Toggle Arduino LED/relay from external webserver
I want to control an LED/relay from an external webserver with an Arduino Nano and W5500 Ethernet chip in realtime (latency for button click on website ---> LED toggle should be lower than 1sec). The task is simple with UDP but my Arduino is behind a NAT/router with dynamic IP and port forwarding is not possible so I can't send UDP packets from my external webserver to Arduino.
Arduino <---> NAT/router <---> webserver
To solve this, I establish a TCP connection from Arduino to the webserver. It's a Python webserver and I handle the connection in its own thread. When someone presses the button to toggle the LED, the webserver just appends a command ('0' or '1') to my TCP handler thread that sends the command via established TCP connection to my Arduino.
Problem: it works sometimes for many minutes/hours then the TCP connection stucks. Arduino thinks the connection is established and I also don't get a timeout Exception or something on my Python thread but no data is received/transmitted.
Has someone an idea how I can solve this problem?
This is my Arduino code:
#include <SPI.h>
#include <Ethernet2.h>
#include "utility/w5500.h"
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
        0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
unsigned int TCPPort = 8080;
IPAddress server(192, 168, 100, 28);
EthernetClient client;
// status LED
const int pin_led_tcp = 4;
// relais pins
const int pin_relais1 = 5;
    // init and turn off relais
    pinMode(pin_relais1, OUTPUT);
    digitalWrite(pin_relais1, HIGH);
    // init and turn off status LED
    pinMode(pin_led_tcp, OUTPUT);
    digitalWrite(pin_led_tcp, LOW);
    // start the Ethernet connection:
    if (Ethernet.begin(mac) == 0) {
        Serial.println("Failed to configure Ethernet using DHCP");
        // no point in carrying on, so do nothing forevermore:
        for (;;);
    // connect TCP
    connectTCP();
    uint8_t status = client.status();
    if(status != SnSR::ESTABLISHED){
        Serial.println("Connection lost...");
        Serial.println(status, HEX);
        for(size_t i=0; i<MAX_SOCK_NUM; i++){
            Serial.print("state ");
            Serial.print(i);
            Serial.print(": ");
            Serial.println(Ethernet._state[i]);
        client.stop();
        //reconnect
        connectTCP();
        // turn LED on if Arduino is connected
        digitalWrite(pin_led_tcp, HIGH);
    char cmd = -1;
    if (client.available()) {
        cmd = client.read();
    // execute command
    switch (cmd) {
        case '1':
            Serial.println("Turn lights on...");
            digitalWrite(pin_relais1, LOW);
        case '0':
            Serial.println("Turn lights off...");
        case 'p': // ping
            Serial.println("got ping");
            client.write('p');
        case -1: // no command
        default:
            Serial.println("unknown command");
            Serial.println(cmd);
bool connectTCP(){
    // if you get a connection, report back via serial:
    if (client.connect(server, TCPPort)) {
        Serial.println("connected");
        return true;
        // if you didn't get a connection to the server:
        Serial.println("connection failed");
    return false;
And this is my Python TCP handler:
class ArduinoSocket(object):
    def __init__(self, port, logger):
        self.port = port
        self.logger = logger
        self.sock = self.__create_socket()
        self.running = True
        self.commands = []
        self.send_timeout = 5.0
        # start loop
        self.thread = Thread(target=self.loop)
        self.thread.start()
    def __create_socket(self):
        self.logger.debug("Create new socket")
        sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        sock.settimeout(2.0)
        sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
        """Set TCP keepalive on an open socket.
