Trouble Combining Code
Hello,
I have built a machine that has a linear belt driven by a stepper motor, it has limit switches at both ends, and two buttons that drive an object on the belt towards or away from each of the limit switches. If written the following code to essentially disable the home or run buttons depending on if the limit switches are HIGH or LOW. This code works exactly as I would expect it to.
    Revision Notes
  1.2 - First working demonstration code
  1.3 - Added linear actuator aka finger to hardware
  1.4 - Added code to control finger
#include <Stepper.h>
const int homeButtonPin = 5;
const int runButtonPin = 6;
const int homeLimitSwitch = 2;
const int endLimitSwitch = 3;
const int ledPin =  13;
const int stepsPerRevolution = 600;
const int fingerUp = 1; //rev 1.3
const int fingerDown = 0; //rev 1.3
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
int homeButtonState = 0;
int runButtonState = 0;
int homeLimitSwitchState = 0;
int endLimitSwitchState = 0;
int lastCheck = 1;
  pinMode(ledPin, OUTPUT);
  pinMode(homeButtonPin, INPUT);
  pinMode(runButtonPin, INPUT);
  pinMode(homeLimitSwitch, INPUT);
  pinMode(endLimitSwitch, INPUT);
  pinMode(fingerUp, OUTPUT); //rev 1.3
  pinMode(fingerDown, OUTPUT); //rev 1.3
  // read the state of the pushbutton value:
  homeButtonState = digitalRead(homeButtonPin);
  runButtonState = digitalRead(runButtonPin);
  homeLimitSwitchState = digitalRead(homeLimitSwitch);
  endLimitSwitchState = digitalRead(endLimitSwitch);
  int speedPot = analogRead(A5); // Added 11:00 1/2/2022
  int speedSetting = map(speedPot, 0 , 1023, 100, 600);  //rev 1.3 - 600 was 1000
  myStepper.setSpeed(speedSetting);  // Added 11:00 1/2/2022
  if (homeButtonState == HIGH && homeLimitSwitchState == LOW)
    myStepper.step(-stepsPerRevolution / 100); //1.4 reinstated /100
    digitalWrite(ledPin, HIGH);
  if (homeLimitSwitchState == HIGH)
    myStepper.step(0);
  if (((homeLimitSwitchState == HIGH || homeLimitSwitchState == LOW)  && endLimitSwitchState == HIGH) && runButtonState == HIGH)
    //This is where the code should be added
    myStepper.step(stepsPerRevolution / 100); //1.4 reinstated /100
  if (endLimitSwitchState == HIGH && runButtonState == HIGH);
    myStepper.step(0);
I am adding another feature to the code that is driven by the same runButton. This code moves a linear actuator (aka finger) for a set amount of time, holds that position while runButton is held else it retracts the linear actuator. This code also works exactly like I would expect it to.
int fingerDown = 0;
int fingerUp = 1;
int lastCheck = 1;
  if (runButtonState == HIGH)
    if (lastCheck == 1)
      analogWrite(fingerUp, 0);
      analogWrite(fingerDown, 255);
      delay(600); //Time the motor runs forward
      analogWrite(fingerDown, 0);
    lastCheck = 0;
    lastCheck = 1;
    analogWrite(fingerUp, 255);
My challenge is this, when I try to add the "nested" IF/ELSE of the second code to the first code I get wildly unexpected results. Any help on how to have the second code work with the first would be greatly appreciated. The first code has a comment for where I would like to add it.
Please let me know what additional details I could provide to be more helpful.
I think your code would greatly benefit in readability if you use a state machine. Here is a link:
State Machine
Apart from that if you add the code where you indicated you get this:
      if (lastCheck == 1)
      lastCheck = 0;
      lastCheck = 1;
Here are a couple of observations:
  1. You will only enter the first if block if runButtonState == HIGH. Therefore, you will never execute the else statement of the if (runButtonState == HIGH) block!
  2. There is no reason to check homeLimitSwitchState == HIGH || homeLimitSwitchState == LOW because it can't be anything other than those 2 values.
Why pins 0 and 1 for the finger? You're depriving yourself of a fundamental debugging tool - Serial.print.
Why too are you using analogWrite when the only values you're using are are 0 and 255?
Thank you Todd,
I was/am unfamiliar with StateMachine but I can see why you recommend it and agree that it would be cleaner. I will try to make a transition to that code strategy and post it here.
I am not sure that I understand why I shouldn't check the limit switch states, I want to make sure that the stepper cannot drive past those limit switches.
Hello WildBill,
With regards to 0 and 1, they were open so I used them. I was not aware that doing so would prevent me from using serial.print, thanks for the tip. I can readily move to pins 4 and 7 and will do so.
I don't really have any better explanation on my choice to use analogWrite... I tried it and it worked. Is there any advantage to digitalWrite that might not be obvious to me?
Thank you for taking the time to help me out.
@ToddL1962 points out the the condition is always true.
Because homeLimitSwitchState is true OR false.
a7
You can and should check the states. However, look at this expression:
That expression will always be true! homeLimitSwitchState can only be HIGH or LOW.
I completely understand your point.
I wrote code that made sense to me as a human trying to work things out... "do this thing regardless of homeLimitSwitch being HIGH or LOW" but the Arduino couldn't care less about that always true condition.
Not that I can think of - in fact, I think if you use zero it does a digitalWrite behind the scenes anyway. Could be the same for 255 too.
It just looks odd and makes the reader wonder what's going on.
Thank you for your advice
Do either of you see a way for me to move the "fingerDown" code into the existing code by moving the else to a different location meaning that the figure should always be up unless the specific section in which it goes down is active?
I'm not convinced that your second code needs to be nested in your existing ifs.
Try putting it in as the very last code in loop.
Wildbill has achieved hero status for the day! Thank you for your suggestion, It worked perfectly.
And thanks to Todd for suggesting I look into StateMachine.
I will clean up things based on your mutual suggestions.
Here is the current stage of the code prior to investigating the State Machine strategy. This code works exactly as I expected and needed.
    Revision Notes
const int fingerUp = 7; //rev 1.4 changed pin
const int fingerDown = 4; //rev 1.4 changed pin
int lastCheck = 1;
    myStepper.step(0);
    myStepper.step(0);
  //rev 1.4 starts here
    if (lastCheck == 1)
      digitalWrite(fingerUp, LOW);
      digitalWrite(fingerDown, HIGH);
      delay(300); //Time the motor runs forward
      digitalWrite(fingerDown, LOW);
      delay(300); //Added to pause a moment before moving
    lastCheck = 0;
    lastCheck = 1;
    digitalWrite(fingerUp, HIGH);
  //rev 1.4 ands here
This is odd:
    myStepper.step(0);
I would have expected the limit switch to be LOW, but since that code really doesn't do anything (Do zero steps) it isn't visible.
You know what... I thought the same exact thing. I think there may be a backwards wire in that circuit but it is working for now so I'll add that to future refinements and improvements.
