I need to get a 9V power source switched down to 5V. I would love if this could be done using a NPN transistor. Supply 9V to the emitter, have an arduino I/O pin hooked into the base, and have 5V be passed through the collector when the transistor is closed. I was wondering if I could also trigger the transistor to close when a certain amount of electric is supplied (.01V - 5V) and have it remain open when receiving no power?
Currently I am using a PNP transistor. Supplying 5V to the emitter, base connected to I/O pin on an arduino, and collector going to devices. I need to supply 5V on the base line to open the circuit. I would much rather supply some type of voltage when the devices need power, not when I do not want them to be powered.
No that is not going to work.
You need a regulator to make the 9V into 5v.
Alternatively put 5.7V onto the base and the COLLECTOR to 9V and the emitter will have 5V on it.
Sorry but that is just being silly. This is electronics, it works by switching things.
I think what you are really after is a voltage regulator with a shutdown control pin.
An example:
I didn't know they made such devices!
I found this just now! Looks like it can use it as it has a shutoff pin!
Will i need a resistor between this device and my arduino i/o pin?
You know what, cross posting is a great way to piss people off on this forum.
The link to the part you posted didn't work, but using the first link from CrossRoads the current entering the enable pin is supposed to be 2 microamps or less. This means that the enable pin has an input impedance greater than 2.5Mohms, so you won't need a resistor to limit the current. That said, adding a 10K resistor in line with the pin wouldn't hurt anything and would also make sure that if you mess something up your Arduino stays safe.
