TM1637 7-Segment Display interfere IR Receiver
I had installed IR control on my room appliances using Arduino. Now I want to add a TM1637 4 Digit 7-Segment display to display time too using the same Arduino. When I tried, all worked well except the IR control. Minimising the hardware along with the programming code, I got to know that the problem is because of TM1637, it somehow interferes with the IR receiver which produces infinite IR signals. I had covered the IR Receiver and it still showing random values So I think the problem is internal. This whole thing happens whenever there is something on display otherwise works alright.
Here is the code I had used:-
#include <IRremote.h>
#include <TM1637Display.h>
#define CLK 11
#define DIO 12
TM1637Display display(CLK, DIO);
uint8_t data[4];
int RECV_PIN = 3;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  display.setBrightness(5);
  data[0] = display.encodeDigit(1);
  data[1] = display.encodeDigit(2)|0x80;
  data[2] = display.encodeDigit(1);
  data[3] = display.encodeDigit(1);
  display.setSegments(data);
  if (irrecv.decode(&results)) {
    Serial.println(results.value);
    irrecv.resume();
  delay(100);
Please help me solve this issue.
Post your schematic. A proper schematic please. Hand drawn is ok.
Post updated with the schematic.
Rishabh8721:
Not a schematic! Please learn the difference.
Fritzing has a schematic view. Switch to that, tidy up the connections and make sure all components are labelled with part numbers.
