Sooo, I just wanted to report back after more testing. I thought it was working reliably after my last post, but turns out it was a fluke, the sketch did actually upload and I was able to do it through avrdude and the Arduino IDE. But now I’m back to getting the same frustrating “programmer is not responding” error again and I literally changed nothing. The behaivour is so inconsistent. it even fails at different stages everytime, sometimes it can’t even read the chip , others it goes to 75% write. What could be causing this erratic behaviour? here is a picture of the circuit, hopefully it makes sense and someone can spot something I’ve missed.
Here is the output:
User configuration file /Users/sam/.avrduderc does not exist
Using port : /dev/cu.usbserial-10
Using programmer : arduino
Setting baud rate : 115200
Ser_send: 0 [30] [20]
Ser_recv: . [14]
Ser_recv: . [10]
AVR part : ATmega1284
Programming modes : SPM, ISP, HVPP, JTAG
Memory Size Pg size
eeprom 4096 8
flash 131072 256
lfuse 1 1
hfuse 1 1
efuse 1 1
lock 1 1
prodsig/sigrow 24 1
sernum 10 1
io 224 1
sram 16384 1
signature 3 1
calibration 1 1
Variants Package F max T range V range
ATmega1284-AU TQFP44 20 MHz [-40 C, 85 C] [1.8 V, 5.5 V]
ATmega1284-AUR TQFP44 20 MHz [-40 C, 85 C] [1.8 V, 5.5 V]
ATmega1284-MU MLF44 20 MHz [-40 C, 85 C] [1.8 V, 5.5 V]
ATmega1284-MUR MLF44 20 MHz [N/A, N/A] [1.8 V, 5.5 V]
ATmega1284-PU PDIP40 20 MHz [-40 C, 85 C] [1.8 V, 5.5 V]
Programmer type : Arduino
Description : Arduino bootloader using STK500 v1 protocol
Ser_send: A [41] . [80] [20]
Ser_recv: . [14]
Ser_recv: . [03]
Ser_recv: . [10]
Ser_send: A [41] . [81] [20]
Ser_recv: . [14]
Ser_recv: . [08]
Ser_recv: . [10]
Ser_send: A [41] . [82] [20]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_send: A [41] . [98] [20]
Ser_recv: . [14]
Ser_recv: . [03]
Ser_recv: . [10]
HW Version : 3
FW Version : 8.0
Ser_recv: . [14]
Ser_recv: . [08]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_send: B [42] . [82] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [00] . [00] . [ff] . [ff] . [01] . [00] . [10] . [00] . [00] . [02] . [00] . [00] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: E [45] . [05] . [08] . [d7] . [a0] . [01] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: P [50] [20]
Ser_recv: . [14]
Ser_recv: . [10]
AVR device initialized and ready to accept instructions
Avr_signature(arduino, m1284)
Reading | | 0% 0.00 s
Avr_read_mem(arduino, m1284, signature, NULL)
Ser_send: u [75] [20]
Ser_recv: . [14] . [1e] . [97] . [06] . [10]
Reading | ################################################## | 100% 0.00 s
Device signature = 1E 97 06 (ATmega1284)
Auto-erasing chip as flash memory needs programming (-U flash:w:...)
specify the -D option to disable this feature
Avr_chip_erase(arduino, m1284)
Ser_send: V [56] . [ac] . [80] . [00] . [00] [20]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [08]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Erased chip
Read ihex record type 0x00 at 0x0000 with 16 bytes and chksum 0x3a (0x3a)
Read ihex record type 0x00 at 0x0010 with 16 bytes and chksum 0x18 (0x18)
Read ihex record type 0x00 at 0x0020 with 16 bytes and chksum 0x08 (0x08)
Read ihex record type 0x00 at 0x0030 with 16 bytes and chksum 0xf8 (0xf8)
Read ihex record type 0x00 at 0x0040 with 16 bytes and chksum 0x32 (0x32)
Read ihex record type 0x00 at 0x0050 with 16 bytes and chksum 0xd8 (0xd8)
Read ihex record type 0x00 at 0x0060 with 16 bytes and chksum 0xc8 (0xc8)
Read ihex record type 0x00 at 0x0070 with 16 bytes and chksum 0xb8 (0xb8)
Read ihex record type 0x00 at 0x0080 with 16 bytes and chksum 0xb9 (0xb9)
Read ihex record type 0x00 at 0x0090 with 16 bytes and chksum 0x51 (0x51)
Read ihex record type 0x00 at 0x00a0 with 16 bytes and chksum 0x20 (0x20)
Read ihex record type 0x00 at 0x00b0 with 16 bytes and chksum 0x20 (0x20)
Read ihex record type 0x00 at 0x00c0 with 16 bytes and chksum 0x32 (0x32)
Read ihex record type 0x00 at 0x00d0 with 16 bytes and chksum 0x22 (0x22)
Read ihex record type 0x00 at 0x00e0 with 16 bytes and chksum 0xdc (0xdc)
Read ihex record type 0x00 at 0x00f0 with 16 bytes and chksum 0x00 (0x00)
Read ihex record type 0x00 at 0x0100 with 16 bytes and chksum 0xc1 (0xc1)
Read ihex record type 0x00 at 0x0110 with 16 bytes and chksum 0x40 (0x40)
Read ihex record type 0x00 at 0x0120 with 16 bytes and chksum 0x5d (0x5d)
Read ihex record type 0x00 at 0x0130 with 16 bytes and chksum 0x13 (0x13)
Read ihex record type 0x00 at 0x0140 with 16 bytes and chksum 0x2c (0x2c)
Read ihex record type 0x00 at 0x0150 with 16 bytes and chksum 0x54 (0x54)
Read ihex record type 0x00 at 0x0160 with 16 bytes and chksum 0xa9 (0xa9)
Read ihex record type 0x00 at 0x0170 with 16 bytes and chksum 0x38 (0x38)
Read ihex record type 0x00 at 0x0180 with 16 bytes and chksum 0x2f (0x2f)
Read ihex record type 0x00 at 0x0190 with 16 bytes and chksum 0x50 (0x50)
Read ihex record type 0x00 at 0x01a0 with 16 bytes and chksum 0xd6 (0xd6)
Read ihex record type 0x00 at 0x01b0 with 16 bytes and chksum 0xf3 (0xf3)
Read ihex record type 0x00 at 0x01c0 with 16 bytes and chksum 0x51 (0x51)
Read ihex record type 0x00 at 0x01d0 with 16 bytes and chksum 0xfc (0xfc)
Read ihex record type 0x00 at 0x01e0 with 16 bytes and chksum 0x46 (0x46)
Read ihex record type 0x00 at 0x01f0 with 16 bytes and chksum 0xb9 (0xb9)
Read ihex record type 0x00 at 0x0200 with 16 bytes and chksum 0x78 (0x78)
Read ihex record type 0x00 at 0x0210 with 16 bytes and chksum 0xfd (0xfd)
Read ihex record type 0x00 at 0x0220 with 16 bytes and chksum 0xfa (0xfa)
Read ihex record type 0x00 at 0x0230 with 16 bytes and chksum 0x27 (0x27)
Read ihex record type 0x00 at 0x0240 with 16 bytes and chksum 0x5a (0x5a)
Read ihex record type 0x00 at 0x0250 with 16 bytes and chksum 0x0d (0x0d)
Read ihex record type 0x00 at 0x0260 with 16 bytes and chksum 0xf1 (0xf1)
Read ihex record type 0x00 at 0x0270 with 16 bytes and chksum 0xff (0xff)
Read ihex record type 0x00 at 0x0280 with 16 bytes and chksum 0x76 (0x76)
Read ihex record type 0x00 at 0x0290 with 16 bytes and chksum 0x3a (0x3a)
Read ihex record type 0x00 at 0x02a0 with 16 bytes and chksum 0x4e (0x4e)
Read ihex record type 0x00 at 0x02b0 with 16 bytes and chksum 0x44 (0x44)
Read ihex record type 0x00 at 0x02c0 with 16 bytes and chksum 0x03 (0x03)
Read ihex record type 0x00 at 0x02d0 with 16 bytes and chksum 0x66 (0x66)
