Title: [FIX] Arduino Opta WiFi DFU Errors in Arduino PLC IDE – Solution
I recently encountered persistent DFU-related errors when uploading sketches to my Arduino Opta WiFi using the Arduino PLC IDE. The errors appeared even though the uploads were successful, and the sketches ran fine.
What I Tried:
  • Reinstalling the Arduino Opta board package
  • Reinstalling the Arduino PLC IDE and IDE
  • Testing multiple Opta WiFi boards
  • Manually uploading via the DFU bootloader (which worked)
Solution:
After trying everything, I finally reinstalled Windows 11, and that completely resolved the issue! The Arduino PLC IDE now works normally without DFU errors.
Takeaway:
If you’re experiencing similar DFU-related upload issues on the Arduino Opta WiFi and nothing else works, consider doing a clean reinstall of Windows.
Hope this helps others facing the same problem! Let me know if you have questions.
Thanks for the info, but still, reinstalling Windows is hardly good advice worth suggesting to others.
If something didn't work for me and I had to reinstall the system, I would rather try to find another device.
