too many conditions: help in coding!
Hi
I am struggling with many conditions in my code. I have used switch case but it is not clean at all. the code has lot of errors. I am not good at coding. if you could suggest something. help it in structuring.
here's the code(this code is wrong. but i want to perform these actions ) how should i do it? help needed :frowning: :frowning:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
const int  buttonPin1 = 2;    // Axthe pin that the pushbutton is attached to
const int  buttonPin1a = 4;    // Bx
const int  buttonPin2 = 5;      //Ay
const int  buttonPin2a = 6;      //By
const int serPin1 = 9;       // the pin that the servo is attached to
const int serPin2 = 10;
// Variables will change:
//int buttonPushCounter1 = 0;   // counter for the number of button presses
//int buttonPushCounter1a = 0;
//int buttonPushCounter2 = 0;
//int buttonPushCounter2a = 0;
int buttonState1 = 0;         // current state of the button
int buttonState2 = 0;         // current state of the button
int buttonState1a = 0;
int buttonState2a = 0;
//int lastButtonState1 = 0;     // previous state of the button
//int lastButtonState2 = 0;
//int lastButtonState2a = 0;
//int lastButtonState1a = 0;
int val= 180;
int val1= 0;
int temp
int n;
  myservo1.attach(9);
  myservo2.attach(10);
  // initialize the button pin as a input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin1a, INPUT);
  pinMode(buttonPin2, INPUT);
  // initialize the LED as an output:
  pinMode(serPin1, OUTPUT);
  pinMode(serPin2, OUTPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  buttonState1 = digitalRead(buttonPin1);
   buttonState1a = digitalRead(buttonPin1a);
  buttonState2 = digitalRead(buttonPin2);
   buttonState2a = digitalRead(buttonPin2a);
        switch (n) {
         val=val1;
         temp=val1;
         val1=val;
    case 0:
   if (buttonState1 == HIGH || buttonState1a == HIGH)// A/B-x
      myservo1.write(val);
       Serial.println("A/B-x");
    case 1:
   if (buttonState2 == HIGH || buttonState2a == HIGH)// A/B-y
      myservo2.write(val);
       Serial.println("A/B-y");
      case 2:
      if (buttonState1 == HIGH && buttonState2 == HIGH)// A-A
       Serial.println("AA");
    case 3:
     if (buttonState1a == HIGH && buttonState2a == HIGH)//B-B
      myservo1.detach();
    myservo2.detach();
    Serial.println("BB");
    case 4:
 if (buttonState1 == HIGH && buttonState2a == HIGH)// Ax-By
       Serial.println("Ax-By");
      case 5:
      if (buttonState1a == HIGH && buttonState2 == HIGH)
       Serial.println("Bx-Ay");
One simple way would be to pack the button states into a single byte or int, and use the numeric value as the selector.
What is "n"?
Comments would be good.
Can I also suggest that before posting code, you use the auto-format tool in the IDE (ctrl-T)?
       switch (n) {
         val=val1;
         temp=val1;
         val1=val;
AFAIK this is not allowed (never seen it before), although the compiler accepts it - after cleaning up the { and } in the code a bit
Think these assignments - swap of two vars- should be before the switch()
Where gets n its value???? its allways zero! ( default initializer global var)
int temp is missing a ;
The whole switch statement should be inside loop() I guess ?
Every path of the switch statement has a delay(1000) in it, that means it possibly can be extracted outside (before/after) the switch => less lines of code
Pay attention to the layout and these things would be visible faster,
I want the position of the servo to remain at the last position after rotation. As in it rotates from 0-180 then next time the code is read it should start from 180 degrees and goes like 180-0. i want this to perform every time rotation happens. I thought the code is read from top to bottom so it would swap the numbers then use those numbers in the following code.
Dived into this piece of code as the compiler didn't complain (maybe warnings could see that in the IDE)
switch (n)
  val=val1;
  temp=val1;
  val1=val;
It is legal C / C++ as the statements are in a valid block { }
However the compiler makes code that jumps just over it, even if there is no matching case and no default in the switch. See testapp below.
  Serial.println("I am Arduino");
int n = 0;
  switch(n)
    Serial.println("!!!!");
    case 1: Serial.println(n); break;
    Serial.println("****");
    case 10: Serial.println(n); n = 0; break;
    Serial.println("????");
  n++;
  delay(100);
Now lets think how this can be made usefull (except for the obfuscated C contest) .....
It is hiding valid code that is unreachable .... Add labels and GOTO's to jump between cases?
easteregg hiding in a switch?
Definitely no good programming practice ...
Conclusion: Don't do this.
-- update --
With goto's and labels the unreachable code can be made reachable again, but I will not publish this horror code here
I want the code to be like, If the above conditions are matched then
this should be performed. But I don't know how to achieve it. I tried using if-else but then again too many loops and its not reading all lines of code.
Take paper and pencil and draw a flowchart of how your application should work. Make a design. Dumping your minds eye directly in code is difficult even for a pro.
And build your application step (then test) by step (and test) by step (and test) ....
The constructions in your code are not too bad but there is too much I don't understand, to start with
  • What is n? what does it represent, the name is as meaningles as x or q or a :slight_smile:
  • Where is the switch(n) for?