Read ihex record type 0x00 at 0x02e0 with 16 bytes and chksum 0xc6 (0xc6)
Read ihex record type 0x00 at 0x02f0 with 16 bytes and chksum 0xf4 (0xf4)
Read ihex record type 0x00 at 0x0300 with 16 bytes and chksum 0x31 (0x31)
Read ihex record type 0x00 at 0x0310 with 16 bytes and chksum 0x53 (0x53)
Read ihex record type 0x00 at 0x0320 with 16 bytes and chksum 0x62 (0x62)
Read ihex record type 0x00 at 0x0330 with 16 bytes and chksum 0xe6 (0xe6)
Read ihex record type 0x00 at 0x0340 with 16 bytes and chksum 0x34 (0x34)
Read ihex record type 0x00 at 0x0350 with 16 bytes and chksum 0x8f (0x8f)
Read ihex record type 0x00 at 0x0360 with 16 bytes and chksum 0xa1 (0xa1)
Read ihex record type 0x00 at 0x0370 with 16 bytes and chksum 0x45 (0x45)
Read ihex record type 0x00 at 0x0380 with 16 bytes and chksum 0x8b (0x8b)
Read ihex record type 0x00 at 0x0390 with 16 bytes and chksum 0x1d (0x1d)
Read ihex record type 0x00 at 0x03a0 with 16 bytes and chksum 0xbe (0xbe)
Read ihex record type 0x00 at 0x03b0 with 16 bytes and chksum 0xc4 (0xc4)
Read ihex record type 0x00 at 0x03c0 with 16 bytes and chksum 0x4c (0x4c)
Read ihex record type 0x00 at 0x03d0 with 16 bytes and chksum 0xbf (0xbf)
Read ihex record type 0x00 at 0x03e0 with 16 bytes and chksum 0x1e (0x1e)
Read ihex record type 0x00 at 0x03f0 with 4 bytes and chksum 0xaf (0xaf)
Read ihex record type 0x01 at 0x0000 with 0 bytes and chksum 0xff (0xff)
Reading 1012 bytes for flash from input file atmega_blink.ino.hex
in 1 section [0, 0x3f3]: 4 pages and 12 pad bytes
Writing 1012 bytes to flash
Writing | | 0% 0.00 s
Avr_write_mem(arduino, m1284, flash, 0x003f4, auto_erase = 0)
Ser_send: U [55] . [80] . [01] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: t [74] . [01] . [00] F [46] [20]
Ser_recv: . [14]
Ser_recv: . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff]
Ser_recv: . [10]
Padding flash [0x0300, 0x03ff]
Ser_send: U [55] . [00] . [00] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: d [64] . [01] . [00] F [46] . [0c] . [94] . [80] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] G [47] . [01] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [00] . [00] ! [21] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] " [22] . [00] % [25] . [00] ( [28] . [00] + [2b] . [00] . [02] . [02] . [02] . [02] . [02] . [02] . [02] . [02] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [03] . [03] . [03] . [03] . [03] . [03] . [03] . [03] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [00] . [00] . [00] . [02] . [03] . [00] . [0a] . [0b] . [00] . [00] . [00] . [00] . [05] . [04] . [09] . [08] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] [20]
Ser_recv: . [00]
Writing | -------------------------------------------------- | 0% 0.05 s
Error stk500_paged_write() stk500.c 1052: protocol expects sync byte 0x14 but got 0x00
Avr_write_byte(arduino, m1284, flash, 0x00000, 0x0c)
Avr_write_byte_default(arduino, m1284, flash, 0x00000, 0x0c)
Ser_send: V [56] @ [40] . [00] . [00] . [0c] [20]
Ser_recv: / [2f]
Error stk500_cmd() stk500.c 163: programmer is out of sync
*** failed
Error do_op() update.c 813: unable to write flash (rc = -1)
Ser_send: Q [51] [20]
Ser_recv: w [77]
Error stk500_disable() stk500.c 814: protocol expects sync byte 0x14 but got 0x77
Here is the error when I run it from the arduino IDE:
Error: protocol expects sync byte 0x14 but got 0x10 in urclock_load_baddr()
Error: bootloader might be optiboot 8.0? Please use -x bootsize=<num>
Error: unable to read signature data for part ATmega1284 (rc = -1)
Error: unable to read signature data (rc = -1)
use -F to override this check
Failed uploading: uploading error: exit status 1
I got it to work one more time:
Ser_recv: . [14]
Ser_recv: . [10]
Memory Size Pg size
eeprom 4096 8
flash 131072 256
lfuse 1 1
hfuse 1 1
efuse 1 1
lock 1 1
prodsig/sigrow 24 1
sernum 10 1
io 224 1
sram 16384 1
signature 3 1
calibration 1 1
Ser_recv: . [14]
Ser_recv: . [03]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [08]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [03]
Ser_recv: . [10]
HW Version : 3
FW Version : 8.0
Ser_recv: . [14]
Ser_recv: . [08]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [08]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [00]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Erased chip
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [10]
Writing | ############# | 25% 0.07 s
Ser_send: U [55] . [80] . [00] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: d [64] . [01] . [00] F [46] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d0] . [e4] . [de] . [bf] . [cd] . [bf] ! [21] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a9] 0 [30] . [b2] . [07] . [e1] . [f7] . [0e] . [94] . [91] . [01] . [0c] . [94] . [f8] . [01] . [0c] . [94] . [00] . [00] . [ed] . [ee] . [f0] . [e0] $ [24] . [91] . [ed] . [ec] . [f0] . [e0] 4 [34] . [91] . [ed] . [ea] . [f0] . [e0] . [94] . [91] . [99] # [23] Y [59] . [f1] " [22] # [23] . [c1] . [f0] " [22] P [50] * [2a] 0 [30] . [a8] . [f4] . [e2] / [2f] . [f0] . [e0] . [e6] U [55] . [ff] O [4f] . [0c] . [94] . [ef] . [01] . [e3] . [00] . [e7] . [00] . [b4] . [00] . [cb] . [00] . [b9] . [00] . [b9] . [00] . [cf] . [00] . [d5] . [00] . [d9] . [00] . [df] . [00] [20] . [91] . [80] . [00] / [2f] w [77] [20] . [93] . [80] . [00] . [e9] / [2f] . [f0] . [e0] . [ee] . [0f] . [ff] . [1f] . [ea] V [56] . [ff] O [4f] . [a5] . [91] . [b4] . [91] . [9f] . [b7] . [f8] . [94] . [ec] . [91] . [81] . [11] $ [24] . [c0] 0 [30] . [95] > [3e] # [23] < [3c] . [93] . [9f] . [bf] . [08] . [95] [20] . [91] . [80] . [00] / [2f] } [7d] . [e8] . [cf] [20] . [91] . [b0] . [00] / [2f] w [77] [20] . [93] . [b0] . [00] . [e4] . [cf] [20] . [91] . [b0] . [00] / [2f] } [7d] . [f9] . [cf] [20] . [91] . [90] . [00] / [2f] w [77] [20] . [93] . [90] . [00] . [da] . [cf] [20] . [91] . [90] . [00] / [2f] } [7d] . [f9] . [cf] $ [24] . [b5] / [2f] w [77] $ [24] . [bd] . [d2] . [cf] $ [24] . [b5] / [2f] } [7d] . [fb] . [cf] > [3e] + [2b] . [dc] . [cf] ? [3f] . [b7] . [f8] . [94] . [80] . [91] . [05] . [01] . [90] . [91] . [06] . [01] . [a0] . [91] . [07] . [01] . [b0] . [91] . [08] . [01] & [26] . [b5] . [a8] . [9b] . [05] . [c0] / [2f] ? [3f] . [19] . [f0] . [01] . [96] . [a1] . [1d] . [b1] . [1d] ? [3f] . [bf] . [ba] / [2f] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Writing | ######################### | 50% 0.11 s
