Не получается считать данные о напряжении на транзисторе
выводит следующую ошибку
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1
Using core 'esp32' from platform in folder: C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1
cmd /c if exist "C:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a\\partitions.csv" COPY /y "C:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a\\partitions.csv" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\partitions.csv"
cmd /c if not exist "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\partitions.csv" if exist "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32\\partitions.csv" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\partitions.csv"
cmd /c if not exist "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\partitions.csv" COPY "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\tools\\partitions\\default.csv" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a\\bootloader.bin" ( COPY /y "C:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a\\bootloader.bin" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\sketch_jan23a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32\\bootloader.bin" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\sketch_jan23a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\sketch_jan23a.ino.bootloader.bin" "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a\\build_opt.h" COPY /y "C:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a\\build_opt.h" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\build_opt.h"
cmd /c if not exist "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\build_opt.h" type nul > "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\build_opt.h"
cmd /c type nul > "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B/file_opts"
cmd /c COPY /y "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32\\sdkconfig" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\sdkconfig"
�����஢��� 䠩���:         1.
Detecting libraries used...
C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/defines -IC:\Users\redmi\Documents\Arduino\sketch_jan23a -iprefix C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/ @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/includes -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/qio_qspi/include -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32 -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\variants\esp32 @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/build_opt.h @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/file_opts C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B\sketch\sketch_jan23a.ino.cpp -o nul
Alternatives for iarduino_VCC.h: [iarduino_VCC@1.0.1]
ResolveLibrary(iarduino_VCC.h)
  -> candidates: [iarduino_VCC@1.0.1]
C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/defines -IC:\Users\redmi\Documents\Arduino\sketch_jan23a -iprefix C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/ @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/includes -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/qio_qspi/include -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32 -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\variants\esp32 -Ic:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/build_opt.h @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/file_opts C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B\sketch\sketch_jan23a.ino.cpp -o nul
C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/defines -IC:\Users\redmi\Documents\Arduino\sketch_jan23a -iprefix C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/ @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/includes -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/qio_qspi/include -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32 -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\variants\esp32 -Ic:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/build_opt.h @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/file_opts c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp -o nul
Error while detecting libraries included by c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp
WARNING: library iarduino_VCC claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
Generating function prototypes...
C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32-elf-g++ -c @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/defines -IC:\Users\redmi\Documents\Arduino\sketch_jan23a -iprefix C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/ @C:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/flags/includes -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/qio_qspi/include -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32 -IC:\Users\redmi\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\variants\esp32 -Ic:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/build_opt.h @C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B/file_opts C:\Users\redmi\AppData\Local\arduino\sketches\F8770BD72E4C86255646601F8CF52B0B\sketch\sketch_jan23a.ino.cpp -o C:\Users\redmi\AppData\Local\Temp\1600308544\sketch_merged.cpp
C:\Users\redmi\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\redmi\AppData\Local\Temp\1600308544\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/defines" "-IC:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a" -iprefix "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/include/" "@C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/includes" "-IC:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/qio_qspi/include" "-IC:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\cores\\esp32" "-IC:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32" "-Ic:\\Users\\redmi\\Documents\\Arduino\\libraries\\iarduino_VCC\\src" "@C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B/build_opt.h" "@C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B/file_opts" "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\sketch\\sketch_jan23a.ino.cpp" -o "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\sketch\\sketch_jan23a.ino.cpp.o"
C:\Users\redmi\Documents\Arduino\sketch_jan23a\sketch_jan23a.ino: In function 'void V_reading(float)':
C:\Users\redmi\Documents\Arduino\sketch_jan23a\sketch_jan23a.ino:45:22: warning: parameter 'v' set but not used [-Wunused-but-set-parameter]
   45 | void V_reading(float v){
C:\Users\redmi\Documents\Arduino\sketch_jan23a\sketch_jan23a.ino: In function 'void loop()':
C:\Users\redmi\Documents\Arduino\sketch_jan23a\sketch_jan23a.ino:31:17: warning: 'v' may be used uninitialized [-Wmaybe-uninitialized]
   31 |   Serial.println(v);
C:\Users\redmi\Documents\Arduino\sketch_jan23a\sketch_jan23a.ino:29:9: note: 'v' was declared here
   29 |   float v;
Compiling libraries...
Compiling library "iarduino_VCC"
"C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/defines" "-IC:\\Users\\redmi\\Documents\\Arduino\\sketch_jan23a" -iprefix "C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/include/" "@C:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/includes" "-IC:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/qio_qspi/include" "-IC:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\cores\\esp32" "-IC:\\Users\\redmi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32" "-Ic:\\Users\\redmi\\Documents\\Arduino\\libraries\\iarduino_VCC\\src" "@C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B/build_opt.h" "@C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B/file_opts" "c:\\Users\\redmi\\Documents\\Arduino\\libraries\\iarduino_VCC\\src\\iarduino_VCC.cpp" -o "C:\\Users\\redmi\\AppData\\Local\\arduino\\sketches\\F8770BD72E4C86255646601F8CF52B0B\\libraries\\iarduino_VCC\\iarduino_VCC.cpp.o"
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:19:26: error: #error \U00000418\U00000437\U00000432\U00000438\U0000043d\U00000438\U00000442\U00000435, \U0000043d\U0000043e \U00000431\U00000438\U00000431\U0000043b\U00000438\U0000043e\U00000442\U00000435\U0000043a\U00000430 "iarduino_VCC" \U0000043d\U00000435 \U0000043f\U0000043e\U00000434\U00000434\U00000435\U00000440\U00000436\U00000438\U00000432\U00000430\U00000435\U00000442 \U00000432\U00000430\U00000448\U00000443 \U0000043f\U0000043b\U00000430\U00000442\U00000443 Arduino!