  • Comments like // Variables will change: makes live not really easier
  • if (buttonState1 == HIGH || buttonState1a == HIGH) // A/B-x <= obfuscated comment detected
    (will you know what that means in 6 months?
if (buttonState1 == HIGH || buttonState1a == HIGH)     // ALL MOTORS FORWARD (more meaningfull)
Hopes this helps you from struggling to walking :wink:
is this a right way to do it?
any better? the output isnt reading the conditional statements..
#include <Servo.h>
Servo myservo1;
Servo myservo2;
const int  buttonPin1 = 2;    // the pin that the pushbutton is attached to
int val= 180;
int val1= 0;
int temp;
int buttonState1, buttonState2,  buttonState2a, buttonState1a = 0;         // current state of the button
  myservo1.attach(9);
  pinMode(buttonPin2a, INPUT);
  // initialize as an output:
  val1=temp;
  temp=val;
  val=val1;
  if (buttonState1 == HIGH ) // when button 1(x orientation) pressed motor1 rotates
    Serial.println("Ax");
  else{
    if (buttonState1a == HIGH) // when button 1a(y orientation) pressed motor1 rotates
      Serial.println("B-x");
    else{
      if (buttonState2 == HIGH ) // when button 2(x orientation) pressed motor2 rotates
        Serial.println("Ay");
      else{
        if( buttonState2a == HIGH)  //when button 2(y orientation) pressed motor2 rotates
          Serial.println("B-y");
        else{
          if (buttonState1 == HIGH && buttonState2 == HIGH)// when button 1 & 2(x orientation both) pressed motor1 rotates
          else{
            if (buttonState1a == HIGH && buttonState2a == HIGH)// when button 1a & 2a(y orientation both) pressed motor1 & 2 stops
              myservo1.detach();
              myservo2.detach();
            else{
              if (buttonState1 == HIGH && buttonState2a == HIGH)// when button 1(x orientation) & 2a(y orientation both) pressed motor2                                     //rotates
              else{
                if (buttonState1a == HIGH && buttonState2 == HIGH)// when button 1a(y orientation) & 2(x orientation both) pressed //motor1  rotates  then motor 2
I cannot tell you if your logic is right, I suppose it isn't (by the look)
Have you made the flowchart?
Think you should just do:
if (...)  // first condition
if (...) // second condition
etc
Maybe just start with testing one condition
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int val= 180;
int val1= 0;
int temp;
  myservo1.attach(9);
  val1=temp;
  temp=val;
  val=val1;
If this works you add a little and test it until it works.
here is the code, I tested out like you said..
It is working fine till i read single switches HIGH but it is not reading when 2 switches are HIGH because its reading the previous statements and working accordingly. whats the way out? :frowning: :frowning:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
const int  buttonPin2 = 7;
int val= 180;
int val1= 0;
int temp;
  myservo1.attach(9);
  val1=temp;
  temp=val;
  val=val1;
  //if (buttonState1 != lastButtonState1)
  else{
    else{
      if (buttonState2 == HIGH ) // A/B-y
       else{
Did you make a flowchart ?
your logic is incorrect, you can see it easier with better layout. See below.
There are 4 options.
if you want OPTION 4 to execute 2 lines must be high.
but you test the highness of them seperately in OPTION 1 and in OPTION 2 before option 4 can be tested. This was OPTION 4 can never be reached.
(that is due to all those else staements, I my previous post I removed them
  if (buttonState1 == HIGH )    // OPTION 1
  else if (buttonState1a == HIGH)   // OPTION 2
  else if (buttonState2 == HIGH )   // OPTION 3
  else if (buttonState1 == HIGH && buttonState2 == HIGH)  // OPTION 4
A possible solution: - there are more
Define one variabele to set the keystate , and use bitmanipulations to add state of all buttons in one keystate .
Note the keystate can have 16 values (0..15)
  bs1= digitalRead(buttonPin1);        // LOW = 0 HIGH = 1
  bs1a = digitalRead(buttonPin1a);
  bs2 = digitalRead(buttonPin2);
  bs2a = digitalRead(buttonPin2a);
  unsigned int keystate = 0;
  if (bs1 == HIGH) bitSet(keystate , 0);
  if (bs1a == HIGH) bitSet(keystate , 1);
  if (bs2 == HIGH) bitSet(keystate , 2);
  if (bs2a == HIGH) bitSet(keystate , 3);
  Serial.print("STATE: ");  Serial.println(keystate, BIN);  // 0-15 = 0 - 1111
  switch (keystate )
  case 1: // bs1 pressed others not
  case 2: // bs1a pressed others not
  case 4: // bs2 pressed others not
  case 5: // bs1 and bs2 pressed others not
  case 5: // all keys pressed
    Serial.println("you found the easteregg");
  case 0: // no keys pressed;
  default:  // invalid key combination
    // error message
    Serial.println("Invalid key combination pressed");
Does this make sense to you...
Thank s lot robtillaart
I understood it.. I had a doubt.. if i have to carry out bitwise OR what should i do?
as in bs1 OR bs1a?
Thanks AWOL i went through it.. in my code it(And operation) is happening as i press the buttons. but i want few of the operations as OR.
Another query
i want to switch between cases. but when i am using goto it shows error! :frowning:
If you scroll down the page I linked, you'll find bitwise OR.
There are very few cases in C programming where you need to use goto.
Could you post your new code so we can see what is wrong?
You should probably avoid using goto as you'll end up with spaghetti code that is hard to understand and hard to debug. One option is to make some simple functions and call them from the body of the case statements (i.e. so you can easily run the same code for different cases).