Ser_send: U [55] . [00] . [01] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: d [64] . [01] . [00] F [46] . [a9] / [2f] . [98] / [2f] . [88] ' [27] . [bc] . [01] . [cd] . [01] b [62] . [0f] q [71] . [1d] . [81] . [1d] . [91] . [1d] B [42] . [e0] f [66] . [0f] w [77] . [1f] . [88] . [1f] . [99] . [1f] J [4a] . [95] . [d1] . [f7] . [08] . [95] . [8f] . [92] . [9f] . [92] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0e] . [94] . [ec] . [00] K [4b] . [01] \ [5c] . [01] . [88] . [ee] . [c8] . [2e] . [83] . [e0] . [d8] . [2e] . [e1] , [2c] . [f1] , [2c] . [0e] . [94] . [ec] . [00] h [68] . [19] y [79] . [09] . [8a] . [09] . [9b] . [09] h [68] > [3e] s [73] @ [40] . [81] . [05] . [91] . [05] . [a8] . [f3] ! [21] . [e0] . [c2] . [1a] . [d1] . [08] . [e1] . [08] . [f1] . [08] . [88] . [ee] . [88] . [0e] . [83] . [e0] . [98] . [1e] . [a1] . [1c] . [b1] . [1c] . [c1] . [14] . [d1] . [04] . [e1] . [04] . [f1] . [04] ) [29] . [f7] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [bf] . [90] . [af] . [90] . [9f] . [90] . [8f] . [90] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [01] . [01] . [90] . [91] . [02] . [01] . [a0] . [91] . [03] . [01] . [b0] . [91] . [04] . [01] 0 [30] . [91] . [00] . [01] # [23] . [e0] # [23] . [0f] - [2d] 7 [37] h [68] . [f1] & [26] . [e8] # [23] . [0f] . [02] . [96] . [a1] . [1d] . [b1] . [1d] [20] . [93] . [00] . [01] . [80] . [93] . [01] . [01] . [90] . [93] . [02] . [01] . [a0] . [93] . [03] . [01] . [b0] . [93] . [04] . [01] . [80] . [91] . [05] . [01] . [90] . [91] . [06] . [01] . [a0] . [91] . [07] . [01] . [b0] . [91] . [08] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [05] . [01] . [90] . [93] . [06] . [01] . [a0] . [93] . [07] . [01] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Writing | ###################################### | 75% 0.15 s
Ser_recv: . [14]
Ser_recv: . [10]
Ser_send: d [64] . [01] . [00] F [46] . [b0] . [93] . [08] . [01] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [d4] . [cf] x [78] . [94] . [84] . [b5] . [83] ` [60] . [84] . [bd] . [85] . [b5] . [83] ` [60] . [85] . [bd] . [80] . [91] n [6e] . [00] . [81] ` [60] . [80] . [93] n [6e] . [00] . [82] . [e0] . [80] . [93] . [81] . [00] . [80] . [91] . [81] . [00] . [81] ` [60] . [80] . [93] . [81] . [00] . [80] . [91] . [80] . [00] . [81] ` [60] . [80] . [93] . [80] . [00] . [80] . [91] . [b1] . [00] . [84] ` [60] . [80] . [93] . [b1] . [00] . [80] . [91] . [b0] . [00] . [81] ` [60] . [80] . [93] . [b0] . [00] . [80] . [91] . [91] . [00] . [83] ` [60] . [80] . [93] . [91] . [00] . [80] . [91] . [90] . [00] . [81] ` [60] . [80] . [93] . [90] . [00] . [87] . [e8] . [80] . [93] z [7a] . [00] . [10] . [92] . [c1] . [00] . [ed] . [ec] . [f0] . [e0] $ [24] . [91] . [ed] . [ea] . [f0] . [e0] . [84] . [91] . [88] # [23] . [99] . [f0] . [90] . [e0] . [88] . [0f] . [99] . [1f] . [fc] . [01] . [e4] W [57] . [ff] O [4f] . [a5] . [91] . [b4] . [91] . [fc] . [01] . [ea] V [56] . [ff] O [4f] . [85] . [91] . [94] . [91] . [8f] . [b7] . [f8] . [94] . [ec] . [91] . [e2] + [2b] . [ec] . [93] . [8f] . [bf] . [c0] . [e0] . [d0] . [e0] . [81] . [e0] . [0e] . [94] . [94] . [00] . [0e] . [94] . [11] . [01] . [80] . [e0] . [0e] . [94] . [94] . [00] . [0e] . [94] . [11] . [01] [20] . [97] . [a1] . [f3] . [0e] . [94] . [00] . [00] . [f1] . [cf] . [ee] . [0f] . [ff] . [1f] . [00] $ [24] . [00] . [1c] . [0b] . [be] . [07] . [90] . [f6] . [91] . [e0] - [2d] . [09] . [94] . [f8] . [94] . [ff] . [cf] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] [20]
Ser_recv: . [14]
Ser_recv: . [10]
Writing | ################################################## | 100% 0.18 s
Avr_read_mem(arduino, m1284, flash, ATmega1284)
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [0c] . [94] . [80] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] G [47] . [01] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [0c] . [94] . [92] . [00] . [00] . [00] ! [21] . [00] $ [24] . [00] ' [27] . [00] * [2a] . [00] . [00] . [00] " [22] . [00] % [25] . [00] ( [28] . [00] + [2b] . [00] . [02] . [02] . [02] . [02] . [02] . [02] . [02] . [02] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [04] . [03] . [03] . [03] . [03] . [03] . [03] . [03] . [03] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [01] . [02] . [04] . [08] . [10] [20] @ [40] . [80] . [00] . [00] . [00] . [02] . [03] . [00] . [0a] . [0b] . [00] . [00] . [00] . [00] . [05] . [04] . [09] . [08] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00]
Ser_recv: . [10]
Reading | ############# | 25% 0.03 s
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d0] . [e4] . [de] . [bf] . [cd] . [bf] ! [21] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a9] 0 [30] . [b2] . [07] . [e1] . [f7] . [0e] . [94] . [91] . [01] . [0c] . [94] . [f8] . [01] . [0c] . [94] . [00] . [00] . [ed] . [ee] . [f0] . [e0] $ [24] . [91] . [ed] . [ec] . [f0] . [e0] 4 [34] . [91] . [ed] . [ea] . [f0] . [e0] . [94] . [91] . [99] # [23] Y [59] . [f1] " [22] # [23] . [c1] . [f0] " [22] P [50] * [2a] 0 [30] . [a8] . [f4] . [e2] / [2f] . [f0] . [e0] . [e6] U [55] . [ff] O [4f] . [0c] . [94] . [ef] . [01] . [e3] . [00] . [e7] . [00] . [b4] . [00] . [cb] . [00] . [b9] . [00] . [b9] . [00] . [cf] . [00] . [d5] . [00] . [d9] . [00] . [df] . [00] [20] . [91] . [80] . [00] / [2f] w [77] [20] . [93] . [80] . [00] . [e9] / [2f] . [f0] . [e0] . [ee] . [0f] . [ff] . [1f] . [ea] V [56] . [ff] O [4f] . [a5] . [91] . [b4] . [91] . [9f] . [b7] . [f8] . [94] . [ec] . [91] . [81] . [11] $ [24] . [c0] 0 [30] . [95] > [3e] # [23] < [3c] . [93] . [9f] . [bf] . [08] . [95] [20] . [91] . [80] . [00] / [2f] } [7d] . [e8] . [cf] [20] . [91] . [b0] . [00] / [2f] w [77] [20] . [93] . [b0] . [00] . [e4] . [cf] [20] . [91] . [b0] . [00] / [2f] } [7d] . [f9] . [cf] [20] . [91] . [90] . [00] / [2f] w [77] [20] . [93] . [90] . [00] . [da] . [cf] [20] . [91] . [90] . [00] / [2f] } [7d] . [f9] . [cf] $ [24] . [b5] / [2f] w [77] $ [24] . [bd] . [d2] . [cf] $ [24] . [b5] / [2f] } [7d] . [fb] . [cf] > [3e] + [2b] . [dc] . [cf] ? [3f] . [b7] . [f8] . [94] . [80] . [91] . [05] . [01] . [90] . [91] . [06] . [01] . [a0] . [91] . [07] . [01] . [b0] . [91] . [08] . [01] & [26] . [b5] . [a8] . [9b] . [05] . [c0] / [2f] ? [3f] . [19] . [f0] . [01] . [96] . [a1] . [1d] . [b1] . [1d] ? [3f] . [bf] . [ba] / [2f]
