte timerRunning = 0;
const byte timerPaused = 1;
//-----------------------------ok
void startTimer (unsigned int aTimer[], unsigned int aTimerPeriod) {
//NOTE: **** startTimer has no effect on an already running timer, allowing to call startTimer in a loop; ****
if (aTimer[timerPeriod] != 0) {
return;
else {
aTimer[timerPeriod] = aTimerPeriod; //the timer becomes active:
aTimer[startedTime] = mainTimer; //note the startTime.
void runTimer(unsigned int aTimer[]) {
aTimer[timerStatus] = timerRunning; //let the timer run.
void rewindTimer(unsigned int aTimer[]) { //rewinds the timer to zero and let it run.
void pauseTimer(unsigned int aTimer[]) { // Pause timer
aTimer[pausedTime] = mainTimer; //write a copy of actual time; used by resumeTimer.
aTimer[timerStatus] = timerPaused;
void resumeTimer(unsigned int aTimer[]) { //make a timer run again after beeing paused.
if (aTimer[timerPeriod] == 0) {
return;
aTimer[startedTime] = mainTimer - aTimer[pausedTime] + aTimer[startedTime]; //puts the timer where it was when paused.
aTimer[timerStatus] = timerRunning; //remove pause = run timer
bool checkTimer (unsigned int aTimer[]) { //Checks if the timer arrived at its end.
if (aTimer[timerPeriod] == 0 || aTimer[timerStatus] != timerRunning) { //If timer is not active or paused.
return false;
if (mainTimer - aTimer[startedTime] >= aTimer[timerPeriod]) { // if time elapsed...
aTimer[startedTime] += aTimer[timerPeriod]; //advance the start time.Optionnally: aTimer[startedTime] = mainTimer;Texte préformaté
return true; //return true if time elapsed.
else {
return false;
void setTimerPeriod (unsigned int aTimer[], unsigned int aTimerPeriod) {
aTimer[timerPeriod] = aTimerPeriod; //set new period
aTimer[startedTime] = mainTimer; //rewind timer
//------------------------------------- END OF TIMERS UTILITY -------------------------------------Texte préformaté
Can we expect code tags anytime soon?
@SMATHIEU13, your topic has been moved to a more suitable location on the forum as this has nothing to do with Avrdude, stk500 or Bootloader.
Please edit your post, select all code and click the </> button; next save your post.
@SMATHIEU13, do not cross-post. Other thread removed.
Hi @SMATHIEU13 ,
you should post code in code-tags
look at the screenshots. Especially on how
RE-Editing
a post is done
Once again someone who never learned what we have is going to improve it by adding overhead to make it like what they do know.
Let me know when it comes time to prove so. I had enough of my time and typing wasted I remember well the last one, what a joke.
