Touchscreen not working
Hello everyone, I am relatively new to Arduino. I am using the Giga Display Shield with the Giga R1 board. it displays graphics and text fine and I was hoping to use the touchscreen for a custom project, However, when I try to use the Giga touchscreen library, it fails to initialize. I have tried using the polling example given by Arduino and it is still the same issue, but everything else works as intended. Any suggestions, or would I need to get a new display shield?
Ethan
can you give links to the exact example you are using and information about how you power your board and the error you see ?
(I don't have that board but that would help clarify your set-up)
No problem.
  Touch_Polling
  created 03 May 2023
  by Leonardo Cavagnis
#include "Arduino_GigaDisplayTouch.h"
Arduino_GigaDisplayTouch touchDetector;
  while(!Serial) {}
  if (touchDetector.begin()) {
    Serial.print("Touch controller init - OK");
    Serial.print("Touch controller init - FAILED");
    while(1) ;
  uint8_t contacts;
  GDTpoint_t points[5];
  contacts = touchDetector.getTouchPoints(points);
  if (contacts > 0) {
    Serial.print("Contacts: ");
    Serial.println(contacts);
    for (uint8_t i = 0; i < contacts; i++) {
      Serial.print(points[i].x);
      Serial.print(" ");
      Serial.println(points[i].y);
  delay(1);
The shield is mounted to the back of the Giga r1 and is powered by usb-c.
IMG_1083
As seen within the code, it uploads fine but displays Touch controller init - FAILED.
Regards, Ethan
have you tried ignoring the returned value ?
    touchDetector.begin();
    uint8_t contacts;
    if (contacts > 0) { //Check if at least one touch occurs on the screen
        //Print the coordinates of all simultaneous contacts detected
            Serial.print(" ");
That fixed it. Thank you very much!
Great
Probably worth reporting a bug in GitHub
Hi, can you share a closer image of the display connector from the GIGA R1 WiFi?
Hi, can I know how you solved it? I'm having the same problems with the GIGA R1 WIFI and Display Shield. The screen works fine, but the touch screen isn't detected. Thanks.
see @J-M-L 's post 4
Just use the .begin() function of the touchscreen and ignore the return value...
Good luck!
ec2021