Ser_recv: . [10]
Reading | ######################### | 50% 0.06 s
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [a9] / [2f] . [98] / [2f] . [88] ' [27] . [bc] . [01] . [cd] . [01] b [62] . [0f] q [71] . [1d] . [81] . [1d] . [91] . [1d] B [42] . [e0] f [66] . [0f] w [77] . [1f] . [88] . [1f] . [99] . [1f] J [4a] . [95] . [d1] . [f7] . [08] . [95] . [8f] . [92] . [9f] . [92] . [af] . [92] . [bf] . [92] . [cf] . [92] . [df] . [92] . [ef] . [92] . [ff] . [92] . [0e] . [94] . [ec] . [00] K [4b] . [01] \ [5c] . [01] . [88] . [ee] . [c8] . [2e] . [83] . [e0] . [d8] . [2e] . [e1] , [2c] . [f1] , [2c] . [0e] . [94] . [ec] . [00] h [68] . [19] y [79] . [09] . [8a] . [09] . [9b] . [09] h [68] > [3e] s [73] @ [40] . [81] . [05] . [91] . [05] . [a8] . [f3] ! [21] . [e0] . [c2] . [1a] . [d1] . [08] . [e1] . [08] . [f1] . [08] . [88] . [ee] . [88] . [0e] . [83] . [e0] . [98] . [1e] . [a1] . [1c] . [b1] . [1c] . [c1] . [14] . [d1] . [04] . [e1] . [04] . [f1] . [04] ) [29] . [f7] . [ff] . [90] . [ef] . [90] . [df] . [90] . [cf] . [90] . [bf] . [90] . [af] . [90] . [9f] . [90] . [8f] . [90] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [01] . [01] . [90] . [91] . [02] . [01] . [a0] . [91] . [03] . [01] . [b0] . [91] . [04] . [01] 0 [30] . [91] . [00] . [01] # [23] . [e0] # [23] . [0f] - [2d] 7 [37] h [68] . [f1] & [26] . [e8] # [23] . [0f] . [02] . [96] . [a1] . [1d] . [b1] . [1d] [20] . [93] . [00] . [01] . [80] . [93] . [01] . [01] . [90] . [93] . [02] . [01] . [a0] . [93] . [03] . [01] . [b0] . [93] . [04] . [01] . [80] . [91] . [05] . [01] . [90] . [91] . [06] . [01] . [a0] . [91] . [07] . [01] . [b0] . [91] . [08] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [05] . [01] . [90] . [93] . [06] . [01] . [a0] . [93] . [07] . [01]
Ser_recv: . [10]
Reading | ###################################### | 75% 0.08 s
Ser_recv: . [14]
Ser_recv: . [10]
Ser_recv: . [14]
Ser_recv: . [b0] . [93] . [08] . [01] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [d4] . [cf] x [78] . [94] . [84] . [b5] . [83] ` [60] . [84] . [bd] . [85] . [b5] . [83] ` [60] . [85] . [bd] . [80] . [91] n [6e] . [00] . [81] ` [60] . [80] . [93] n [6e] . [00] . [82] . [e0] . [80] . [93] . [81] . [00] . [80] . [91] . [81] . [00] . [81] ` [60] . [80] . [93] . [81] . [00] . [80] . [91] . [80] . [00] . [81] ` [60] . [80] . [93] . [80] . [00] . [80] . [91] . [b1] . [00] . [84] ` [60] . [80] . [93] . [b1] . [00] . [80] . [91] . [b0] . [00] . [81] ` [60] . [80] . [93] . [b0] . [00] . [80] . [91] . [91] . [00] . [83] ` [60] . [80] . [93] . [91] . [00] . [80] . [91] . [90] . [00] . [81] ` [60] . [80] . [93] . [90] . [00] . [87] . [e8] . [80] . [93] z [7a] . [00] . [10] . [92] . [c1] . [00] . [ed] . [ec] . [f0] . [e0] $ [24] . [91] . [ed] . [ea] . [f0] . [e0] . [84] . [91] . [88] # [23] . [99] . [f0] . [90] . [e0] . [88] . [0f] . [99] . [1f] . [fc] . [01] . [e4] W [57] . [ff] O [4f] . [a5] . [91] . [b4] . [91] . [fc] . [01] . [ea] V [56] . [ff] O [4f] . [85] . [91] . [94] . [91] . [8f] . [b7] . [f8] . [94] . [ec] . [91] . [e2] + [2b] . [ec] . [93] . [8f] . [bf] . [c0] . [e0] . [d0] . [e0] . [81] . [e0] . [0e] . [94] . [94] . [00] . [0e] . [94] . [11] . [01] . [80] . [e0] . [0e] . [94] . [94] . [00] . [0e] . [94] . [11] . [01] [20] . [97] . [a1] . [f3] . [0e] . [94] . [00] . [00] . [f1] . [cf] . [ee] . [0f] . [ff] . [1f] . [00] $ [24] . [00] . [1c] . [0b] . [be] . [07] . [90] . [f6] . [91] . [e0] - [2d] . [09] . [94] . [f8] . [94] . [ff] . [cf] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff]
Ser_recv: . [10]
Reading | ################################################## | 100% 0.11 s
Avr_read_mem(): skipping page 4: no interesting data
Avr_read_mem(): skipping page 5: no interesting data
Avr_read_mem(): skipping page 6: no interesting data
Avr_read_mem(): skipping page 7: no interesting data
Avr_read_mem(): skipping page 8: no interesting data
Avr_read_mem(): skipping page 9: no interesting data
Avr_read_mem(): skipping page 10: no interesting data
Avr_read_mem(): skipping page 11: no interesting data
Avr_read_mem(): skipping page 12: no interesting data
Avr_read_mem(): skipping page 13: no interesting data
Avr_read_mem(): skipping page 14: no interesting data
Avr_read_mem(): skipping page 15: no interesting data
Avr_read_mem(): skipping page 16: no interesting data
Avr_read_mem(): skipping page 17: no interesting data
Avr_read_mem(): skipping page 18: no interesting data
Avr_read_mem(): skipping page 19: no interesting data
Avr_read_mem(): skipping page 20: no interesting data
Avr_read_mem(): skipping page 21: no interesting data
Avr_read_mem(): skipping page 22: no interesting data
Avr_read_mem(): skipping page 23: no interesting data
Avr_read_mem(): skipping page 24: no interesting data
Avr_read_mem(): skipping page 25: no interesting data
Avr_read_mem(): skipping page 26: no interesting data
Avr_read_mem(): skipping page 27: no interesting data
Avr_read_mem(): skipping page 28: no interesting data
Avr_read_mem(): skipping page 29: no interesting data
Avr_read_mem(): skipping page 30: no interesting data
Avr_read_mem(): skipping page 31: no interesting data
Avr_read_mem(): skipping page 32: no interesting data
Avr_read_mem(): skipping page 33: no interesting data
Avr_read_mem(): skipping page 34: no interesting data
Avr_read_mem(): skipping page 35: no interesting data
Avr_read_mem(): skipping page 36: no interesting data
Avr_read_mem(): skipping page 37: no interesting data
Avr_read_mem(): skipping page 38: no interesting data
Avr_read_mem(): skipping page 39: no interesting data
Avr_read_mem(): skipping page 40: no interesting data
Avr_read_mem(): skipping page 41: no interesting data
Avr_read_mem(): skipping page 42: no interesting data
Avr_read_mem(): skipping page 43: no interesting data
Avr_read_mem(): skipping page 44: no interesting data
Avr_read_mem(): skipping page 45: no interesting data
Avr_read_mem(): skipping page 46: no interesting data
Avr_read_mem(): skipping page 47: no interesting data
Avr_read_mem(): skipping page 48: no interesting data
Avr_read_mem(): skipping page 49: no interesting data
Avr_read_mem(): skipping page 50: no interesting data
Avr_read_mem(): skipping page 51: no interesting data
Avr_read_mem(): skipping page 52: no interesting data