   19 |                         #error Извините, но библиотека "iarduino_VCC" не поддерживает вашу плату Arduino!
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:47:26: error: #error \U00000418\U00000437\U00000432\U00000438\U0000043d\U00000438\U00000442\U00000435, \U0000043d\U0000043e \U00000431\U00000438\U00000431\U0000043b\U00000438\U0000043e\U00000442\U00000435\U0000043a\U00000430 "iarduino_VCC" \U0000043d\U00000435 \U0000043f\U0000043e\U00000434\U00000434\U00000435\U00000440\U00000436\U00000438\U00000432\U00000430\U00000435\U00000442 \U00000432\U00000430\U00000448\U00000443 \U0000043f\U0000043b\U00000430\U00000442\U00000443 Arduino!
   47 |                         #error Извините, но библиотека "iarduino_VCC" не поддерживает вашу плату Arduino!
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp: In function 'float analogRead_VCC()':
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:25: error: 'ADMUX' was not declared in this scope
   21 |                         ADMUX   = (0<<REFS1)|(1<<REFS0)|(0<<ADLAR)|(1<<MUX4)|(1<<MUX3)|(1<<MUX2)|(1<<MUX1)|(0<<MUX0);   //      Устанавливаем биты регистра «ADMUX»: «REFS»=01 (ИОН=VCC), «ADLAR»=0 (выравнивание результата по правому краю), «MUX[4-0]»=11110 или «MUX[3-0]»=1110 (источником сигнала для АЦП является напряжение ИОН на 1,1 В).
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:39: error: 'REFS1' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:50: error: 'REFS0' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:61: error: 'ADLAR' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:82: error: 'MUX3' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:92: error: 'MUX2' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:102: error: 'MUX1' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:21:112: error: 'MUX0' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:27:33: error: 'ADCSRA' was not declared in this scope
   27 |                                 ADCSRA |= (1<<ADEN )|(1<<ADSC );        //      Устанавливаем биты регистра «ADCSRA»: «ADEN»=1  (вкл АЦП), «ADSC» =1 (запускаем новое преобразование).
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:27:47: error: 'ADEN' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:27:58: error: 'ADSC' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:29:39: error: 'bit_is_set' was not declared in this scope
   29 |                                 while(bit_is_set(ADCSRA,ADSC)){}; i += ADC;        //      Ждём завершения преобразования: о готовности результата свидетельствует сброс бита «ADSC» регистра «ADCSRA» и добавляем результат «ADC» к переменной «i».
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:29:72: error: 'ADC' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp: In function 'float analogCalc_1V1(float)':
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:25: error: 'ADMUX' was not declared in this scope
   49 |                         ADMUX   = (0<<REFS1)|(1<<REFS0)|(0<<ADLAR)|(1<<MUX4)|(1<<MUX3)|(1<<MUX2)|(1<<MUX1)|(0<<MUX0);   //      Устанавливаем биты регистра «ADMUX»: «REFS»=01 (ИОН=VCC), «ADLAR»=0 (выравнивание результата по правому краю), «MUX[4-0]»=11110 или «MUX[3-0]»=1110 (источником сигнала для АЦП является напряжение ИОН на 1,1 В).
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:39: error: 'REFS1' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:50: error: 'REFS0' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:61: error: 'ADLAR' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:82: error: 'MUX3' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:92: error: 'MUX2' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:102: error: 'MUX1' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:49:112: error: 'MUX0' was not declared in this scope; did you mean 'MUX4'?
      |        MUX4
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:55:33: error: 'ADCSRA' was not declared in this scope
   55 |                                 ADCSRA |= (1<<ADEN )|(1<<ADSC );        //      Устанавливаем биты регистра «ADCSRA»: «ADEN»=1  (вкл АЦП), «ADSC» =1 (запускаем новое преобразование).
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:55:47: error: 'ADEN' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:55:58: error: 'ADSC' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:57:39: error: 'bit_is_set' was not declared in this scope
   57 |                                 while(bit_is_set(ADCSRA,ADSC)){}; i += ADC;        //      Ждём завершения преобразования: о готовности результата свидетельствует сброс бита «ADSC» регистра «ADCSRA» и добавляем результат «ADC» к переменной «i».
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:57:72: error: 'ADC' was not declared in this scope
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp: In function 'float analogSave_1V1(float)':
c:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC\src\iarduino_VCC.cpp:66:63: error: control reaches end of non-void function [-Werror=return-type]
   66 |                         if(v==0){return ion_1V1;}else{ion_1V1 = v;}        //      Сохраняем или возвращаем значение ion_1V1.
cc1plus.exe: some warnings being treated as errors
Using library iarduino_VCC at version 1.0.1 in folder: C:\Users\redmi\Documents\Arduino\libraries\iarduino_VCC
exit status 1
Compilation error: exit status 1
Ошибка вполне однозначная
Это библиотека для ардуино Уно - нано, она не работает на есп32
