I have an issue with sensor calibration on my AlphaBot 2 AR when using the demo code provided by the manufacturer. Despite following the instructions, the calibration doesn't seem to take place, and the sensor values are incorrect. Strangely, when I tested the same setup on a laptop at college, it worked without any problems.
Could anyone offer insights into why the calibration isn't working as expected on my setup? Any suggestions for troubleshooting or alternative approaches would be appreciated.
#include <Arduino.h>
#include "TRSensors.h"
#define Clock 13
#define Address 12
#define DataOut 11
#define CS 10
#define NUMSENSORS 5
// Base class data member initialization (called by derived class init())
TRSensors::TRSensors()
pinMode(Clock, OUTPUT);
pinMode(Address, OUTPUT);
pinMode(DataOut, INPUT);
pinMode(CS, OUTPUT);
_numSensors = NUMSENSORS;
calibratedMin = (unsigned int*)malloc(sizeof(unsigned int) * _numSensors);
calibratedMax = (unsigned int*)malloc(sizeof(unsigned int) * _numSensors);
for(int i=0;i<_numSensors;i++)
calibratedMin[i] = 1023;
calibratedMax[i] = 0;
// Reads the sensor values using TLC1543 ADC chip into an array.
// The values returned are a measure of the reflectance in abstract units,
// with higher values corresponding to lower reflectance (e.g. a black
// surface or a void).
void TRSensors::AnalogRead(unsigned int *sensor_values)
char i,j;
unsigned int channel = 0;
unsigned int values[] = {0,0,0,0,0,0,0,0};
for(j = 0;j < _numSensors + 1;j++)
digitalWrite(CS,LOW);
for(i = 0;i < 10;i++)
//0 to 4 clock transfer channel address
if((i < 4) && (j >> (3 - i) & 0x01))
digitalWrite(Address,HIGH);
digitalWrite(Address,LOW);
//0 to 10 clock receives the previous conversion result
values[j] <<= 1;
if(digitalRead(DataOut))
values[j] |= 0x01;
digitalWrite(Clock,HIGH);
digitalWrite(Clock,LOW);
//sent 11 to 16 clock
for(i = 0;i < 6;i++)
digitalWrite(CS,HIGH);
for(i = 0;i < _numSensors;i++)
sensor_values[i] = values[i+1];
// Reads the sensors 10 times and uses the results for
// calibration. The sensor values are not returned; instead, the
// maximum and minimum values found over time are stored internally
// and used for the readCalibrated() method.
void TRSensors::calibrate()
int i;
unsigned int sensor_values[_numSensors];
unsigned int max_sensor_values[_numSensors];
unsigned int min_sensor_values[_numSensors];
int j;
for(j=0;j<10;j++)
AnalogRead(sensor_values);
for(i=0;i<_numSensors;i++)
// set the max we found THIS time
if(j == 0 || max_sensor_values[i] < sensor_values[i])
max_sensor_values[i] = sensor_values[i];
// set the min we found THIS time
if(j == 0 || min_sensor_values[i] > sensor_values[i])
min_sensor_values[i] = sensor_values[i];
// record the min and max calibration values
if(min_sensor_values[i] > calibratedMax[i])
calibratedMax[i] = min_sensor_values[i];
if(max_sensor_values[i] < calibratedMin[i])
calibratedMin[i] = max_sensor_values[i];
// Returns values calibrated to a value between 0 and 1000, where
// 0 corresponds to the minimum value read by calibrate() and 1000
// corresponds to the maximum value. Calibration values are
// stored separately for each sensor, so that differences in the
// sensors are accounted for automatically.
void TRSensors::readCalibrated(unsigned int *sensor_values)
int i;
// read the needed values
unsigned int calmin,calmax;
unsigned int denominator;
denominator = calibratedMax[i] - calibratedMin[i];
signed int x = 0;
if(denominator != 0)
x = (((signed long)sensor_values[i]) - calibratedMin[i])
* 1000 / denominator;
if(x < 0)
x = 0;
else if(x > 1000)
x = 1000;
sensor_values[i] = x;
// Operates the same as read calibrated, but also returns an
// estimated position of the robot with respect to a line. The
// estimate is made using a weighted average of the sensor indices
// multiplied by 1000, so that a return value of 0 indicates that
// the line is directly below sensor 0, a return value of 1000
// indicates that the line is directly below sensor 1, 2000
// indicates that it's below sensor 2000, etc. Intermediate
// values indicate that the line is between two sensors. The
// formula is:
// 0*value0 + 1000*value1 + 2000*value2 + ...
// value0 + value1 + value2 + ...
// By default, this function assumes a dark line (high values)
// surrounded by white (low values). If your line is light on
// black, set the optional second argument white_line to true. In
// this case, each sensor value will be replaced by (1000-value)
// before the averaging.
int TRSensors::readLine(unsigned int *sensor_values, unsigned char white_line)
unsigned char i, on_line = 0;
unsigned long avg; // this is for the weighted total, which is long
// before division
unsigned int sum; // this is for the denominator which is <= 64000
static int last_value=0; // assume initially that the line is left.
readCalibrated(sensor_values);
avg = 0;
sum = 0;
for(i=0;i<_numSensors;i++) {
int value = sensor_values[i];
if(!white_line)
value = 1000-value;
sensor_values[i] = value;
// keep track of whether we see the line at all
if(value > 300) {
on_line = 1;
// only average in values that are above a noise threshold
if(value > 50) {
avg += (long)(value) * (i * 1000);
sum += value;
if(!on_line)
// If it last read to the left of center, return 0.
if(last_value < (_numSensors-1)*1000/2)
return 0;
// If it last read to the right of center, return the max.
return (_numSensors-1)*1000;
last_value = avg/sum;
return last_value;
I have attached the source file of the library for reference. Could be any other reason the calibration doesn't take place?