Avr_read_mem(): skipping page 53: no interesting data
Avr_read_mem(): skipping page 54: no interesting data
Avr_read_mem(): skipping page 55: no interesting data
Avr_read_mem(): skipping page 56: no interesting data
Avr_read_mem(): skipping page 57: no interesting data
Avr_read_mem(): skipping page 58: no interesting data
Avr_read_mem(): skipping page 59: no interesting data
Avr_read_mem(): skipping page 60: no interesting data
Avr_read_mem(): skipping page 61: no interesting data
Avr_read_mem(): skipping page 62: no interesting data
Avr_read_mem(): skipping page 63: no interesting data
Avr_read_mem(): skipping page 64: no interesting data
Avr_read_mem(): skipping page 65: no interesting data
Avr_read_mem(): skipping page 66: no interesting data
Avr_read_mem(): skipping page 67: no interesting data
Avr_read_mem(): skipping page 68: no interesting data
Avr_read_mem(): skipping page 69: no interesting data
Avr_read_mem(): skipping page 70: no interesting data
Avr_read_mem(): skipping page 71: no interesting data
Avr_read_mem(): skipping page 72: no interesting data
Avr_read_mem(): skipping page 73: no interesting data
Avr_read_mem(): skipping page 74: no interesting data
Avr_read_mem(): skipping page 75: no interesting data
Avr_read_mem(): skipping page 76: no interesting data
Avr_read_mem(): skipping page 77: no interesting data
Avr_read_mem(): skipping page 78: no interesting data
Avr_read_mem(): skipping page 79: no interesting data
Avr_read_mem(): skipping page 80: no interesting data
Avr_read_mem(): skipping page 81: no interesting data
Avr_read_mem(): skipping page 82: no interesting data
Avr_read_mem(): skipping page 83: no interesting data
Avr_read_mem(): skipping page 84: no interesting data
Avr_read_mem(): skipping page 85: no interesting data
Avr_read_mem(): skipping page 86: no interesting data
Avr_read_mem(): skipping page 87: no interesting data
Avr_read_mem(): skipping page 88: no interesting data
Avr_read_mem(): skipping page 89: no interesting data
Avr_read_mem(): skipping page 90: no interesting data
Avr_read_mem(): skipping page 91: no interesting data
Avr_read_mem(): skipping page 92: no interesting data
Avr_read_mem(): skipping page 93: no interesting data
Avr_read_mem(): skipping page 94: no interesting data
Avr_read_mem(): skipping page 95: no interesting data
Avr_read_mem(): skipping page 96: no interesting data
Avr_read_mem(): skipping page 97: no interesting data
Avr_read_mem(): skipping page 98: no interesting data
Avr_read_mem(): skipping page 99: no interesting data
Avr_read_mem(): skipping page 100: no interesting data
Avr_read_mem(): skipping page 101: no interesting data
Avr_read_mem(): skipping page 102: no interesting data
Avr_read_mem(): skipping page 103: no interesting data
Avr_read_mem(): skipping page 104: no interesting data
Avr_read_mem(): skipping page 105: no interesting data
Avr_read_mem(): skipping page 106: no interesting data
Avr_read_mem(): skipping page 107: no interesting data
Avr_read_mem(): skipping page 108: no interesting data
Avr_read_mem(): skipping page 109: no interesting data
Avr_read_mem(): skipping page 110: no interesting data
Avr_read_mem(): skipping page 111: no interesting data
Avr_read_mem(): skipping page 112: no interesting data
Avr_read_mem(): skipping page 113: no interesting data
Avr_read_mem(): skipping page 114: no interesting data
Avr_read_mem(): skipping page 115: no interesting data
Avr_read_mem(): skipping page 116: no interesting data
Avr_read_mem(): skipping page 117: no interesting data
Avr_read_mem(): skipping page 118: no interesting data
Avr_read_mem(): skipping page 119: no interesting data
Avr_read_mem(): skipping page 120: no interesting data
Avr_read_mem(): skipping page 121: no interesting data
Avr_read_mem(): skipping page 122: no interesting data
Avr_read_mem(): skipping page 123: no interesting data
Avr_read_mem(): skipping page 124: no interesting data
Avr_read_mem(): skipping page 125: no interesting data
Avr_read_mem(): skipping page 126: no interesting data
Avr_read_mem(): skipping page 127: no interesting data
Avr_read_mem(): skipping page 128: no interesting data
Avr_read_mem(): skipping page 129: no interesting data
Avr_read_mem(): skipping page 130: no interesting data
Avr_read_mem(): skipping page 131: no interesting data
Avr_read_mem(): skipping page 132: no interesting data
Avr_read_mem(): skipping page 133: no interesting data
Avr_read_mem(): skipping page 134: no interesting data
Avr_read_mem(): skipping page 135: no interesting data
Avr_read_mem(): skipping page 136: no interesting data
Avr_read_mem(): skipping page 137: no interesting data
Avr_read_mem(): skipping page 138: no interesting data
Avr_read_mem(): skipping page 139: no interesting data
Avr_read_mem(): skipping page 140: no interesting data
Avr_read_mem(): skipping page 141: no interesting data
Avr_read_mem(): skipping page 142: no interesting data
Avr_read_mem(): skipping page 143: no interesting data
Avr_read_mem(): skipping page 144: no interesting data
Avr_read_mem(): skipping page 145: no interesting data
Avr_read_mem(): skipping page 146: no interesting data
Avr_read_mem(): skipping page 147: no interesting data
Avr_read_mem(): skipping page 148: no interesting data
Avr_read_mem(): skipping page 149: no interesting data
Avr_read_mem(): skipping page 150: no interesting data
Avr_read_mem(): skipping page 151: no interesting data
Avr_read_mem(): skipping page 152: no interesting data
Avr_read_mem(): skipping page 153: no interesting data
Avr_read_mem(): skipping page 154: no interesting data
Avr_read_mem(): skipping page 155: no interesting data
Avr_read_mem(): skipping page 156: no interesting data
Avr_read_mem(): skipping page 157: no interesting data
Avr_read_mem(): skipping page 158: no interesting data
Avr_read_mem(): skipping page 159: no interesting data
Avr_read_mem(): skipping page 160: no interesting data
Avr_read_mem(): skipping page 161: no interesting data
Avr_read_mem(): skipping page 162: no interesting data
Avr_read_mem(): skipping page 163: no interesting data
Avr_read_mem(): skipping page 164: no interesting data
Avr_read_mem(): skipping page 165: no interesting data
Avr_read_mem(): skipping page 166: no interesting data
Avr_read_mem(): skipping page 167: no interesting data
Avr_read_mem(): skipping page 168: no interesting data
