Hi there ,
Testing two TOF sensors, VL53L1X , connections are simillar with one different.
One of them has a VCC pin, this one works fine - picture on left side
Second one has a VIN pin instead, nothing happens at all....no input on console....
Testing them separatly, and using USB.
Dont know if i doining something wrong or this with VIN ( purchased from alliexpress - has good opinon) .
Any advice please
Did you follow the wiring diagram? Did you wire it like this
Board 5V to sensor Vin
Board GND to sensor GND
Board SCL to sensor SCL
Board SDA to sensor SDA
Board 2 to sensor GPIO
Board 3 to sensor XSHUT
The TOF Vin is for 5V in and not Arduino VIn.
Tried connection VIN to 5V pin, no input as well.
So you are saying that we cannot use this kind of sensor ( with VIN) on MKR WAN?
I purchesed it from https://pl.aliexpress.com/item/1005003091941068.html?spm=a2g0o.order_list.order_list_main.22.3ba41c24ONRosk&gatewayAdapt=glo2pol
looks like it for arduino....
Please show where I 'said' such.
any idea why it is not working ? what could be the issue...?
