Transferring data to Android
Hello, I am currently working on a project and I am new to Arduino.
What are the ways to communicate between an Android and an Arduino?
I plan to attach a speaker and microphone to the Arduino, and the audio signal from the microphone should be transmitted to the Android phone. The Android phone should also be able to send audio data to the Arduino to play a sound on the speaker.
I am thinking of ways such as bluetooth, Wi-Fi, and USB, but I am not sure if it is possible.
Thanks.
First, what, exactly, are you using the microphone for? The ADC chip on the Arduino is not very good for collecting audio data. The higher the quality data you need, the more often you need to sample, which means the more data you need to send.
There are, therefore, two limits to consider - the amount of data you can (or do) collect and the amount of data you can (or do) send. Without knowing the first, it's impossible to help you choose a mechanism that supports sufficient speed.
Other factors to consider are distance, bi-directional, and what data loss rate you can live with.
mageicial:
Have you just reinvented a bluetooth headset?