Avr_read_mem(): skipping page 169: no interesting data
Avr_read_mem(): skipping page 170: no interesting data
Avr_read_mem(): skipping page 171: no interesting data
Avr_read_mem(): skipping page 172: no interesting data
Avr_read_mem(): skipping page 173: no interesting data
Avr_read_mem(): skipping page 174: no interesting data
Avr_read_mem(): skipping page 175: no interesting data
Avr_read_mem(): skipping page 176: no interesting data
Avr_read_mem(): skipping page 177: no interesting data
Avr_read_mem(): skipping page 178: no interesting data
Avr_read_mem(): skipping page 179: no interesting data
Avr_read_mem(): skipping page 180: no interesting data
Avr_read_mem(): skipping page 181: no interesting data
Avr_read_mem(): skipping page 182: no interesting data
Avr_read_mem(): skipping page 183: no interesting data
Avr_read_mem(): skipping page 184: no interesting data
Avr_read_mem(): skipping page 185: no interesting data
Avr_read_mem(): skipping page 186: no interesting data
Avr_read_mem(): skipping page 187: no interesting data
Avr_read_mem(): skipping page 188: no interesting data
Avr_read_mem(): skipping page 189: no interesting data
Avr_read_mem(): skipping page 190: no interesting data
Avr_read_mem(): skipping page 191: no interesting data
Avr_read_mem(): skipping page 192: no interesting data
Avr_read_mem(): skipping page 193: no interesting data
Avr_read_mem(): skipping page 194: no interesting data
Avr_read_mem(): skipping page 195: no interesting data
Avr_read_mem(): skipping page 196: no interesting data
Avr_read_mem(): skipping page 197: no interesting data
Avr_read_mem(): skipping page 198: no interesting data
Avr_read_mem(): skipping page 199: no interesting data
Avr_read_mem(): skipping page 200: no interesting data
Avr_read_mem(): skipping page 201: no interesting data
Avr_read_mem(): skipping page 202: no interesting data
Avr_read_mem(): skipping page 203: no interesting data
Avr_read_mem(): skipping page 204: no interesting data
Avr_read_mem(): skipping page 205: no interesting data
Avr_read_mem(): skipping page 206: no interesting data
Avr_read_mem(): skipping page 207: no interesting data
Avr_read_mem(): skipping page 208: no interesting data
Avr_read_mem(): skipping page 209: no interesting data
Avr_read_mem(): skipping page 210: no interesting data
Avr_read_mem(): skipping page 211: no interesting data
Avr_read_mem(): skipping page 212: no interesting data
Avr_read_mem(): skipping page 213: no interesting data
Avr_read_mem(): skipping page 214: no interesting data
Avr_read_mem(): skipping page 215: no interesting data
Avr_read_mem(): skipping page 216: no interesting data
Avr_read_mem(): skipping page 217: no interesting data
Avr_read_mem(): skipping page 218: no interesting data
Avr_read_mem(): skipping page 219: no interesting data
Avr_read_mem(): skipping page 220: no interesting data
Avr_read_mem(): skipping page 221: no interesting data
Avr_read_mem(): skipping page 222: no interesting data
Avr_read_mem(): skipping page 223: no interesting data
Avr_read_mem(): skipping page 224: no interesting data
Avr_read_mem(): skipping page 225: no interesting data
Avr_read_mem(): skipping page 226: no interesting data
Avr_read_mem(): skipping page 227: no interesting data
Avr_read_mem(): skipping page 228: no interesting data
Avr_read_mem(): skipping page 229: no interesting data
Avr_read_mem(): skipping page 230: no interesting data
Avr_read_mem(): skipping page 231: no interesting data
Avr_read_mem(): skipping page 232: no interesting data
Avr_read_mem(): skipping page 233: no interesting data
Avr_read_mem(): skipping page 234: no interesting data
Avr_read_mem(): skipping page 235: no interesting data
Avr_read_mem(): skipping page 236: no interesting data
Avr_read_mem(): skipping page 237: no interesting data
Avr_read_mem(): skipping page 238: no interesting data
Avr_read_mem(): skipping page 239: no interesting data
Avr_read_mem(): skipping page 240: no interesting data
Avr_read_mem(): skipping page 241: no interesting data
Avr_read_mem(): skipping page 242: no interesting data
Avr_read_mem(): skipping page 243: no interesting data
Avr_read_mem(): skipping page 244: no interesting data
Avr_read_mem(): skipping page 245: no interesting data
Avr_read_mem(): skipping page 246: no interesting data
Avr_read_mem(): skipping page 247: no interesting data
Avr_read_mem(): skipping page 248: no interesting data
Avr_read_mem(): skipping page 249: no interesting data
Avr_read_mem(): skipping page 250: no interesting data
Avr_read_mem(): skipping page 251: no interesting data
Avr_read_mem(): skipping page 252: no interesting data
Avr_read_mem(): skipping page 253: no interesting data
Avr_read_mem(): skipping page 254: no interesting data
Avr_read_mem(): skipping page 255: no interesting data
Avr_read_mem(): skipping page 256: no interesting data
Avr_read_mem(): skipping page 257: no interesting data
Avr_read_mem(): skipping page 258: no interesting data
Avr_read_mem(): skipping page 259: no interesting data
Avr_read_mem(): skipping page 260: no interesting data
Avr_read_mem(): skipping page 261: no interesting data
Avr_read_mem(): skipping page 262: no interesting data
Avr_read_mem(): skipping page 263: no interesting data
Avr_read_mem(): skipping page 264: no interesting data
Avr_read_mem(): skipping page 265: no interesting data
Avr_read_mem(): skipping page 266: no interesting data
Avr_read_mem(): skipping page 267: no interesting data
Avr_read_mem(): skipping page 268: no interesting data
Avr_read_mem(): skipping page 269: no interesting data
Avr_read_mem(): skipping page 270: no interesting data
Avr_read_mem(): skipping page 271: no interesting data
Avr_read_mem(): skipping page 272: no interesting data
Avr_read_mem(): skipping page 273: no interesting data
Avr_read_mem(): skipping page 274: no interesting data
Avr_read_mem(): skipping page 275: no interesting data
Avr_read_mem(): skipping page 276: no interesting data
Avr_read_mem(): skipping page 277: no interesting data
Avr_read_mem(): skipping page 278: no interesting data
Avr_read_mem(): skipping page 279: no interesting data
Avr_read_mem(): skipping page 280: no interesting data
Avr_read_mem(): skipping page 281: no interesting data
Avr_read_mem(): skipping page 282: no interesting data
Avr_read_mem(): skipping page 283: no interesting data
