Hello, I'm a student in electronic engineering and I have a school project I'm having problems with. What I'm trying to do is implement a traction control system for a smaller RC car that works in a similar way to a normal car.
The robot has 4 motors. The motors are connected 2 by 2 to a single driver motor (the car will only move forward or backward). Total consumption 400 mA (100 mA per wheel).
There are 2 Modules : 1 ECU Module and 1 ABS - TCS Module
ECU contains Arduino Uno with 328p uC + CAN + l298n motor driver + 1.1Mohm potentiometer (pedal input).
ABS - TCS Module contains a PCB with that has 2 speed sensors (mounted on 1 motor on each axle), Arduino Nano with 328p uC + CAN + MMA8452Q Accelerometer.
The modules are powered by a 12V battery. The motor driver needs 12V and we are using a 12V-5V converter to power the development boards.
There are 2 programs needed to be made for the 2 modules.
The program for the microcontroller(from ABS-TCS) needs to read the signals from the speed sensors and accelerometer, calculate the wheel speeds and vehicle speed, estimate the direction of the car and transmit control signals via the CAN bus.
The program for the other module (ECU) must take the information from the ABS - TCS module and if it detects a difference in speed from normal operating conditions, it sends the information to the engine controller to reduce acceleration, and to the ABS - TCS system to brake the slipping wheel, thus controlling the traction of the vehicle.
These are the connections for ABS - TCS module:
Arduino Nano CAN Speed sensor 1 Speed sensor 2 Accelerometer
VCC +5V +5V +5V VCC_IN
GND GND GND GND GND
D2 INT - - -
D7 - OUT - -
D8 - - OUT -
D10 CS - - -
D11 MOSI - - -
D12 MISO - - -
D13 SCK - - -
A4 - - - SDA
A5 - - - SCL
These are the connections for ECU module:
Arduino Nano CAN Driver motor Potentiometer
VCC +5V +5V VCC
GND GND GND GND
2 INT - -
3 - Enable A -
4 - IN1 -
5 - IN2 -
6 - IN3 -
7 - IN4 -
9 - Enable B -
10 CS - -
11 MOSI - -
12 - MISO - -
13 SCK - -
A1 - - Cursor
So far I have tried to send the rpm values through the can interface using the can.h library.
The rpm values are different (the values received by ECU are different from those sent by the ABS - TCS). I didn't use timers, everything was written in loop.
Program for the Transmitter
#include <CAN.h>
int nr_slots = 20;
const byte sensor_MOTOR1 = 7;
const byte sensor_MOTOR2 = 8;
volatile unsigned int counter1=0;
volatile unsigned int counter2=0;
//ISR for D7
ISR(PCINT2_vect)
counter1++;
//ISR for D8 //interrupt service routine
ISR(PCINT0_vect)
counter2++;
pinMode(sensor_MOTOR1, INPUT);
pinMode(sensor_MOTOR2, INPUT);
PCICR |= 0b00000001; //enable port B for PCI
PCMSK0 |= 0b00000001; //PCINT0 (pin D8) //Pin Change MaSK
PCICR |= 0b00000100;
PCMSK2 |= 0b10000000; //PCINT 23 (pin D7)
while (!Serial);
Serial.println("CAN Sender");
if (!CAN.begin(500E3)) {
Serial.println("Starting CAN failed!");
while (1);
delay(500); // Send every 1s data via CAN bus
int rpm1 = counter1 / nr_slots * 120;
int rpm2 = counter2 / nr_slots * 120;
// Reset pulse sensor counter
counter1 = counter2 = 0;
Serial.print("Motor Speed 1: ");
Serial.print(rpm1);
Serial.print(" RPM - ");
Serial.print("Motor Speed 2: ");
Serial.print(rpm2);
Serial.println(" RPM ");
CAN.beginPacket(0x10);
CAN.write(rpm1);
CAN.write(rpm2);
CAN.endPacket();
Program for the Receiver
#include <CAN.h>
int motor1_1 = 4;
int motor1_2 = 5;
int motor2_1 = 6;
int motor2_2 = 7;
int enA = 3;
int enB = 9;
int motorspeed1;
int motorspeed2;
int rpm1,rpm2;
void computeMotorSpeed(int potValue) {
static int delta1 = 0, delta2 = 0;
static int old_rpm1 = -1, old_rpm2 = -1;
// nano hasnt updated RPMs, skip calculation
if (old_rpm1 == rpm1 && old_rpm2 == rpm2) return;
motorspeed1 = motorspeed2 = map(potValue, 0, 1023, 0, 255);
// Serial.println("Calculate new pair of motorspeed...");
if (rpm1 > rpm2) {
delta1 += delta1 > 10 ? 1 : 0;
delta2 = 0;
if (rpm2 > rpm1) {
delta1 = 0;
delta2 += delta2 > 10 ? 1 : 0;
if (rpm1 == rpm2) {
delta1 = delta2 = 0;
motorspeed1 -= delta1;
motorspeed2 -= delta2;
pinMode(motor1_1, OUTPUT);
pinMode(motor1_2, OUTPUT);
pinMode(motor2_1, OUTPUT);
pinMode(motor2_2, OUTPUT);
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
while (!Serial);
Serial.println("CAN Receiver");
// start CAN bus 500kbps
while (1);
int packetSize = CAN.parsePacket();
int potValue = analogRead(A1);
potValue = potValue*0.2492668622; //We read the analog value from the potentiometer calibrate it
if(potValue > 254){
digitalWrite(motor1_1, HIGH);// Motor A Clockwise
digitalWrite(motor1_2, LOW); // Motor B Clockwise
digitalWrite(motor2_1, HIGH);
digitalWrite(motor2_2, LOW);
analogWrite(enA, 160);
analogWrite(enB, 160);
else{
digitalWrite(motor1_1, LOW);// Motor A Clockwise
digitalWrite(motor2_1, LOW);
analogWrite(enA, 0);
analogWrite(enB, 0);
if(CAN.packetId() == 0x10){
rpm1 = CAN.read();
rpm2 = CAN.read();
Serial.print(motorspeed1);
Serial.print(" ");
Serial.print(motorspeed2);
Serial.print("MOTOR1 RPM ");
Serial.print(rpm1);
Serial.print("\tMOTOR2 RPM ");
Serial.print(rpm2);
The values that are sent are about 600 - 720 rpms. And the values that are received are about 288,272.
I can't figure out why they are so different. If anyone can help me to figure out how to fix it I would really appreciate it. Thank you!
