Troubles with making FTP server
So i found this Arduino-Ftp-Server/FtpServer at master · gallegojm/Arduino-Ftp-Server · GitHub an decided to give it a try. Im using arduino uno and ethernet shield with wiznet w5100. Currently i am at the second step
  1. To test the access to the SD card is ok :
  • load example libraries/FatFs/examples/FatFsDemo,
  • verify that SD_CS_PIN has the correct value (Chip Select for SD card reader),
  • run
I downloaded, installed FatFs and, the FatFsDemo example aaand i get this error:
I think there is something wrong with the FatFs library.
Arduino: 1.6.12 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino: In function 'void setup()':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:37:46: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Unable to mount SD card" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:47:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   if( dir.openDir( "/" ))
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:58:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   char * dirName = "/New Directory";
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:65:49: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     printError( res, "Error creating directory" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:70:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   char * fileName = "/New Directory/A new file.txt";
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:73:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Error creating file" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:77:65: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   res = file.writeString( "Test d'ecriture dans un fichier\r\n" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:79:59: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     res = file.writeString( "Testing writing to file\r\n" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:81:69: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     res = file.writeString( "Prueba de escritura en un archivo\r\n" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:85:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     char * ps1 = "Test di scrittura su file\r\n";
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:92:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     char * ps2 = "Testes de gravacao em um arquivo\r\n";
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:97:53: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( ( res >= 0 ), "Error writing to file" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:109:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Error closing file" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:112:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   char * newName = "/TEST.TXT";
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:117:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Error renaming file" );
There is more to that error but the forum doesn't let me post it due to the 9000 characters limitation. I will post it if it's needed.
What ERRORS did you get? None that I can see in what you posted. If the warnings bother you, fix them. Doing so is trivial.
This is the whole output from the compiler:
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:121:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   if( dir.openDir( "/New Directory" ))
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:125:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:132:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Error opening file" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:154:42: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Error deleting file" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/examples/FatFsDemo/FatFsDemo.ino:159:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   printError( res, "Error deleting directory" );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp: In member function 'bool FatFsCard::begin(uint8_t, uint8_t)':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:137:22: error: no matching function for call to 'SPIClass::begin(uint8_t&)'
   SPI.begin( m_CSPin );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:137:22: note: candidate is:
In file included from /Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:23:0:
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.h:159:15: note: static void SPIClass::begin()
   static void begin();
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.h:159:15: note:   candidate expects 0 arguments, 1 provided
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:146:22: error: no matching function for call to 'SPIClass::begin(uint8_t&)'
   SPI.begin( csPin52 );
Here is the rest of the compiler output:
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:146:22: note: candidate is:
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:147:79: error: no matching function for call to 'SPIClass::beginTransaction(uint8_t&, SPISettings)'
   SPI.beginTransaction( csPin52, SPISettings( m_spifrec, MSBFIRST, SPI_MODE0 ));
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:147:79: note: candidate is:
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.h:178:22: note: static void SPIClass::beginTransaction(SPISettings)
   inline static void beginTransaction(SPISettings settings) {
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.h:178:22: note:   candidate expects 1 argument, 2 provided
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:149:33: warning: invalid conversion from 'uint8_t {aka unsigned char}' to 'void*' [-fpermissive]
     SPI.transfer( csPin52, 0XFF );
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.h:244:22: note: initializing argument 1 of 'static void SPIClass::transfer(void*, size_t)'
   inline static void transfer(void *buf, size_t count) {
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:217:79: error: no matching function for call to 'SPIClass::beginTransaction(uint8_t&, SPISettings)'
   SPI.beginTransaction( m_CSPin, SPISettings( m_spifrec, MSBFIRST, SPI_MODE0 ));
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:217:79: note: candidate is:
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp: In member function 'void FatFsCard::chipSelect()':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:283:79: error: no matching function for call to 'SPIClass::beginTransaction(uint8_t&, SPISettings)'
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:283:79: note: candidate is:
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp: In member function 'uint8_t FatFsCard::spiReceive()':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:599:38: warning: invalid conversion from 'uint8_t {aka unsigned char}' to 'void*' [-fpermissive]
   return SPI.transfer( m_CSPin, 0XFF );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:599:38: error: void value not ignored as it ought to be
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp: In member function 'uint8_t FatFsCard::spiReceive(uint8_t*, size_t)':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:606:43: error: 'SPI_CONTINUE' was not declared in this scope
     buf[i] = SPI.transfer( m_CSPin, 0XFF, SPI_CONTINUE );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:607:40: warning: invalid conversion from 'uint8_t {aka unsigned char}' to 'void*' [-fpermissive]
   buf[i] = SPI.transfer( m_CSPin, 0XFF );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:607:10: error: void value not ignored as it ought to be
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp: In member function 'void FatFsCard::spiSend(uint8_t)':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:613:31: warning: invalid conversion from 'uint8_t {aka unsigned char}' to 'void*' [-fpermissive]
   SPI.transfer( m_CSPin, data );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp: In member function 'void FatFsCard::spiSend(const uint8_t*, size_t)':
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:620:36: error: 'SPI_CONTINUE' was not declared in this scope
     SPI.transfer( m_CSPin, buf[i], SPI_CONTINUE );
/Users/borisborisov/Documents/Arduino/libraries/FatFs/FatFsCard.cpp:621:33: warning: invalid conversion from 'uint8_t {aka unsigned char}' to 'void*' [-fpermissive]
   SPI.transfer( m_CSPin, buf[i] );
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
I do not know where you got the FatFs library, but it appears to use it's own version of SPI, which is not compatible with the one that comes with the IDE.
I download it from github. Could you give me a link where i can download a working library?
That's as useful as saying "I got it from the internet". Not at all, that is.
To do what?
Link to download the FatFs library
Did you read the instructions on the page you linked to?
How to use FtpServer on Arduino Due and ide 1.6.0
Due != Uno
