a tricky one (or maybe not, if you've been through the same already).
I am struggling since days to get TMRPCM to play back some simple WAV from SD through an UNO. I am trying to rebuild this gentlemen's escape room phone prop. Dialing and hook lifting/dropping works but it is not playing back the audio as expected.
Problem
When playing back the sound I am getting either nothing at all or a weird cracking / nonsense noise output.
"#define debug" enabled in pcmConfig.h returns "WAV ERR" despite using demo files and demo code.
Code
"basic_test" from the TMRPCM library example:
#include <SD.h>
#define SD_ChipSelectPin 4
#include <TMRpcm.h>
#include <SPI.h>
TMRpcm tmrpcm;
void setup(){
tmrpcm.speakerPin = 9 ; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
tmrpcm.play("music");
void loop(){
if(Serial.available()){
if(Serial.read() == 'p'){ //send the letter p over the serial monitor to start playback
tmrpcm.setVolume(4);;
tmrpcm.play("musicb");
Serial.println(tmrpcm.isPlaying());
Hardware
Arduino UNO v3
SPI SD Card reader HW-203 and HW-125 (I guess no-name/unbranded)
Speaker: Old rotary dial phone (yes, seriously)
Pins
#4 CS
#9 Speaker
#11 MOSI
#12 MISO
#13 SCK
What I have tried so far
Ran the SD cardinfo demo - could list the files and received correct card info
Pins #9 Speaker #11 Speaker
Don't make much sense to me. I thought this used just one pin from the Arduino, why are you attaching two speaker pins from the Arduino?
The WAV file must be the right format for TMRPCM library. But if you're using demo files that should be correct.
Is the SDcard getting proper power? SDcards are power hungry and built-in 3.3V supply on many Arduinos isn't beefy enough.
Have you sanity checked just reading files from the card direct?
About the least likely transducer I can imagine, and I know what they are like, probably going to make abysmal sound quality. They involve a steel diaphram in the field of an electromagnet with a permanent magnet bias and have very low output for the input level (basically an earphone).
MarkT:
I am running the SD reader off the 5V pins, supply is via USB. Will try to power the whole contraption by an external power supply.
MarkT:
Good point, I will try reading file content to serial. The SD "cardinfo" example works fine and returns info + all file names on the card to serial.
MarkT:
I do not expect much quality either... but in the original video linked in my post you can hear quite a decent output. In my case the UNO outputs enough juice to make a very loud and unplesent noise/scramble.
If its a module with its own 3.3V regulator, that's fine. You can get a bare SDcard socket which then needs this added.
You need to boost a logic signal before if can drive any loudspeaker type except piezo.
I got it to work... looks like formatting the SD card to fat16 on macOS did mess up the file system. Formatted with Win10, downloaded the demo wav again and it worked.
MarkT:
In this case arduino output themes to be sufficient. Volume is great, audio quality as expected but good enough for my purpose.
