Total newbee
Hi am a total noob at this,
recently bought a uno so that learn more about it and eventually want to make a piece of test equipment to test for power on 27 pins of a cable and send that info out to a raspberry pi to turn that into a readable spreadsheet.
So my issue is that there is only 6 analog inputs, How do I get more? need a total of 27 of which one will be a constant ground for the other 26.
Programming and interfacing with the pi I don't think I'll have and issue just the input is my issue.
Any tips will be welcome and the out come will be posted during each steps.
The above link gives one idea of how you could do this. Maybe someone mounts three on a shield for you, but this device has some merit. --Rob.
This one has exactly what you need.
http://blueberryde.com/shop/24-channel-analog-expander-shield/
You could use multiplexer ICs such as the ADG528AKNZ. Or, you could use ADC (Analog-to-Digital Converter) ICs as rmetzner49 mentioned.
How frequently do you need to sample the wires?
I don't think you can do better than $24 for a packaged solution. You will easily have that by the time you use 4x ADG528's and a circuit board.
The ADG528 was just the first hit on Google. There's also the Maxim MAX4581CPE+ which is less than $2, and I'm sure there are dozens of other chips to choose from.
Possible multiplex solutions:
http://www.nxp.com/documents/data_sheet/HEF4067B.pdf
ty for the responces I bought a Mux sheild and I beleive that will be what will work Karllson roboits sales it and I beleive Mayhem labs were the developer.