Avr_read_mem(): skipping page 284: no interesting data
Avr_read_mem(): skipping page 285: no interesting data
Avr_read_mem(): skipping page 286: no interesting data
Avr_read_mem(): skipping page 287: no interesting data
Avr_read_mem(): skipping page 288: no interesting data
Avr_read_mem(): skipping page 289: no interesting data
Avr_read_mem(): skipping page 290: no interesting data
Avr_read_mem(): skipping page 291: no interesting data
Avr_read_mem(): skipping page 292: no interesting data
Avr_read_mem(): skipping page 293: no interesting data
Avr_read_mem(): skipping page 294: no interesting data
Avr_read_mem(): skipping page 295: no interesting data
Avr_read_mem(): skipping page 296: no interesting data
Avr_read_mem(): skipping page 297: no interesting data
Avr_read_mem(): skipping page 298: no interesting data
Avr_read_mem(): skipping page 299: no interesting data
Avr_read_mem(): skipping page 300: no interesting data
Avr_read_mem(): skipping page 301: no interesting data
Avr_read_mem(): skipping page 302: no interesting data
Avr_read_mem(): skipping page 303: no interesting data
Avr_read_mem(): skipping page 304: no interesting data
Avr_read_mem(): skipping page 305: no interesting data
Avr_read_mem(): skipping page 306: no interesting data
Avr_read_mem(): skipping page 307: no interesting data
Avr_read_mem(): skipping page 308: no interesting data
Avr_read_mem(): skipping page 309: no interesting data
Avr_read_mem(): skipping page 310: no interesting data
Avr_read_mem(): skipping page 311: no interesting data
Avr_read_mem(): skipping page 312: no interesting data
Avr_read_mem(): skipping page 313: no interesting data
Avr_read_mem(): skipping page 314: no interesting data
Avr_read_mem(): skipping page 315: no interesting data
Avr_read_mem(): skipping page 316: no interesting data
Avr_read_mem(): skipping page 317: no interesting data
Avr_read_mem(): skipping page 318: no interesting data
Avr_read_mem(): skipping page 319: no interesting data
Avr_read_mem(): skipping page 320: no interesting data
Avr_read_mem(): skipping page 321: no interesting data
Avr_read_mem(): skipping page 322: no interesting data
Avr_read_mem(): skipping page 323: no interesting data
Avr_read_mem(): skipping page 324: no interesting data
Avr_read_mem(): skipping page 325: no interesting data
Avr_read_mem(): skipping page 326: no interesting data
Avr_read_mem(): skipping page 327: no interesting data
Avr_read_mem(): skipping page 328: no interesting data
Avr_read_mem(): skipping page 329: no interesting data
Avr_read_mem(): skipping page 330: no interesting data
Avr_read_mem(): skipping page 331: no interesting data
Avr_read_mem(): skipping page 332: no interesting data
Avr_read_mem(): skipping page 333: no interesting data
Avr_read_mem(): skipping page 334: no interesting data
Avr_read_mem(): skipping page 335: no interesting data
Avr_read_mem(): skipping page 336: no interesting data
Avr_read_mem(): skipping page 337: no interesting data
Avr_read_mem(): skipping page 338: no interesting data
Avr_read_mem(): skipping page 339: no interesting data
Avr_read_mem(): skipping page 340: no interesting data
Avr_read_mem(): skipping page 341: no interesting data
Avr_read_mem(): skipping page 342: no interesting data
Avr_read_mem(): skipping page 343: no interesting data
Avr_read_mem(): skipping page 344: no interesting data
Avr_read_mem(): skipping page 345: no interesting data
Avr_read_mem(): skipping page 346: no interesting data
Avr_read_mem(): skipping page 347: no interesting data
Avr_read_mem(): skipping page 348: no interesting data
Avr_read_mem(): skipping page 349: no interesting data
Avr_read_mem(): skipping page 350: no interesting data
Avr_read_mem(): skipping page 351: no interesting data
Avr_read_mem(): skipping page 352: no interesting data
Avr_read_mem(): skipping page 353: no interesting data
Avr_read_mem(): skipping page 354: no interesting data
Avr_read_mem(): skipping page 355: no interesting data
Avr_read_mem(): skipping page 356: no interesting data
Avr_read_mem(): skipping page 357: no interesting data
Avr_read_mem(): skipping page 358: no interesting data
Avr_read_mem(): skipping page 359: no interesting data
Avr_read_mem(): skipping page 360: no interesting data
Avr_read_mem(): skipping page 361: no interesting data
Avr_read_mem(): skipping page 362: no interesting data
Avr_read_mem(): skipping page 363: no interesting data
Avr_read_mem(): skipping page 364: no interesting data
Avr_read_mem(): skipping page 365: no interesting data
Avr_read_mem(): skipping page 366: no interesting data
Avr_read_mem(): skipping page 367: no interesting data
Avr_read_mem(): skipping page 368: no interesting data
Avr_read_mem(): skipping page 369: no interesting data
Avr_read_mem(): skipping page 370: no interesting data
Avr_read_mem(): skipping page 371: no interesting data
Avr_read_mem(): skipping page 372: no interesting data
Avr_read_mem(): skipping page 373: no interesting data
Avr_read_mem(): skipping page 374: no interesting data
Avr_read_mem(): skipping page 375: no interesting data
Avr_read_mem(): skipping page 376: no interesting data
Avr_read_mem(): skipping page 377: no interesting data
Avr_read_mem(): skipping page 378: no interesting data
Avr_read_mem(): skipping page 379: no interesting data
Avr_read_mem(): skipping page 380: no interesting data
Avr_read_mem(): skipping page 381: no interesting data
Avr_read_mem(): skipping page 382: no interesting data
Avr_read_mem(): skipping page 383: no interesting data
Avr_read_mem(): skipping page 384: no interesting data
Avr_read_mem(): skipping page 385: no interesting data
Avr_read_mem(): skipping page 386: no interesting data
Avr_read_mem(): skipping page 387: no interesting data
Avr_read_mem(): skipping page 388: no interesting data
Avr_read_mem(): skipping page 389: no interesting data
Avr_read_mem(): skipping page 390: no interesting data
Avr_read_mem(): skipping page 391: no interesting data
Avr_read_mem(): skipping page 392: no interesting data
Avr_read_mem(): skipping page 393: no interesting data
Avr_read_mem(): skipping page 394: no interesting data
Avr_read_mem(): skipping page 395: no interesting data
Avr_read_mem(): skipping page 396: no interesting data
Avr_read_mem(): skipping page 397: no interesting data
Avr_read_mem(): skipping page 398: no interesting data
Avr_read_mem(): skipping page 399: no interesting data
