toCharArray Giving Weird Results
I have a String that I want to convert to a char Array.
The following code WORKS FINE
char buff[100] = "";
strcpy(buff, "MyString5522");
However THE FOLLOWING gives me a weird block as the beginning character.
char buff[100];
String myString = "MyString5522";
myString.toCharArray(buff, myString.length()+1);
How can I fix this?
How and where are you seeing this weird character ? Please post a small but complete sketch that illustrates your problem
#include<SPI.h>
String B1SN = "MySerialTest4455";
String B2SN = "";
volatile int pos;
volatile bool active;
  pinMode(MISO, OUTPUT);
  SPCR |= bit(SPE);
  SPCR |= bit(SPIE);
// SPI interrupt routine
ISR (SPI_STC_vect)
  byte c = SPDR;
  if (c == 1)  // starting new sequence?
     B1SN.toCharArray(buff, B1SN.length()+1);
     active = true;
     pos = 0;
     SPDR = buff [pos++];   // send first byte
     return;
  if (c == 2)  // starting new sequence?
     strcpy(buff, "ENERGIZER");
     active = true;
     pos = 0;
     return;
  if (!active)
    SPDR = 0;
    return;
  SPDR = buff [pos];
  if (buff [pos] == 0 || ++pos >= sizeof (buff))
    active = false;
    strcpy(buff, "");
This is a slave code for a SPI project
The obvious question is why are you using a String in the first place ?
I suspect that the problem is not in the toCharArray() function but elsewhere in your code
Try
  char buff[100];
  String myString = "A";
  myString.toCharArray(buff, myString.length() + 1);
  Serial.println(strlen(buff));
  Serial.println(buff);
Would it be better to just store everything initially as a char array?
Does this help with memory for my Arduino?
Yes to both questions
Ok I just converted to the char array but still the same problem, if I use strcpy(buff, SN) in the setup, everything works fine but as soon as the strcpy is in the interrupt it gives me this weird block.
I will send a quick screenshot
#include<SPI.h>
char B1SN[100] = "MySerialTest5524558Red";
volatile int pos;
  SPCR |= bit(SPE);
  SPCR |= bit(SPIE);
ISR (SPI_STC_vect)
  byte c = SPDR;
     strcpy(buff, B1SN);
     active = true;
     pos = 0;
     return;
  if (!active)
    SPDR = 0;
    return;
  SPDR = buff [pos];
    active = false;
    strcpy(buff, "");
This gives This...
However if i place the strcpy in the setup it does what I expect, but I can't use that method as I need to update the buffer with different info
#include<SPI.h>
volatile int pos;
  SPCR |= bit(SPE);
  SPCR |= bit(SPIE);
  strcpy(buff, B1SN);
ISR (SPI_STC_vect)
  byte c = SPDR;
     active = true;
     pos = 0;
     return;
  if (!active)
    SPDR = 0;
    return;
  SPDR = buff [pos];
    active = false;
    strcpy(buff, "");
Bad idea. The second argument to the toCharArray method is the size of the buffer, not the length of the string.
I found the problem.
On my master i have a delayMicroseconds, increasing this time removes the weird characters and increases the length of sendable data
I have not read in details but The indentation in this snippet seems to indicate you wanted to include the second line in the if expression. Are you missing {}?
And to empty a cString you don’t need strcpy() just use buff[0] = '\0'; or *buff = 0; and the likes.
