TIP120 transistor overheating
hello, i'm having trouble making an arduino controlled seedling/germination heatpad.
I took a heat pad from one of those heated jackets you can get, i plug 5v through it and it works fine, nice and toasty (picture 1).
Now i want my arduino to turn it on /off for me (picture 2). I used a TIP120 transistor, and when the arduino gpio pin goes high to turn it on, the TIP120 gets really hot, and the heat pad doesn't get hot.
What am i doing wrong?
(many thanks)
Why are you using an emitter follower?
  • Show us a good image of your actual wiring.
  • What is the collector current and Vce voltage when the TIP120 is ON ?
  • What is the Arduino output voltage when the TIP120 is ON ?
You should be switching the ground side instead of the +5V power:
Transistor Driver Circuit. (You don't need the flyback diode with a non-inductive load.)
The TIP120 may still need a heatsink, depending on the current.
I assume you meant to reply to the OP rather than me?
i'm not sure what an emitter follower is, tried to google it but got confused. sorry my electronics knowledge is terrible. I thought this would just be a simple circuit, where the TIP120 would just act like a switch as in picture 1.
Known also as "common collector" - Common collector - Wikipedia
I'm not sure what that means to switch the ground side, my electronics knowledge is is terrible. Do you mean put the heat pad between the 5v and collector? i tried that, but the transistor still gets really hot, the heat pad does get a little warm though. Do i need a more efficient transistor?
i'm sorry i don't have a multimeter or access to a camera right now
thanks you i'll give it a read
Slew to 16m24s in this video for a TIP120 example.
Thanks!
  • It should be noted the old TIP120 BJT has a Vce saturation voltage of ~ 2V.
    This means the heater will only see 3V maximum.
  • Today we recommend using (in this case) an N channel logic level MOSFET.
    The MOSFET Vds is close to 0V, therefore the heater would see almost the full 5V.
Thanks! i'll look into it!
  • FYI, I have used these in the past.