Avr_read_mem(): skipping page 400: no interesting data
Avr_read_mem(): skipping page 401: no interesting data
Avr_read_mem(): skipping page 402: no interesting data
Avr_read_mem(): skipping page 403: no interesting data
Avr_read_mem(): skipping page 404: no interesting data
Avr_read_mem(): skipping page 405: no interesting data
Avr_read_mem(): skipping page 406: no interesting data
Avr_read_mem(): skipping page 407: no interesting data
Avr_read_mem(): skipping page 408: no interesting data
Avr_read_mem(): skipping page 409: no interesting data
Avr_read_mem(): skipping page 410: no interesting data
Avr_read_mem(): skipping page 411: no interesting data
Avr_read_mem(): skipping page 412: no interesting data
Avr_read_mem(): skipping page 413: no interesting data
Avr_read_mem(): skipping page 414: no interesting data
Avr_read_mem(): skipping page 415: no interesting data
Avr_read_mem(): skipping page 416: no interesting data
Avr_read_mem(): skipping page 417: no interesting data
Avr_read_mem(): skipping page 418: no interesting data
Avr_read_mem(): skipping page 419: no interesting data
Avr_read_mem(): skipping page 420: no interesting data
Avr_read_mem(): skipping page 421: no interesting data
Avr_read_mem(): skipping page 422: no interesting data
Avr_read_mem(): skipping page 423: no interesting data
Avr_read_mem(): skipping page 424: no interesting data
Avr_read_mem(): skipping page 425: no interesting data
Avr_read_mem(): skipping page 426: no interesting data
Avr_read_mem(): skipping page 427: no interesting data
Avr_read_mem(): skipping page 428: no interesting data
Avr_read_mem(): skipping page 429: no interesting data
Avr_read_mem(): skipping page 430: no interesting data
Avr_read_mem(): skipping page 431: no interesting data
Avr_read_mem(): skipping page 432: no interesting data
Avr_read_mem(): skipping page 433: no interesting data
Avr_read_mem(): skipping page 434: no interesting data
Avr_read_mem(): skipping page 435: no interesting data
Avr_read_mem(): skipping page 436: no interesting data
Avr_read_mem(): skipping page 437: no interesting data
Avr_read_mem(): skipping page 438: no interesting data
Avr_read_mem(): skipping page 439: no interesting data
Avr_read_mem(): skipping page 440: no interesting data
Avr_read_mem(): skipping page 441: no interesting data
Avr_read_mem(): skipping page 442: no interesting data
Avr_read_mem(): skipping page 443: no interesting data
Avr_read_mem(): skipping page 444: no interesting data
Avr_read_mem(): skipping page 445: no interesting data
Avr_read_mem(): skipping page 446: no interesting data
Avr_read_mem(): skipping page 447: no interesting data
Avr_read_mem(): skipping page 448: no interesting data
Avr_read_mem(): skipping page 449: no interesting data
Avr_read_mem(): skipping page 450: no interesting data
Avr_read_mem(): skipping page 451: no interesting data
Avr_read_mem(): skipping page 452: no interesting data
Avr_read_mem(): skipping page 453: no interesting data
Avr_read_mem(): skipping page 454: no interesting data
Avr_read_mem(): skipping page 455: no interesting data
Avr_read_mem(): skipping page 456: no interesting data
Avr_read_mem(): skipping page 457: no interesting data
Avr_read_mem(): skipping page 458: no interesting data
Avr_read_mem(): skipping page 459: no interesting data
Avr_read_mem(): skipping page 460: no interesting data
Avr_read_mem(): skipping page 461: no interesting data
Avr_read_mem(): skipping page 462: no interesting data
Avr_read_mem(): skipping page 463: no interesting data
Avr_read_mem(): skipping page 464: no interesting data
Avr_read_mem(): skipping page 465: no interesting data
Avr_read_mem(): skipping page 466: no interesting data
Avr_read_mem(): skipping page 467: no interesting data
Avr_read_mem(): skipping page 468: no interesting data
Avr_read_mem(): skipping page 469: no interesting data
Avr_read_mem(): skipping page 470: no interesting data
Avr_read_mem(): skipping page 471: no interesting data
Avr_read_mem(): skipping page 472: no interesting data
Avr_read_mem(): skipping page 473: no interesting data
Avr_read_mem(): skipping page 474: no interesting data
Avr_read_mem(): skipping page 475: no interesting data
Avr_read_mem(): skipping page 476: no interesting data
Avr_read_mem(): skipping page 477: no interesting data
Avr_read_mem(): skipping page 478: no interesting data
Avr_read_mem(): skipping page 479: no interesting data
Avr_read_mem(): skipping page 480: no interesting data
Avr_read_mem(): skipping page 481: no interesting data
Avr_read_mem(): skipping page 482: no interesting data
Avr_read_mem(): skipping page 483: no interesting data
Avr_read_mem(): skipping page 484: no interesting data
Avr_read_mem(): skipping page 485: no interesting data
Avr_read_mem(): skipping page 486: no interesting data
Avr_read_mem(): skipping page 487: no interesting data
Avr_read_mem(): skipping page 488: no interesting data
Avr_read_mem(): skipping page 489: no interesting data
Avr_read_mem(): skipping page 490: no interesting data
Avr_read_mem(): skipping page 491: no interesting data
Avr_read_mem(): skipping page 492: no interesting data
Avr_read_mem(): skipping page 493: no interesting data
Avr_read_mem(): skipping page 494: no interesting data
Avr_read_mem(): skipping page 495: no interesting data
Avr_read_mem(): skipping page 496: no interesting data
Avr_read_mem(): skipping page 497: no interesting data
Avr_read_mem(): skipping page 498: no interesting data
Avr_read_mem(): skipping page 499: no interesting data
Avr_read_mem(): skipping page 500: no interesting data
Avr_read_mem(): skipping page 501: no interesting data
Avr_read_mem(): skipping page 502: no interesting data
Avr_read_mem(): skipping page 503: no interesting data
Avr_read_mem(): skipping page 504: no interesting data
Avr_read_mem(): skipping page 505: no interesting data
Avr_read_mem(): skipping page 506: no interesting data
Avr_read_mem(): skipping page 507: no interesting data
Avr_read_mem(): skipping page 508: no interesting data
Avr_read_mem(): skipping page 509: no interesting data
Avr_read_mem(): skipping page 510: no interesting data
Avr_read_mem(): skipping page 511: no interesting data
Avr_verify_mem(arduino, m1284, m1284, flash, 0x003f4)
1012 bytes of flash verified
Ser_recv: . [14]
Ser_recv: . [10]
Avrdude done. Thank you.