        It activates after 1 second (after_idle_sec) of idleness,
        then sends a keepalive ping once every 3 seconds (interval_sec),
        and closes the connection after 5 failed ping (max_fails), or 15 seconds
        #sock.setsockopt(socket.SOL_SOCKET, socket.SO_KEEPALIVE, 1)
        #sock.setsockopt(socket.IPPROTO_TCP, socket.TCP_KEEPIDLE, 1)
        #sock.setsockopt(socket.IPPROTO_TCP, socket.TCP_KEEPINTVL, 3)
        #sock.setsockopt(socket.IPPROTO_TCP, socket.TCP_KEEPCNT, 5)
        sock.bind(("0.0.0.0", self.port))
        sock.listen(8)
        return sock
    def loop(self):
        clientsocket = None
        last_ping = time.time()
        while self.running:
            if clientsocket is None:
                try:
                    (clientsocket, address) = self.sock.accept()
                    self.logger.debug("Got connection to {}".format(address))
                except IOError, e:
                    self.logger.error("IOError {}".format(e))
                    continue
                except socket.timeout:
                    self.logger.error("Timeout {}".format(e))
                    continue
                except Exception as e:
                    self.logger.error("Unknown error {}".format(e))
            if len(self.commands) > 0 and clientsocket is not None:
                try:
                    t, cmd = self.commands[0]
                    if time.time() - t < self.send_timeout:
                        self.logger.debug("send command {}".format(cmd))
                        clientsocket.send(str(cmd))
                    self.commands.pop(0)
                except IOError as e:
                    self.logger.error("Clientsocket.send() IOError {}".format(e))
                    if clientsocket is not None:
                        clientsocket.close()
                        clientsocket = None
                    self.logger.error("Clientsocket.send() Unknown error {}".format(e))
                        clientsocket = None
            elif time.time() - last_ping > 5:
                try:
                        self.logger.debug("send ping")
                        clientsocket.send("p")
                    else:
                        self.logger.debug("no clientsocket to send ping")
                        clientsocket = None
                        clientsocket = None
    def send(self, cmd):
        self.commands.append((time.time(), cmd))
I guess that your NAT device simply forgets the connection when no data was transmitted for some time. You might have to insert some keep-alive signal into your protocol.
the webserver sends a ping every 5 seconds. Maybe I should decrease the interval to 1s? However, the sockets should detect the broken connection and reconnect but both sides think the connection is established!?
They should detect it after some timeout (I think it's about 180s) but not immediately as they don't get a signal if the NAT router closes the entry in it's table. Did you check that the ping signal is really sent? Wireshark or tcpdump may help you detecting that.
Please post the output of such a session.
I captured some data with thsark on my webserver (see attachment, IPs are replaced). There are errors from package 47 to 56 (Reassembly error, protocol TCP: New fragment overlaps old data (retransmission?). The webserver sends the ping but I don't receive it on my Arduino and there is no timeout detected?! I also detached the Ethernet cable from the Arduino and the webserver didn't get a timeout.
t.txt (506 KB)
We need a bit more information about your network to interpret that output. I expected an already filtered output where just the Arduino IP is included (as source or target). I won't check over 5000 lines of output manually. And use a tool that does not only log the header information but the content too, otherwise we cannot find out if the ping signal was sent.
This is the tshark capture file: Dropbox - Error
Captured on my vserver/webserver with IP 193... and the NAT's IP is the 178.0.253.37. I only captured port 8080 where the TCP between webserver and Arduino is established. The webserver sends an 'p' for ping and '0' or '1' to toggle the LED.
Take a look at the end of the communication. The Arduino send a packet with FIN and ACK set which is usually an answer to a FIN packet. So I guess that the NAT router sent a FIN packet to Arduino to terminate a long standing connection (which several devices from network providers are doing). It's interesting that your server is acknowledging that but a few moments later it tries to send another packet into the terminated connection.
I would expect the Arduino to reconnect after some time in this case. What output do you get on the Arduino side? It might be interesting to sniff on the network where the Arduino is connected. Either the arduino freezes for some memory problem or the like, or the NAT router does some really nasty things.
I added some code to save a timestamp for received pings on Arduino. If there is no ping in 20 seconds, I close the socket and reconnect. Arduino says it's reconnected but the server sends pings to its old, outdated socket connection without an exception. So the Arduino doesn't receive the pings and commands.
I captured the internet interface: Dropbox - Error
and the ethernet interface of my router: Dropbox - Error
That means that you NAT router disconnects the running connection without informing the end points. I would try to replace that device as it has a broken implementation of the NAT process.
Thanks for your input! I will try it with another router/network. If someone has similar problems: the router is a Fritzbox 7312.
It's for an art project of a friend where visitors of the exhibition and his website can control an LED strip in realtime. The Arduino will be part of the museum's network so a simple webserver on the device or UDP datagrams won't work because port forwarding is probably not possible.
One possibility is to stop the time when the disconnect usually happens (let's say it's 3 hours). The disconnect the connection on the Arduino after 1 hour and immediately re-open a connection. That might circumvent that problem.
Just out of curiosity: Is that a Deutsche Telekom connection? I think to remember that they have a mandatory disconnect. So it may be a provider problem and not one of the router, at least my fritzbox doesn't have that problem (it's another model though).
It happens after random durations. Sometimes after 10 minutes, sometimes after several hours. I just close and reopen the session every 5 minutes on server side to prevent the problem.
My provider is 1&1. You have the mandatory disconnect after 24h with almost all providers in Germany but it's set to 4AM on my fritzbox.
